    [Plugin] QuadFaceTools
    673 Posts 116 Posters 524.6k Views 116 Watching
      driven
      @daforum said:
      ah, now it's there πŸ™‚
      out of curiosity...
      do you use a 'Finder' enhancer/manager of any sort?
      I have found 'sometimes' I need to update 'Finder' before newly added files can be accessed.
      Turning your mac off overnight would have refreshed 'Finder'...
      • daforumD Offline
        daforum
        Oops, sorry for the confusion. I meant about my Profile details on the left.
        When I filled in my Profile details they didn't appear, then when I went back to this thread my details had updated and appeared.
        Will have a go at the Code pasting as suggested earlier.
        • daforumD Offline
          daforum
          This is what I got when i pasted: $LOADED_FEATURES.join("\n")
          langhandler.rb
          sketchup.rb
          3d_grid.rb
          [CASF]FunShapes.rb
          arcs.rb
          balustrade.rb
          bezier.rb
          box_pos.rb
          boxes_random.rb
          cleanuplines.rb
          cloud_v6.rb
          ContourMaker.rb
          cratetool.rb
          creat360view.rb
          cylinder.rb
          dashes.rb
          dat_importer1.rb
          edge-coplanar.rb
          deleteCoplanar.rb
          delfaces.rb
          DoorMaker.rb
          doortools/doortoolright.rb
          doortools/doortoolleft.rb
          doortools/3PointTool.rb
          doortools/doortoolframe.rb
          doortools/doortooltrim.rb
          doortools/doortoolmullion.rb
          doortools/doortoollouver.rb
          doortools/doortoolglass.rb
          DoorTools.rb
          drawhelix13.rb
          drop.rb
          Sketchup.rb
          Engraver.rb
          extensions.rb
          LangHandler.rb
          examples/box.rb
          examples/selection.rb
          examples/contextmenu.rb
          examples/linetool.rb
          examples/animation.rb
          examples/attributes.rb
          examples/exampleScripts.rb
          examples.rb
          extend11.rb
          extrud_selected_faces_along_normal.rb
          extrude_lines.rb
          ExtrudeAlongPath.rb
          extrudelinetool.rb
          FilletTool.rb
          flattery/utils.rb
          flattery/unfoldtool.rb
          flattery/edgepairs.rb
          flattery/reunitetool.rb
          flattery/tabtool.rb
          flattery/svgexport.rb
          flattery/toolbar.rb
          flattery.rb
          flightpath.rb
          fur_en.rb
          Geodesic_SketchUp.rb
          Grow.rb
          heightfield_generator.rb
          ./offset.rb
          holes.rb
          housetool01.rb
          import_from_folder.rb
          jf_sine_wave.rb
          joisttool.rb
          kitchen.rb
          label_stray_lines.rb
          lathe.rb
          Latticeizer.rb
          linetool.rb
          lsystem.rb
          lwo_export/export.rb
          lwo_export.rb
          progressbar.rb
          makefaces.rb
          mesh_additions.rb
          Mirror.rb
          model_location.rb
          normal_map_maker.rb
          obj_importer.rb
          OBJexporter.rb
          offset.rb
          orient_faces.rb
          parametric.rb
          parking.rb
          Pipe Tool v4.3.rb
          PipeAlongPath.rb
          protrude.rb
          pyramidtool.rb
          QuadsFrom2Tris.rb
          raftertool.rb
          random_lines.rb
          rectangle_hole.rb
          rot90.rb
          sceneExporter.rb
          shapes.rb
          SimplifyContours.rb
          SketchyBevel.rb
          skp_to_dxf.rb
          slabtool.rb
          stair_maker062.rb
          SteelSections.rb
          Stepping Stones.rb
          thicklines.rb
          tnt_bookshelf.rb
          tnt_StairConcTool.rb
          /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/TT_Lib2/arc.rb
          /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/TT_Lib2/attributes.rb
          /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/TT_Lib2/babelfish.rb
          TT_Lib2/geom3d.rb
          /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/TT_Lib2/bezier.rb
          /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/TT_Lib2/binary.rb
          /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/TT_Lib2/bounds.rb
          /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/TT_Lib2/color.rb
          /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/TT_Lib2/cursor.rb
          unfoldtool.rb
          Utilities/utilitiesTools.rb
          utilities.rb
          voxelizebeta04.rb
          vrobj_exporter.rb
          WindowGlass.rb
          windowizer.rb
          windows.rb
          xLine2Line.rb
          /Library/Application Support/Google SketchUp 7/SketchUp/Tools/sketchup.rb
          DynamicComponents/ruby/dcloader.rb
          dynamiccomponents.rb
          make_pano_pm.rb
          sandboxtools.rb
          • daforumD Offline
            daforum
            This is what I got when I pasted: $loaded_files.join("\n")
            sketchup.rb
            rp_spherical_helix
              driven
              disable Geodesic_SketchUp.rb by renaming it Geodesic_SketchUp.rb! and see if this works then. if so there is a safer version about...
