    Sketchup needs to be BIM
    46 Posts 19 Posters 8.3k Views 19 Watching
    • aadbuildA
      aadbuild
      Stay tuned I have an answer to all of your questions and more.
      Every building designed can be affordable & buildable, to help we built PlusSpec; VDC & BIM for Sketchup
      https://www.plusspec.com
      • utilerU
        utiler
        You're a tease!!!!!! 😍
        Just Curious...
          sonder
          I work with a local contractor that has a robotic plasma cutter. We designed several specific wood/steel connections solely in SU. I then exported .dxf files from SU for input in their plasma cutter software. It was remarkable how seamless the process was, and the results were nearly immediate - 3 days. I'll try to find some pics of the process, but it clearly represents the BIM capabilities already available in SU.
          • dcauldwellD
            dcauldwell
            The BIM thing has been intriguing me lately. One of the other (!) software companies has been pushing their software to create BIM models, but having watched their videos, I felt that SU could do most of what was required,i.e. 1) a 3d model 2) able to render from the model 3) using 3d components 4) extracting component information for estimating. It was only the last item that I found a bit flaky. (I know that there are timelines and facilities management stages, but that isn't necessary for my domestic work)
            For small, domestic projects a full-on BIM (using sophisticated layering conventions etc) seems way over the top, but it did occur to me that to assist the builder in pricing for the work, that I could lend a hand and extract areas and volumes of materials, lengths of beams etc, that a builder, without the benefit of the 3d model would otherwise have to prepare manually. The only danger is, me making an error!, so it does put the onus on me to double check the output. (most small builders don't have CAD software anyway, let alone a computer)
            I've just given this a try out on my last project, preparing "QUANTITIES of Main Elements
            (from model)" and with a hefty health warning about the data being to assist the builder etc. I will wait for feedback from the builder quoting for the work.
            Sketchup 2017
            (vray 2.00)
            • utilerU
              utiler
              That sounds neat, Nick... would love to see the process pics...!
              Just Curious...
                sonder
                The piece is a center steel knife plate with 8 plates. It is 54" in diameter. In the first video, that google released on my process, there is a small segment showing the model of this element.
                No shop drawings were prepared other than the SU model.
                Here it is freshly installed.
                http://i1358.photobucket.com/albums/q777/Sonder3/9bafd7e0fecadf125ba4705c8fa85215_zpsada61b2b.jpg
                • jeff hammondJ
                  are those 6x6s ?!
                    sonder
                    are those 6x6s ?!
                    They are 12x12's - 200 psf snow load. The structure is 18 feet in diameter - center point to center of segment of course πŸ˜‰
                      sonder
                      The element above is the top of a 3 story stair tower. Here it is finished (unfortunately the photographer couldn't easily capture the element, but it gives you a better idea of scale:
                      http://i1358.photobucket.com/albums/q777/Sonder3/Sonder376MartisCamp10_zpsf043af79.jpg
                      • jeff hammondJ
                        nice man
                        • daleD
                          dale
                          This reminds me of a connector I put together for a project a few years back for ridge and valley timbers over a log post. Didn't have the luxury of a plasma cutter though, so it was hand fabricated. It was pretty much mostly buried anyway but it made for an interesting structure. These kinds of details are fun to design.
                          • 3 / 3
