    [AppleScript] - Sketchup PrintRight
    75 Posts 7 Posters 8.3k Views 7 Watching
      driven
      jeff heres a sumac download link, dmg installerhttp://homepage.mac.com/johnboundy/filechute/sumac_dev_2011-03-01-002859.dmg.zip
      I need to go back out for an hour or so, I'll have another look at your stuff.
      What I see as being really good with what your trying is the idea...
      and you've cracked what can't be done from SU ruby.. i.e manipulate the window size and position the window.
      ruby can handle all the other bits really easily, without opening dialogs or console at all, it can even send the applescript to system and avoid an external file altogether.
      What I find interesting is the possibility of doing other things to other SU windows, so if you click a button, Applescript could get the position and pass that info to a ruby WebDialog that then appears in that spot, hiding the button in the process.
      In that WD you could say I want 8 A4 sheets of this drawing, size and zoom the window for accurate printing, and have ruby move camera, save and name image 8 times.
      more later
        driven
        Hey Jeff,
        lets bump this Applescript stuff and get more people in on the act...
        I've been re-reading all the SketchUp Applescript 'google' hits and I think it's time to make it all work.
        One of the past problems was no-one seemed to know how to get Applescript to do this sort of thing from INSIDE a ruby script... e.g. »» RUN IN AppleScript Editor
        activate application "Sketchup"
        tell application "System Events"
           tell process "SketchUp"
              click menu item "Weld" of menu "Plugins" of menu bar 1
           end tell
        end tell
        Although you could get other apps to run from SU using 'osascript' e.g. »» RUN IN Ruby Console
        `osascript -e 'activate application "Safari"'`
        Previously, as soon as you changed the app to SketchUp you beach-balled...
        well, I finally got it working e.g. »» RUN IN Ruby
        runAppleScript=Thread.new{
        `osascript <<EOF
        	end tell
        end tell
        EOF
        runAppleScript.kill
        the missing ingredient was a new Thread... and a HEREDOC to simplify the osascript
        so where does that all lead us?
        if it has a menu item you can activate it from ruby
        so if you have "Arc: Center and 2 points"
        #--# UI;;Toolbar why would you want a custom set of menu items?
          def aplscrpt_TB
          		aplscrpt_tb = UI;;Toolbar.new "aplscrpt_TB"
              # This command when clicked
              cmd = UI;;Command.new("aplscrpt_TB-Test") {
        				`osascript <<EOF
        							click menu item "Arc; Center and 2 points" of menu "Draw" of menu bar item "Draw" of menu bar 1
        						end tell
        					end tell
        				EOF
        	    runAppleScript.kill
          		aplscrpt_tb.add_item cmd
          		aplscrpt_tb.show
          end # aplscrpt_TB
        you can have a button even though it's an encrypted file...
        but there's even more we can do with this,
        I've worked out how to 'mine' the menu items, and how to 'activate' them from a ruby script, but I'm trying to optimise the parsing to html for use in a 'WebDialog'.
        The best way to explain my goal, is a floating 'localised', 'dynamic' menu/toolbar that can be edited (via option boxes) to show only the items you want, and be positioned anywhere, i.e. another monitor.
        I use full screen mode alot, and I find getting menu items is a pain. There are only so many shortcut keys I can remember...
        Another advantage is it can be 'Stay Open', eg. if you want to check all available camera views in advanced camera tools.
        I have made 'html' that looks like a menu, and others that look like toolbar buttons. but I need to full it all together.
        and then there's window positioning and sizing, a lot can be gain on using Applescripts strengths from inside ruby...
        @ Jeff, if you don't want the highjack, split this to a new thread, but I think it's as good a place as any, mainly cause I like watching RC type itself....
          driven
          I've been working on returning AppleScript Dialogs from SU ruby osascript, [incase it's desired/needed] and I got most of it working, launches and shows in 'SU' but writes result to tmp file.
          This is an experiment something we were trying to get externally... for soemthing like this you would most likely just use in a larger AppleScript, rather than return it to ruby...
          »»RUN in RUBY CONSOLE
          # get the target ratio from the user with an option box
          %x(rm "/private/tmp/Prnt_Format")
          %x(osascript -so > /private/tmp/Prnt_Format <<SU
          	tell application "SketchUp"
          activate
          set Land to "Landscape"
          set Portr to "Portrait"
          choose from list {¬
          	"'A'-Series " & Land, ¬
          	"'A'-Series " & Portr, ¬
          	"Architectural " & Land, ¬
          	"Architectural " & Portr, ¬
          	"'US' Letter " & Land, ¬
          	"'US' Letter " & Portr, ¬
          	"Square", ¬
          	"Use Printer Settings"} ¬
          	with title ¬
          	"Print Format" with prompt ¬
          	"Choose one format" OK button name ¬
          	"Format View" cancel button name ¬
          	"Cancel" default items {"Use Printer Settings"} ¬
          	--	with multiple selections allowed
          	end tell
          SU
          runAppleScript.kill;
          then to read back
          (`cat /private/tmp/Prnt_Format`)
          • livemixerL
            livemixer
            Jeff:
            I don't know if you still have any interest in this project, but if you do please check out the script below (based on one of your earlier ones) & see if it works for you like it does for me.
