    Newbie_problem with trees
    13 Posts 5 Posters 500 Views 5 Watching
      decumano
      thanks for the answer... I tried to do what you say but this is what I found
      As you can see it's already .png with white space below..
      Where i'm wrong?
      • KrisidiousK Offline
        Krisidious
        when you save it you're using save for web instead of just save as. save for web will write in the back white. try just using save as and choosing png.
        By: Kristoff Rand
        • Chris FullmerC Offline
          What renderer are you using?
            decumano
            No, for sure, I saved in .png format. I really don't know why this is the result
            I'm using the Vray for sketchup
              Krisidious
              are they transparent in SketchUp before rendering in Vray? or are they white in SketchUp.
              By: Kristoff Rand
                I am not sure about the current version of V-ray but I remember you need(ed?) to use clip masks there as it can (could?) not use png transparency.
                A clip map ios a purely black and white version of your image where the visible parts are white and the invisible ("to-be") transparent parts are black.
                  decumano
                  For krisidious:
                  Yes, they are transparent before, 2 samples i did right now
                  For gaieus:
                  i know nothing about clip masks. This evening i will search on the web about it.
                  You said "purely black and white version of your image" i think you are talking about the single .png image of the leaf that i posted above
                  Thanks for the advices
                    Krisidious
                    I'm afraid this is going to be a VRay issue and I'm not going to be able to help.
                    By: Kristoff Rand
                      decumano
                      Yes, it works! I just used a black and white version in the "transparency" section.
                        πŸ‘
                        • N Offline
                          neshxy
                          In v-ray materials under diffuse just click on "Use color texture as transparency" and click preview of material. It should be transparent now if u are using png.
