    I invite for acquaintance with Russian plug-in
    77 Posts 18 Posters 26.7k Views 18 Watching
    • FrederikF Offline
      Frederik
      Looks like a very interesting plugin... πŸ‘
      Unfortunately I seem to share the same issue as Ken...
      I've never had any issue installing a plugin - before now... πŸ˜•
      I even tried to copy the iconv.so to the plugins folder, but to no avail... 😐
      Cheers
      Kim Frederik
      • FrederikF Offline
        Frederik
        OK... Tried to see if I could see something in the coolpipe_Start.rb
        (yep - it's dangerous when having a very limited knowledge when it comes to coding... πŸ˜† )
        The original code looked like this:
        #encoding; utf-8
        # Cool Pipe Engine 2011-2012
        # Cool Pipe Engine 2011-2012 to the SketchUp interface
        # version 1.2
        # Software Author;     Borisov Denis Vladimirovich (yad2000@rambler.ru)
        # Design;              Borisov Denis Vladimirovich (yad2000@rambler.ru)
        # Β©2012 by Borisov Denis Vladimirovich (yad2000@rambler.ru)
        #Π˜ΡΡ‚ΠΎΡ€ΠΈΡ вСрсий
        #-v1.2.1
        #-ΠœΡƒΠ»ΡŒΡ‚ΠΈΡΠ·Ρ‹Ρ‡Π½ΠΎΡΡ‚ΡŒ ΠΏΡ€ΠΎΠ΅ΠΊΡ‚Π° (русский,английский,французский,ΠΈΡ‚Π°Π»ΡŒΡΠ½ΡΠΊΠΈΠΉ,испанский,Π½Π΅ΠΌΠ΅Ρ†ΠΊΠΈΠΉ), Π²ΠΎΠ·ΠΌΠΎΠΆΠ½ΠΎΡΡ‚ΡŒ Π²Ρ‹Π±ΠΎΡ€Π° языка Π² процСссС Ρ€Π°Π±ΠΎΡ‚Ρ‹ с ΠΏΠ»Π°Π³ΠΈΠ½ΠΎΠΌ
        #-РасчСт массы ΠΎΡ‚Π²ΠΎΠ΄Π° (ΡΡ‚Π°Π»ΡŒΠ½ΠΎΠ³ΠΎ), расчитыватСся ΠΏΠΎ гСомСтричСским ΠΏΠ°Ρ€Π°ΠΌΠ΅Ρ‚Ρ€Π°ΠΌ (ΠΌΠΎΠΆΠ΅Ρ‚ Π½Π΅ ΡΠΎΠΎΡ‚Π²Π΅Ρ‚ΡΡ‚Π²ΠΎΠ²Π°Ρ‚ΡŒ с заводским издСлиям)
        #-Π‘Ρ‚Ρ€ΡƒΠΊΡ‚ΡƒΡ€Π° ΠΊΠΎΠ΄Π° ΠΈΠ·ΠΌΠ΅Π½Π΅Π½Π΅Π½Π°; отсутствуСт ΠΈΠ·ΠΌΠ΅Π½Π΅Π½ΠΈΠ΅ стандартных классов, вСсь ΠΊΠΎΠ΄ объСдинСн Π² классы ΠΈ ΠΌΠΎΠ΄ΡƒΠ»ΠΈ
        #-внСсСно исправлСниС ΠΏΠΎ Π·Π°Π³Ρ€ΡƒΠ·ΠΊΠ΅ iconv.so; Π½Π° MAC Π½Π΅ Π·Π°Π³Ρ€ΡƒΠΆΠ°Ρ‚ΡŒ, Ρ‚ΠΎΠ»ΡŒΠΊΠΎ Π½Π° Windows
        #-Ρ€Π΅Π΄Π°ΠΊΡ‚ΠΈΡ€ΠΎΠ²Π°Π½ΠΈΠ΅ элСмСнтов вынСсСно Π·Π° ΠΏΡ€Π΅Π΄Π΅Π»Ρ‹ Observer ΠΏΡ€ΠΈ Π²Ρ‹Π΄Π΅Π»Π΅Π½ΠΈΠΈ Π½Π° ΠΎΡ‚Π΄Π΅Π»ΡŒΠ½ΡƒΡŽ ΠΊΠΎΠΌΠ°Π½Π΄Π½ΡƒΡŽ ΠΊΠ½ΠΎΠΏΠΊΡƒ
        #-исправлСн ΠΏΡ€ΠΈΠ½Ρ†ΠΈΠΏ сортировки элСмСнтов спСцификации Π½Π° стандартный .sort (для избСТания ΡƒΡ‚Π΅Ρ‡ΠΊΠΈ памяти Π² процСссС подсчСта ΠΈ зависаний SketchUP)
        #-v1.2
        #-ИзмСнСниС структуры Ρ€Π°Π±ΠΎΡ‚Ρ‹ с Π±Π°Π·ΠΎΠΉ Π΄Π°Π½Π½Ρ‹Ρ… элСмСнтов
        #-РисованиС ΠΈ Ρ€Π΅Π΄Π°ΠΊΡ‚ΠΈΡ€ΠΎΠ²Π°Π½ΠΈΠ΅ Ρ‚Ρ€ΡƒΠ±ΠΎΠΏΡ€ΠΎΠ²ΠΎΠ΄ΠΎΠ²
