    PNG transparency with SU styles
    16 Posts 5 Posters 1.0k Views 5 Watching
    • JoelM3DMJ
      JoelM3DM
      Thanks. One trick is to cut away all the border from a jpg and turn off transparency. That is what I want to do ... but the problem is cutting out the image from the background. It is possible and I have seen it done. Does anyone know how? - Joel
      || Joel Metzger 3D Modeling
      || story-shorts.net - Animation with SU
      • Chris FullmerC
        Yeah, you can use a software like illustrator to general lines around an image that is nicely cut out like that. Then export that linework as dwg linework and there you go, you have the shape all cut out with SU lines. Its not super simple and it takes time though, but its probably faster than drawing the linework by hand in SU.
        I thought TIG wrote a plugin to do this automatically, but I don't see it. I might have been thinking of his white to transparent plugin.
        Rick made a plugin for this. Its not free, but not terribly expensive if you don't have hundreds to do. You install the plugin and then he charges for each cutout you do. you have send the png to his server and it processes and sends it back very quickly. Might be worth looking into:
        File Not Found
        (www.smustard.com)
          TIG's Image Trimmer: http://sketchucation.com/forums/viewtopic.php?t=33445
          • Chris FullmerC
            Perfect, thanks Dave!
            • JoelM3DMJ
              JoelM3DM
              I'm not seeing it work. I select the image, choose Image Trimmer from Tools, but it does not trim off the transparent border pixels.
                Worked for me using TIG's Image Trimmer. try running the plugin with the Ruby console open and see if you get any messages. Go back to the thread and check to make sure you've got everything set up correctly.
                Mr Transparent (1).skp
                • GaieusG
                  This is actually a known bug ever since these sketchy styles were introduced in version 6. (Some older members may remember Tomsdesk's plant packs he has never been able to release due to this).
                  So indeed the only solution is to cut the components around and forget image transparency when sketchy styles are used.
                  • JoelM3DMJ
                    JoelM3DM
                    Hmmm, I am getting a greyed out image and no trimming. I have all the files parked in their correct places.
                    • Chris FullmerC
                      Did you open the ruby console and run the plugin? If so, please copy and paste errors (if any) back here to the forum.
                      Also, it did run the outline and trimming just fine. See how the sketchy lines in the background no longer overlap over the top of your character? So the trimming worked great. Now you just have to figure out why the .png is getting lost.
                        The PNG isn't lost. It just isn't being displayed.
                        Try setting the face style to Shaded With Texture. πŸ˜’
                        And it is indeed trimmed as Chris says The blue lines are the bounding box of the resulting component.
                        • Chris FullmerC
                          I'm not sure how TIG's plugin works. Have you tried just putting them all into a model and selecting them all and running his plugin? Is that possibly a workflow that his plugin allows?
                          • JoelM3DMJ
                            JoelM3DM
                            Ahh, Shaded with Texture is the answer! Silly me. Thank you.
