    [Plugin] V-Ray Tools
    238 Posts 80 Posters 301.7k Views 80 Watching
      @segal91 said:
      whats about rendering elevations in parallel view?
      VfSU doesn't support parallel view. But if you set the SU camera to as near zero degree AOV it's pretty much the same - and that does work.
        dtrarch
        Camera tools error.jpgTT
        Latest .rbs Lib2 and Vray tools installed
        Shows up in menu and icons
        Shows this error message ?
        Camera Tools just a black screen.
        SU 8 Pro latest Version
        dtr
        • H
          hspaht
          How does this work? Where are the tools that come with the plugin?
            @dtrarch said:
            [attachment=0:1w8aqvsn]<!-- ia0 -->Camera tools error.jpg<!-- ia0 -->[/attachment:1w8aqvsn]TT
            dtr
            What Internet Explorer version do you have?
            (Can you fill out your profile information about your system? Makes it easier when answering questions.)
              A toolbar and menus under Plugins.
              • T
                tskoog20
                No. I can't open it in my downloads file .......I open .rb all the time when I'm installing plugins but I can't open .rbx for some reason?
                  Install RBZ files using the Install Extension feature of SketchUp 8.
                  General guide on installing plugins: http://www.thomthom.net/thoughts/2012/01/installing-plugins-for-google-sketchup/
                    dtrarch
                    TT
                    I use Firefox not IE which is not installed.
                    Will re-install and check.
                    I'll bet that is the problem.
                    Thx
                    dtr
                      What browser you use is not relevant. Internet Explorer always exist in some form in Windows.
                      There is Internet Explorer the engine - webdialogs use it, .CHM help files use it, lots of applications use it in some form. It's an embedded version of IE.
                      So, regardless of what web browser you use, keep Internet Explorer up to date as there is much more software that makes use of the IE engine.
                        dtrarch
                        TT
                        I had removed/scrubbed IE off my system
                        IE 10 now installed
                        Error still persists.
                        Is there a SU2Vray script that needs to be installed?
                        Thank you for giving this your attention.
                        dtr
                          No, only thing that should be needed is this plugins and TT_Lib2. It's a very strange error you're getting. I've never seen it before.
                          Maybe it's some setting on your computer?
                          Can you fill out your system info in your profile, please?
                            dtrarch
                            dtr sys specs.jpgTT
                            System specs attached
                            SU 8 UPD PRO
                            I moved all the plugins not for this script to a temp hold folder.
                            Same error
                            Thanks again for checking this out.
                            Please do not make this a big project.
                            dtr
                              Could it be... there are some files in your VirtualStore?
                              This utility might help you check: http://sketchucation.com/forums/viewtopic.php?f=180&t=48399
                                dtrarch
                                TT
                                I have BU SSD for boot and apps.
                                Something on my current disk is just sideways.
                                The script runs perfectly on the BU drive.
                                Sorry to cause all the fuss.
                                Just a case of computer hell.
                                Thanks for all your good natured help 👍 👍
                                Dave
                                  Glad it works - somehow. :s
                                  Did you check the VirtualStore?
                                  • P
                                    penumbra
                                    Thomas
                                    I get the attached error after install. any thoughts?
                                      dtrarch
                                      TT
                                      Yes I did run the Virtual Store and error still there.
                                      Could be a root kit or such but OK now.
                                      Thx 👍
                                      dtr
                                      • P
                                        penumbra
                                        TT
                                        never mind about my issue. deleting the old TTLib and tantalizing the new one seem to get rid of the issue.
                                        Omar
                                          Milunice259
                                          I have the same error like him. Anybody help!!
                                            Very little I can do without any further info.
                                            And as you can see in the previous post, penumbra solved it by uninstalling TT_Lib2 and then installing it again.
                                            • 11
                                            • 12
                                            • 7 / 12
