Lines Not Showing
10 Posts 4 Posters 2.1k Views 4 Watching
    sgcrain
    HI All
    Something changed this morning and I can't figure out what I did.
    When I'm viewing my model with textures or shading the lines disappear.
    If I view the model in the hidden line, wireframe, back edges or x-ray
    view the view goes completely white. See the screenshots below.
    What did I do?
      sgcrain
      Also, when I zoom in or out the lines reappear but as soon as I stop zooming the line go away again.
        sgcrain
        OK. I've just noticed that if I open a new document and draw a line that it doesn't show up at all!
        Did I mistakenly change my line color or something?
          cotty
          Did you change your (standard) stile?
          my SketchUp gallery
            Steve, I'm wonder as Carsten is, if you changed the style for your model. If you turn off edges under Edit while in Hidden Line face style, everything will appear to disappear. Or did you change the line color to white?
            You might try to choose one of the default styles and see if that changes things.
              sgcrain
              Well, I just tried rebooting Sketchup for the second time and for some reason everything is fine now.
              I have no idea what happened. Thanks for responding though. All the best DaveR!!
                Weird.
                Best to you, too. Would love to chat on the phone sometime and see how things are going.
                  dukejazz
                  I think it was menu- view- edge style-edges was turn off
                    Or not that since restarting SketchUp took care of it. If it had been set as you say, it would have still been that way after reopening the file.
                      dukejazz
                      I re-read what you wrote and my ealier statment is wrong
                      the edge would switch on in going thou the
                      and in the hidden line, wireframe, back edges or x-ray
                      but
                      if profile were off
                      add hidden geometry were off
                      edges are made to guides or smooth
                      you will see what you stated sgcrain » Yesterday, 12:59 pm
                      if this not the case
                      A fast fix next time is using your undo's back beyon the problem
                      or restart another sketchup with out closeing the old
                      copy model or object to new
                      and
                      save old model and close old sketchup
                      in new
                      if it problem go's away it a style problem or state of sketchup
                      if it dosn't goes away its a material problem (transparcy on and style edge is by material)
                      now when you close the new it refresh reg back to before the old sketch up started
                      which is good
                      But
                      now if you alreadly closed sketchup before starting a 2rd sketchup
                      you can load a different model
                      or reload a new style
                      if the problem still their
                      maybe now you have to reinstall sketchup reg by reinstall sketchup
                      I which you did.
