    [Plugin] QuadFaceTools
    680 Posts 116 Posters 700.3k Views 116 Watching
    • daforumD Offline
      daforum
      Oops, sorry for the confusion. I meant about my Profile details on the left.
      When I filled in my Profile details they didn't appear, then when I went back to this thread my details had updated and appeared.
      Will have a go at the Code pasting as suggested earlier.
      • daforumD Offline
        daforum
        This is what I got when i pasted: $LOADED_FEATURES.join("\n")
        langhandler.rb
        sketchup.rb
        3d_grid.rb
        [CASF]FunShapes.rb
        arcs.rb
        balustrade.rb
        bezier.rb
        box_pos.rb
        boxes_random.rb
        cleanuplines.rb
        cloud_v6.rb
        ContourMaker.rb
        cratetool.rb
        creat360view.rb
        cylinder.rb
        dashes.rb
        dat_importer1.rb
        edge-coplanar.rb
        deleteCoplanar.rb
        delfaces.rb
        DoorMaker.rb
        doortools/doortoolright.rb
        doortools/doortoolleft.rb
        doortools/3PointTool.rb
        doortools/doortoolframe.rb
        doortools/doortooltrim.rb
        doortools/doortoolmullion.rb
        doortools/doortoollouver.rb
        doortools/doortoolglass.rb
        DoorTools.rb
        drawhelix13.rb
        drop.rb
        Sketchup.rb
        Engraver.rb
        extensions.rb
        LangHandler.rb
        examples/box.rb
        examples/selection.rb
        examples/contextmenu.rb
        examples/linetool.rb
        examples/animation.rb
        examples/attributes.rb
        examples/exampleScripts.rb
        examples.rb
        extend11.rb
        extrud_selected_faces_along_normal.rb
        extrude_lines.rb
        ExtrudeAlongPath.rb
        extrudelinetool.rb
        FilletTool.rb
        flattery/utils.rb
        flattery/unfoldtool.rb
        flattery/edgepairs.rb
        flattery/reunitetool.rb
        flattery/tabtool.rb
        flattery/svgexport.rb
        flattery/toolbar.rb
        flattery.rb
        flightpath.rb
        fur_en.rb
        Geodesic_SketchUp.rb
        Grow.rb
        heightfield_generator.rb
        ./offset.rb
        holes.rb
        housetool01.rb
        import_from_folder.rb
        jf_sine_wave.rb
        joisttool.rb
        kitchen.rb
        label_stray_lines.rb
        lathe.rb
        Latticeizer.rb
        linetool.rb
        lsystem.rb
        lwo_export/export.rb
        lwo_export.rb
        progressbar.rb
        makefaces.rb
        mesh_additions.rb
        Mirror.rb
        model_location.rb
        normal_map_maker.rb
        obj_importer.rb
        OBJexporter.rb
        offset.rb
        orient_faces.rb
        parametric.rb
        parking.rb
        Pipe Tool v4.3.rb
        PipeAlongPath.rb
        protrude.rb
        pyramidtool.rb
        QuadsFrom2Tris.rb
        raftertool.rb
        random_lines.rb
        rectangle_hole.rb
        rot90.rb
        sceneExporter.rb
        shapes.rb
        SimplifyContours.rb
        SketchyBevel.rb
        skp_to_dxf.rb
        slabtool.rb
        stair_maker062.rb
        SteelSections.rb
        Stepping Stones.rb
        thicklines.rb
        tnt_bookshelf.rb
        tnt_StairConcTool.rb
        /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/TT_Lib2/arc.rb
        /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/TT_Lib2/attributes.rb
        /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/TT_Lib2/babelfish.rb
        TT_Lib2/geom3d.rb
        /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/TT_Lib2/bezier.rb
        /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/TT_Lib2/binary.rb
        /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/TT_Lib2/bounds.rb
        /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/TT_Lib2/color.rb
        /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/TT_Lib2/cursor.rb
        unfoldtool.rb
        Utilities/utilitiesTools.rb
        utilities.rb
        voxelizebeta04.rb
        vrobj_exporter.rb
        WindowGlass.rb
        windowizer.rb
        windows.rb
        xLine2Line.rb
        /Library/Application Support/Google SketchUp 7/SketchUp/Tools/sketchup.rb
        DynamicComponents/ruby/dcloader.rb
        dynamiccomponents.rb
        make_pano_pm.rb
        sandboxtools.rb
        • daforumD Offline
          daforum
          This is what I got when I pasted: $loaded_files.join("\n")
          sketchup.rb
          rp_spherical_helix
            driven
            disable Geodesic_SketchUp.rb by renaming it Geodesic_SketchUp.rb! and see if this works then. if so there is a safer version about...
            • daforumD Offline
              daforum
              Hi John,
              I renamed the Geodesic_Sketchup plugin and got this when Sketchup started:
              can't convert nil into StringError Loading File tt_quadface.rb
              I've installed QuadFaceTools - (0.7.0) Do I need an earlier version?
                driven
                I just installed it using rbz file and you seem to be missing the entire TT_QuadFaceTools Folder?
                  Could it be some permission problem?
                  • daforumD Offline
                    daforum
                    @driven said:
                    TT_QuadfaceTools folder is installed!
                    Please see attached png
                    • daforumD Offline
                      daforum
                      Oh well, if it's not working it's not working!
                      Thanks for your help guys with all suggestions. Time to move on πŸ˜„
                        You never replied to my questions to whether you'd checked the folder permissions...
                        • daforumD Offline
                          daforum
                          Hi thomthom,
                          I originally downloaded the .rbz file and renamed it to a .zip file and unzipped it.
                          It unzipped fine and the folder and .rb file I installed into my plugins folder without any problems.
                          I'm the administrator on my computer so there are no problems with permissions.
                          πŸ˜„
                            hmm..
                            I see you are using SketchUp 7 Free from your profile, why not SketchUp 8?
                            You could then use the RBZ installing feature - and there's lots of API fixes as well.
                              By the way - have you checked in the Extension list to make sure it's enabled?
                              • daforumD Offline
                                daforum
                                Yes, I had a look and it is ticked.
                                Should i download the version you have v0.8.0, and do you recommend i update to TT_Lib2_v2.71 ?
                                  You can't download 0.8.0 - it's not released. It's what I am working on right now.
                                  You could try to update TT_Lib2 - but I'm not sure if it'll work. (to be honest, I don't understand why it fails to show at all.) Oh, you do know that the menus are under Tools - not Plugins?
                                  But for the sake of it, can you install SU8 and use the Install Extension feature? Just to see if that works?
                                  • daforumD Offline
                                    daforum
                                    I can see the TT lib2 folder (i greyed it so to highlight it in my Plugins folder)
                                    I have looked in the Tools section and it's not there.
                                    The problem i have is that I'm still on Mac OSX 10.4.11 and SU8 runs on 10.5+
                                    That's the reason I'm using SU7.
                                      Mra
                                      Hi, is the toolbar supported in 2013?
                                      I installed via the extension but it's not showing up even though its ticked?
                                      • jo-keJ Offline
                                        jo-ke
                                        I've got the same problem with my notebook. At the desktop PC the toolbar is shown.
                                        both win7
                                        http://www.zz7.de
                                          That's a bug in the first release of SketchUp 2013. There is a new versiono out that fixes this. Go to sketchup.com and download SketchUp again.
                                          • jo-keJ Offline
                                            jo-ke
                                            Can I overwrite the old version or should I reinstall everything new?
                                            http://www.zz7.de
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 33
                                            • 34
                                            • 16 / 34
