    Screen capture and aspect ratio
    16 Posts 7 Posters 1.8k Views 7 Watching
      You can use V-Ray Tools. You don't need V-Ray to use it, but you can use the feature which sets the aspect ratio and the export feature.
      http://sketchucation.com/forums/download/file.php?id=102012
      • K
        ktgeary
        I tried the Vray tools this worked great for setting the aspect ratio, thanks. However the export safeframe did not allow me to select a file type and I received the error "failed to save image" . any thoughts? Thanks for the help.
          You need to manually type the file format. It's due to a bug in the SketchUp API.
          • K
            ktgeary
            rock on. works great, thanks for the help.
              miikka1978
              I also tried to use VRAY tools but I get error message: "Invalid Control Type: TT:GUI::Groupbox"
              Do you have idea what could be the problem? I already updated the TT_Lib to TT_Lib2 - 2.7.1.rbz.
                Tt_lib2 doesnt replace Tt_lib 1.
                Not sure why you get that error. Never had that before. Is that the full error? Are you sure you installed everything correctly?
                  miikka1978
                  Thanks for helping me with this thomthom. I reinstalled both:
                  TT_Lib (1.2.0) — 31 August 2010
                  TT_Lib² (2.7.1) — 19 February 2013
                  But, I still get the same message as earlier. When I close the message (window) I also get this error message. Maybe it explains the problem a little better.
                  http://i.imgur.com/SfPP3dA.jpg
                    I'd need more info about your system. (Can you please fill this out in your profile as well?)
                    What is your Windows version?
                    What is your Internet Explorer version?
                    It also appear that you have activated debug messages for embedded browser controls - which is unusual...
                      dtrarch
                      TT
                      Will this work if using Firefox not MS IE?
                      dtr
                        driven
                        @dtrarch said:
                        TT
                        dtr
                        SketchUp can't use Firefox only MS IE on PC or WebKit on mac.
                        it's part of the program, not selectable...
                          miikka1978
                          I am sorry that I have not answered earlier for this clarification request!
                          My Windows: Windows 7 Home Premium version 6.1
                          My Internet Explorer: 9.0.8112.16421
                            sp33d1984
                            I have this same problem.
                              Either you have an old version of TT_Lib2 - or you have an outdated IE. (I think it's an outdated TT_Lib2 you have.)
