    [Plugin] V-Ray Tools
    238 Posts 80 Posters 295.0k Views 80 Watching
      hmm... I'm trying this plugin for the first time... it sort of works, but when using 'Start V-ray', the toolbar doesn't show up. The editors, such as material editor etc, work fine when approached via the plugin/Vray menu, it's only the toolbar that doesn't show up.
      That's odd - don't know why the toolbar doesn't show... ๐Ÿ˜•
      It's been a while since this thread was active... is the plugin still up to date?
      I have version 2 on my computer. Along with this plugin I also have a few other updates due for release after I release Vertex Tools 1.1 in a couple of weeks.
        CharlieBarr
        Hi!
        Donยดt know if this thread is alive anymore but... Iยดm having troubles using the plugin together with the "photo match" tools in SU. When I add the values suggested by the "Camera sync" plugin the render stills turn out weird (V-ray just render a small part of the actual view).
        Iยดve tried searching for a thread on this problem but with no luck.
        Thanks alot for sharing your excellent plugins with us!
        /Charlie
        • pilgerP Offline
          pilger
          I believe SU version 8.0.16846 broke this plugin. I type in the aspect ratio on the box and I can see the grey frame on my viewport but the V-Ray zoom indicator doesn't change at all.
            What was your previous version? Nothing in SketchUp 8.0.16846 should have affected the API it uses.
            Any errors in the Ruby Console?
            Also, what OS do you use? (Please add your info in your profile.)
            Btw, I have version 2.0 ready to be release very shortly.
            • pilgerP Offline
              pilger
              Nothing comes up on the Ruby console. No errors or other messages.
              I'm on Windows 7 x64 Ultimate edition.
              Despite of the not changing field, the aspect of the viewport seems to be changed. I can get the ratio correctly on the "Output" tab of V-Ray. I tried rendering with just the aspect ratio of the Output matching the SU's (left the Zoom field of V-Ray unaltered: 1.00 ) and it kinda worked as expected.
              Maybe we don't need to mess with the zoom anymore? Can you confirm that, Thom?
                Yes, with the newer VfS it's no longer needed to set the zoom. It'll all be clearer when I release version 2.0.
                  projectimagi
                  ๐Ÿ˜ yes..thank you..
                    Version 2.0.0
                    • Removed the Sync Camera feature. V-Ray for SketchUp should now correctly match the SketchUp viewport.
                    • Added "Purge V-Ray Materials" for removing V-Ray data from materials.
                    • Added "Use as Material Override"
                    • Added "Reset Camera Aspect"
                    • Aspect Ratio and Export Safeframe is now merged into one dialog.
                    • Adjusting aspect ratio tried to compensate for viewport "jumping". (Not perfect in all cases)
                    • Added "Recreate Scene" to rebuild photomatch scenes as normal scenes.
                    • Bug fixes.
                    • andybotA Offline
                      andybot
                      Woohoo! Nice job thomthom ๐Ÿ˜„ All very useful things ๐Ÿ‘
                      • F Offline
                        frippe1968
                        Hi thomthom,
                        This sounds exactly like what I'm looking for (having issues with 2-point perspectives in Vray not matching SU) - do I need to do anything special with the .rz file? I just copied it into my SU plug ins folder but it seems nothing happened. Will I get a new tool bar or something the drop-down menu?
                        Thanks so much.
                          V-Ray doesn't support 2pt perspectives. This plugins cannot fix that.
                          To install RBZ files you need to use the Install Extension feature in SketchUp.
                          Installation Guide: http://www.thomthom.net/thoughts/2012/01/installing-plugins-for-google-sketchup/
                            tskoog20
                            I'm super excited about this plugin!........but the file isn't opening on my mac?!?
                              When you say "opening", what do you mean then? Are you using the Install Extension feature in SketchUp? ( see link in post above )
                              Sent from my LT15i using Tapatalk 2
                                segal91
                                whats about rendering elevations in parallel view?
                                  VfSU doesn't support parallel view. But if you set the SU camera to as near zero degree AOV it's pretty much the same - and that does work.
                                    dtrarch
                                    Camera tools error.jpgTT
                                    Latest .rbs Lib2 and Vray tools installed
                                    Shows up in menu and icons
                                    Shows this error message ?
                                    Camera Tools just a black screen.
                                    SU 8 Pro latest Version
                                    dtr
                                    • H Offline
                                      hspaht
                                      How does this work? Where are the tools that come with the plugin?
                                        @dtrarch said:
                                        [attachment=0:1w8aqvsn]<!-- ia0 -->Camera tools error.jpg<!-- ia0 -->[/attachment:1w8aqvsn]TT
                                        dtr
                                        What Internet Explorer version do you have?
                                        (Can you fill out your profile information about your system? Makes it easier when answering questions.)
                                          A toolbar and menus under Plugins.
                                            tskoog20
                                            No. I can't open it in my downloads file .......I open .rb all the time when I'm installing plugins but I can't open .rbx for some reason?
                                            • 11
                                            • 12
                                            • 7 / 12
