Merge two surface
I have two surface like this:
This plugin could theoretically work:
http://sketchucation.com/forums/viewtopic.php?t=24676Now if you get a BugSplat instead of the desired result or how long it will take to process it if you do not splat, regarding the complexity of your surfaces, is completely unpredictable.
Hi Gai do you know a freware software to make this merge file.
If you must do a second file How to make this?
I want make a surface like a designe. -
That plugin is free.
What plug in ?
Can I have the link? -
The link was provided in Gai's first post to you. It links to a free plugin. Do you need more help getting that plugin?
Thank you sorry i m new but on the link i can see the video you have a little tutorial
And did you get the plugin itself?
Yes already installed but the example i can watch the tutorial video on the page
Do you mean you canNOT see the videos?
It appears those videos are no longer available.
I have selected the stl file .3ds and used the plug in thi is the error
I believe you must before launch the Plugin
Right CLick on each object / Make group -