        #-РисованиС ΠΈ Ρ€Π΅Π΄Π°ΠΊΡ‚ΠΈΡ€ΠΎΠ²Π°Π½ΠΈΠ΅ ΠΎΡ‚Π²ΠΎΠ΄ΠΎΠ²
        #-РисованиС ΠΈ Ρ€Π΅Π΄Π°ΠΊΡ‚ΠΈΡ€ΠΎΠ²Π°Π½ΠΈΠ΅ ΠΏΠ΅Ρ€Π΅Ρ…ΠΎΠ΄ΠΎΠ²
        #-РисованиС ΠΈ Ρ€Π΅Π΄Π°ΠΊΡ‚ΠΈΡ€ΠΎΠ²Π°Π½ΠΈΠ΅ Ρ‚Ρ€ΠΎΠΉΠ½ΠΈΠΊΠΎΠ²
        #-РисованиС Π·Π°Π³Π»ΡƒΡˆΠ΅ΠΊ
        #-РисованиС Ρ„Π»Π°Π½Ρ†Π΅Π²
        #-Π‘ΠΎΠ·Π΄Π°Π½ΠΈΠ΅ спСцификации
        #-Ѐункция копирования свойств (слой+ΠΌΠ°Ρ‚Π΅Ρ€ΠΈΠ°Π») для ΠΎΠ±ΡŠΠ΅ΠΊΡ‚ΠΎΠ² CoolPipe ΠΈ Π³Ρ€ΡƒΠΏΠΏ
        #v1.1
        #-Π‘Π»Π΅Π΄ΡƒΡŽΡ‰ΠΈΠ΅ ΠΏΡƒΠ±Π»ΠΈΠΊΠ°Ρ†ΠΈΠΈ ΠΏΠΎ адрСсу; http://coolpipe.ru/load
        #-ΠšΠ°Ρ€Π΄ΠΈΠ½Π°Π»ΡŒΠ½ΠΎ ΠΈΠ·ΠΌΠ΅Π½Π΅Π½ Π΄ΠΈΠ·Π°ΠΉΠ½ Π΄ΠΈΠ°Π»ΠΎΠ³Π° с ΠΏΠΎΠ»ΡŒΠ·ΠΎΠ²Π°Ρ‚Π΅Π»Π΅ΠΌ
        #-Π”ΠΎΠΏΠΎΠ»Π½Π΅Π½Π° Π±Π°Π·Π° Π“ΠžΠ‘Π’ΠΎΠ² Ρ‚Ρ€ΡƒΠ±ΠΎΠΏΡ€ΠΎΠ²ΠΎΠ΄ΠΎΠ²
        #-РисованиС Ρ‚Ρ€ΡƒΠ±ΠΎΠΏΡ€ΠΎΠ²ΠΎΠ΄ΠΎΠ² ΠΌΡ‹ΡˆΡŒΡŽ
        #-НакладываниС слоСв, собствСнный Ρ€Π΅Π΄Π°ΠΊΡ‚ΠΎΡ€ "быстрых" слоСв
        #-НакладываниС ΠΌΠ°Ρ‚Π΅Ρ€ΠΈΠ°Π»ΠΎΠ² (боСвая раскраска Ρ‚Ρ€ΡƒΠ±ΠΎΠΏΡ€ΠΎΠ²ΠΎΠ΄ΠΎΠ²)
        #-НакладываниС тСплоизоляции + Ρ€Π΅Π΄Π°ΠΊΡ‚ΠΎΡ€ стандартных Ρ‚ΠΎΠ»Ρ‰ΠΈΠ½ изоляции
        #-Ѐункция "ΠŸΡ€ΠΈΠ»Π΅ΠΏΠΈΡ‚ΡŒ ΠΎΡ‚Π²ΠΎΠ΄"
        #-Π€ΡƒΠ½ΠΊΡ†ΠΈΠΈ рСдактирования Ρ‚Ρ€ΡƒΠ±ΠΎΠΏΡ€ΠΎΠ²ΠΎΠ΄ΠΎΠ² (Π·Π°Π΄Π°Π½ΠΈΠ΅ ΡƒΠΊΠ»ΠΎΠ½Π° ΠΈΠ»ΠΈ ΠΎΡ‚ΠΌΠ΅Ρ‚ΠΎΠΊ Ρ‚Ρ€ΡƒΠ±ΠΎΠΏΡ€ΠΎΠ²ΠΎΠ΄Π°)
        #-Π€ΡƒΠ½ΠΊΡ†ΠΈΠΈ рСдактирования ΠΎΡ‚Π²ΠΎΠ΄ΠΎΠ² ΠΏΡ€ΠΈ Π²Ρ‹Π΄Π΅Π»Π΅Π½ΠΈΠΈ самих ΠΎΡ‚Π²ΠΎΠ΄ΠΎΠ² ΠΌΡ‹ΡˆΡŒΡŽ (экранноС мСню)
        #-Ѐункция "БоставлСниС спСцификации"
        #--Ρ€Π°Π·Ρ€Π°Π±ΠΎΡ‚ΠΊΠ° ΠΏΡ€Π΅Ρ€Π²Π°Π½Π°
        #v1.0
        #ΠŸΡ€ΠΎΠ±Π½Ρ‹ΠΉ ΠΏΠ»Π°Π³ΠΈΠ½ (Π² Π²ΠΈΠ΄Π΅ Ρ‚ΡƒΠ»Π±Π°Ρ€Π°) Ρ€ΠΈΡΡƒΡŽΡ‰ΠΈΠΉ Ρ‚Ρ€ΡƒΠ±Ρ‹, ΠΎΡ‚Π²ΠΎΠ΄Ρ‹, ΠΏΠ΅Ρ€Π΅Ρ…ΠΎΠ΄Ρ‹, Ρ‚Ρ€ΠΎΠΉΠ½ΠΈΠΊΠΈ, Π·Π°Π³Π»ΡƒΡˆΠΊΠΈ, Ρ„Π»Π°Π½Ρ†Ρ‹ ΠΏΠΎ извСстным Π“ΠžΠ‘Π’Π°ΠΌ
        #ΠŸΠ΅Ρ€Π²Π°Ρ публикация ΠΏΠΎ адрСсу; http://forum.abok.ru/index.php?&showtopic=30806&st=160
        require 'sketchup.rb'
        require 'CoolPipe/cp_Lang.rb'
        require 'CoolPipe/Service_proc.rb'
        require 'CoolPipe/PipeTool.rb'
        require 'CoolPipe/ElbowTool.rb'
        require 'CoolPipe/ReducerTool.rb'
        require 'CoolPipe/TeeTool.rb'
        require 'CoolPipe/CapTool.rb'
        require 'CoolPipe/FlangeTool.rb'
        require 'CoolPipe/cpCSVBase.rb'
        require 'CoolPipe/CopyOptionsTool.rb'
        pform = (Object;;RUBY_PLATFORM =~ /mswin/i) ? ;windows ; ((Object;;RUBY_PLATFORM =~ /darwin/i) ? ;mac ; ;other)