              • daforumD Offline
                daforum
                Hi John,
                I renamed the Geodesic_Sketchup plugin and got this when Sketchup started:
                can't convert nil into StringError Loading File tt_quadface.rb
                I've installed QuadFaceTools - (0.7.0) Do I need an earlier version?
                  driven
                  I just installed it using rbz file and you seem to be missing the entire TT_QuadFaceTools Folder?
                    Could it be some permission problem?
                    • daforumD Offline
                      daforum
                      @driven said:
                      TT_QuadfaceTools folder is installed!
                      Please see attached png
                      • daforumD Offline
                        daforum
                        Oh well, if it's not working it's not working!
                        Thanks for your help guys with all suggestions. Time to move on πŸ˜„
                          You never replied to my questions to whether you'd checked the folder permissions...
                          • daforumD Offline
                            daforum
                            Hi thomthom,
                            I originally downloaded the .rbz file and renamed it to a .zip file and unzipped it.
                            It unzipped fine and the folder and .rb file I installed into my plugins folder without any problems.
                            I'm the administrator on my computer so there are no problems with permissions.
                            πŸ˜„
                              hmm..
                              I see you are using SketchUp 7 Free from your profile, why not SketchUp 8?
                              You could then use the RBZ installing feature - and there's lots of API fixes as well.
                                By the way - have you checked in the Extension list to make sure it's enabled?
                                • daforumD Offline
                                  daforum
                                  Yes, I had a look and it is ticked.
                                  Should i download the version you have v0.8.0, and do you recommend i update to TT_Lib2_v2.71 ?
                                    You can't download 0.8.0 - it's not released. It's what I am working on right now.
                                    You could try to update TT_Lib2 - but I'm not sure if it'll work. (to be honest, I don't understand why it fails to show at all.) Oh, you do know that the menus are under Tools - not Plugins?
                                    But for the sake of it, can you install SU8 and use the Install Extension feature? Just to see if that works?
                                    • daforumD Offline
                                      daforum
                                      I can see the TT lib2 folder (i greyed it so to highlight it in my Plugins folder)
                                      I have looked in the Tools section and it's not there.
                                      The problem i have is that I'm still on Mac OSX 10.4.11 and SU8 runs on 10.5+
                                      That's the reason I'm using SU7.
                                        Mra
                                        Hi, is the toolbar supported in 2013?
                                        I installed via the extension but it's not showing up even though its ticked?
                                        • jo-keJ Offline
                                          jo-ke
                                          I've got the same problem with my notebook. At the desktop PC the toolbar is shown.
                                          both win7
                                          http://www.zz7.de
                                            That's a bug in the first release of SketchUp 2013. There is a new versiono out that fixes this. Go to sketchup.com and download SketchUp again.
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 30 / 34
