    [REQ] replace all similar groups with component
    23 Posts 7 Posters 2.3k Views 7 Watching
    • soloS
      @rich o brien said:
      Chris Fullmers Loose Geometry to groups to capture leaves
      There is such a plugin?
      SU 7
      http://dl.dropbox.com/u/1129899/test%20tree.skp
        Read Wyatt's tut as I told you already. It is the only way to do this.
        • soloS
          I'll do dat, funny how one only reads stuff that one has a need to know, I remember browsing that edition but not reading that tut as at the time I had no need for it, then one forgets about it.
          • Chris FullmerC
            Loose to Groups - First plugin I ever released I think. I import a LOT of building footprints from GIS or CAD data. Then I go through and push/pull them up to some random height that is approximately as tall as they should be. Then I'm left with hundreds of buildings that are ungrouped and very difficult to work with. So I made Loose 2 Groups.
            File Not Found
            (www.smustard.com)
            • soloS
              File Not Found
              (www.smustard.com)
              I have many leaves, I have left your script to run for ober an hour now, is this normal?
                How many?
                Use Vertex Tools or Count Faces to figure it out.
                I've seen 10,000 leaves take some time.....
                Sent from my iPad
                • EarthMoverE
                  EarthMover
                  Here's an option. Crude but fast. Using Chris's Components onto Faces plugin.
                  test tree_fix.skp
                  Content Creator at Skapeup
                  • soloS
                    That's what I'm talking about, I like the result, even though I plan to simplify the leaves not give more geometry with the circle. I could not increase size of the video to see what you clicked as it's blurry when in full screen mode, could you explain the steps?
                    • EarthMoverE
                      EarthMover
                      Try it on HD. Could be youtube was still processing it. Or click the "YouTube" link and it should link to the HD version.
                      It was simple.
                      Just select all faces and the one component.
                      Use Chris's plugin - components onto faces and use the "face groups" option. EDIT "Face Collections" not face groups.
                      Then I just selected the original faces with their edges and deleted them.
                      Adjusted the texture.
                      Should work for background trees. Problem is obviously the leaf direction being upside down on some of the leaves.
                      Working on trying to do something similar with an evermotion plant. I'll let you know if I find a better way.
                        As I have a very old computer and no many memory
                        I kill a big part of your leaves πŸ˜„
                        Then all explode them
                        Apply the snipset of Tig All Selection faces to components
                        And then Apply the Sdmitch Component replacement
                        (just don't forget to name the "Source" , and all components leaves "Target"
                        Seems works fine πŸ˜„
                        • sdmitchS
                          sdmitch
                          Solo, "This is deja vu all over again"
                          404 Not Found
                          (sketchucation.com)
                          Then like now, changing a group to a component didn't significantly reduce the size of the file. The only thing really gained is the ability to edit all instance at once.
                          http://sdmitch.blogspot.com/
                          • soloS
                            I thought I'd asked this before. That's the problem with getting old.
                            So what would be the best way to take a tree like in my sample and reducing or consolidating it to a point where it's light enough for SU yet detailed enough for rendering?
                              More leaves on one quad. Less quads.
                                And don't forget that the Sdmitch Plugin allow you to take several different components as "Source" for a better tree leaves simulation! πŸ€“
                                  TIG has also some snipsets for this sort of things πŸ˜‰
                                  (all codes must be on one line in the ruby console!!!
                                  Transform objects of a selection in components!
                                  m=Sketchup.active_model;
                                  m.start_operation("Faces>Compos");
                                  n=m.active_entities;m.selection.to_a.each{|e|(g=n.add_group(e.all_connected);
                                  g.to_component.definition.name="FaceSet#1")if e.valid? and e.parent==n.parent and e.class==Sketchup;;Face};
                                  m.commit_operation
                                  http://forum.zbrush.fr/index.php?PHPSESSID=4e825ae188c60774366f18ac0035054f&action=dlattach;topic=1622.0;attach=15209;image
                                  Tranform any faces in components
                                  m.selection.to_a.each{|e|(g=n.add_group(e);
                                  g.to_component.definition.name="Face#1")if e.class==Sketchup;;Face}
                                  http://forum.zbrush.fr/index.php?PHPSESSID=4e825ae188c60774366f18ac0035054f&action=dlattach;topic=1622.0;attach=15210;image
                                  all faces of a selection are transformed in groups
                                  (except groups or components yet existing)
                                  m=Sketchup.active_model;n=m.active_entities;m.selection.to_a.each{|e|n.add_group(e)if e.class==Sketchup;;Face};
                                  http://forum.zbrush.fr/index.php?PHPSESSID=4e825ae188c60774366f18ac0035054f&action=dlattach;topic=1622.0;attach=15211;image
                                  Ps For be complete
                                  Groups to Components by Thomthom