        platform = pform.to_s
        if platform == "windows"
          require 'CoolPipe/iconv.so' #  примСняСм iconv
        elsif platform == "mac"
           #  Π½Π΅ примСняСм
        CoolPipe_number_version = "1.2.1" # ВСкущая вСрсия ΠΏΠ»Π°Π³ΠΈΠ½Π°
        coolpipe_plugin = CoolPipePluginApp.new
        coolpipe_plugin.run
        So I deleted the two spaces in line 62 in front of "require"
        Now I get this Load Error message:
        Cheers
        Kim Frederik
        • yorik1984Y Offline
          yorik1984
          Copy iconv.co to C:\Windows\system32
          • Dan RathbunD Offline
            Dan Rathbun
            @yorik1984 said:
            Copy iconv.so to C:\Windows\system32
            NO.. DO NOT !
            It does not belong in the OS system directory !
            I'm not here much anymore.
              yorik1984
                 #  Π½Π΅ примСняСм
              Frederik has WINDOWS!
                driven
                and Dan is saying "DON'T" move the file into the C:\Windows\system32 system path, it won't be found and doesn't belong there...
                @ Fredrick if you suspect the require is not working test it in 'Ruby Console'. e.g.
                should return windows
                then try
                   #  Π½Π΅ примСняСм
                should return true
                if it does it's not the problem, if it doesn't, check permissions on that file... 'CoolPipe/iconv.so' in that Directory, don't move it...
                • FrederikF Offline
                  Frederik
                  Thanks for the heads up...
                  Much appreciated... πŸ‘
                  I don't dare to copy any files into the C:\Windows\System32 folder...
                  It seem strange that I would need to copy a file to a OS system folder... 😐
                  From the videos this plugin looks very interesting...
                  I'm working as Project Manager and my job is to make 2D and 3D drawings, mechanical design, building design, surface calculation, volume calculation, walk through in buildings, equipment layout in control/engineering rooms, piping design, piping and equipment support design, of the cooling systems we're going to be working on...
                  On a daily basis I'm using the 3skeng plugin, which suits my needs well...
                  Since this is also related to the piping industry I wanted to check it out, but as long as I can't get it to work, I will stick to the 3skeng plugin... πŸ˜‰
                  Cheers
                  Kim Frederik
                  • FrederikF Offline
                    Frederik
                    It sure does...
                    @driven said:
                    then try
                    >    #  Π½Π΅ примСняСм
                    > end
                    should return true
                    A bit strange...
                    It seem to only allow me to write
                    I don't seem to be able to insert the remaining text... πŸ˜•
                    Cheers
                    Kim Frederik
                      driven
                      @frederik said:
                      I don't seem to be able to insert the remaining text... :?
                      I think that's the windows single line 'Ruby Console' thing... mac is multiline, and mines actually full page as well, sorry..
                      just use the require and see if it returns true
                      might need the rest of path if nothing else has loaded..
                        driven
                        I think single line looks like this
                        if platform == "windows"; require 'CoolPipe/iconv.so'; elsif platform == "mac";  end
                        but I never need it so... john
                        • FrederikF Offline
                          Frederik
                          Cheers, John...!
                          I believe I will just leave it as is for the time being...
                          Like I wrote I don't like to copy anything to any system folder, so until they come up with an alternative plugin, I will stick to 3skeng... πŸ˜„
                          Cheers
                          Kim Frederik
                          • kenK Offline
                            ken
                            I have tried each and every suggestion trying to get this plugin to work. The error is the same, can not find iconv.so.
                            Is there anyone that has this plugin working on a Windows machine?
                            And if you do have it working on a Windows machine, what size is your iconv.so. My iconv.so file is 24661 Date 2008-08-12-14:18.
                            I can't believe it is so hard to get this plugin to work.
                            Anyway thanks in advance. I am surprised the author doesn't offer any help.
                            Ken
                              driven
                              @Ken & @Fredrick,
                              I had a look on the russian forum the authors reply to your issue is
                              Has already been written about it many times. Find the folder with the plugin file iconv.dll and throw it in the folder πŸ˜„ \ Windows \ System32 without this dll can not run so .... and no magic
                              I don't know windows at all, but he is saying to move the iconv.dll not the iconv.so as suggested in this thread.
                              I don't know if adding .dll is wise, maybe dan will comment...
                                Dan Rathbun
                                Is there anyone that has this plugin working on a Windows machine? ... I can't believe it is so hard to get this plugin to work.
                                This plugin (in it's current state,) needs to go on the Plugins Quarantine list !
                                It needs a major overhaul.
                                ANY compiled Ruby binary file used, should match the Ruby version and platform of the currently loaded Ruby interpreter.
                                So.. it is a BAD IDEA to distribute so ("shared object",) dll ("dynamic linked library",) or any binary files WITH PLUGINS.
                                Users should just install the PROPER full Ruby edition, and use a load path script to push the paths to the standard Ruby library directories, into the global array $LOAD_PATH, which is used by the global methods load() and require() to find external files.
                                On SketchUp v 8.x PC this is Ruby v1.8.6-p287
                                Ruby v1.8.6-p287 Windows One-Click Installer
                                THEN ... after the above is done, the call to load the PROPER iconv.so file, from the platform specific sub-dir ("/i386-mswin32"), of the standard Ruby lib dir, .. is simply:
                                require("iconv")
                                (The line " Sketchup::require 'CoolPipe/iconv.so'" about 13th in "coolpipe_Start.rb" needs to change.)
                                He is Russian and does not speak English.
                                He likely does not read English, and cannot read the Programming Ruby book, because his code violates many rules and corrupts the SketchUp Ruby environment.
                                Sorry .. avoid using this plugin until it is fixed.
                                πŸ€“
                                • kenK Offline
                                  ken
                                  Dan
                                  Thank you. There for awhile I just assumed I was the only one having trouble.
                                  So thanks for taking the time to answer my request.
                                  Ken
                                    Stephlez
                                    I am trying to use this plugin, i followed the 3 steps installation on their site:
                                    1. unzip the file to a folder Plugins installed SketchUp
                                    2. Copy the file iconv.dll to the System32 folder or SysWoW64
                                    3. Reboot
                                      It loads without errors. However it seems i am not getting any pipe models from the database (database looks empty)
                                      Se7ven
                                      From his site it seems that he will very soon be releasing version 2.0.
                                        djRuska
                                        Made with Cool Pipe 1.2.1 http://www.youtube.com/watch?v=Jdv3r-yRntM
                                          driven
                                          @djRustka
                                          that is a lot of very cool coolPipe...
                                          • utilerU Offline
                                            utiler
                                            Very nice work!! How do you do that shy in SketchUp...?
                                            Just Curious...
                                            • 4 / 4