            	-- more robust to error trap for SketchUp not running before telling it anything!
            	activate
            	tell application "System Events" to tell process "SketchUp"
            		set drawwin to count of windows
            		click menu item "page setup..." of menu "file" of menu bar 1
            		repeat while focused of window drawwin = false
            			try
            				set psz to name of static text 2 of sheet 1 of window drawwin
            				(* To dismiss the page setup sheet as soon as it appears,
            				uncomment the 'click button' line below.
            				May be useful if allowing user changes is not needed &
            				the script just needs to get current values & continue?*)
            				-- click button "OK" of sheet 1 of window drawwin
            			end try
            		end repeat
            	end tell
            end tell
            (* Bring the AppleScript Editor to the front;
            manually check its Result pane for the expected psz text.
            Demonstrates that it can be processed outside the
            'tell SketchUp' loop
            activate me
            psz
            From what I understand, one of the things you wanted to do was drop down the page setup sheet & let users change its settings before continuing. It seems a little weird, but in my testing the inverted logic "repeat while focused of window drawwin = false" line accomplishes that. Here is (I think) how it works:
            The 'Events' pane of the AppleScript Editor shows the script looping through the repeat over & over, grabbing the current 'psz' value on each pass, just as one might expect. But the unexpected part is that SU doesn't seem to return 'focused = true' to the script even if a user changes something in the sheet. That only happens when a button in the sheet is clicked. That causes an error in the repeat loop (because sheet 1 is no longer there) so the script exits the loop & continues with the 'psz' value from the last "good" repeat.
            To keep things simple & make testing easier, I didn't do any processing of the 'psz' text in the script. If you run it from Script Editor, it should bring the script window back to the front as soon as you click "OK" in the SU sheet & the text should be the only thing in the 'Result' pane.
            That also avoids the distraction of a 'Display Dialog' window & messing with AppleScript's Text Item Delimiters (which really should be saved before a change & restored to the saved value ASAP afterwards so the change won't screw up some other script that expects the default or its own changed value).
            • jeff hammondJ
              yeah.. i'm pretty much over this project.. i have a version of it which i do use but making it work on pre-lion OSes was too much of a pain for me..
              i use the part which can resize the actual drawing window to a desired aspect ratio as well as the part which gives a true zoom extents.. the rest of it was an attempt at automation for others but i dunno.. i guess i lost the drive to make that happen..
              that said.. i do have another applescript idea brewing but i haven't really dug into it yet.. maybe you guys want to try some stuff with the idea.. i was going to call it TightenUp.. what it would do is grab all the various windows/toolbars then put them in exact locations.. the only thing missing for me is the algorithm (if that's even what it's called in this case).. but i think we've already figured out how to get bounds of everything and how to move them around etc..
              here's the basic idea.. on the left is my typical looking sketchup.. on the right is after running the script (and it would also be useful for people with lost panels etc.. better than sketchup's 'reset workspace' thing..
                driven
                not Jeff, but gave it a whirl anyway... it didn't work here... and took a little while to see why.
                basically I had 2 drawings open, without realising it and it was screwing with the count of windows...
                This is actually one of the reasons I'm pursuing the ruby interaction...
                suWin = Sketchup.active_model.title if suWin.to_a.length == 1 then suWin = suWin else suWin = "Untitled" end #if if Sketchup.is_pro? @suW =(suWin + ".skp - SketchUp Pro").inspect else @suW =(suWin + ".skp - SketchUp").inspect end #if
                returns **"2Arcs_36sided.skp - SketchUp Pro"**
                if I have the other model forefront I get, "Untitled.skp - SketchUp Pro"
                if your not runing pro it should chop "Pro"
                if thats used in the AppleScript there's no ambiguity, which easily, can be a show stopper.
                also the value is then easier to get...
                get the value of text field 1 of sheet 1 of window "2Arcs_36sided.skp - SketchUp Pro"
                @Jeff I do have scripts that do that sort of thing, but integrating them into ruby will make then more portable.
                you want to split this into the dev forum and we might get more help??
                • jeff hammondJ
                  ha.. crazy but last time this thread was going, i left for a job then i personally fizzled out on pursuing it further..
                  and yesterday, i flew to a job.. then i go home for 2 days.. then to nashville for a few weeks after that..
                  so all my energy is zapped for at least a month or so 😉
                    driven
                    Ok, know how it feels, the next film I had got put back when the lead actor pulled out so I have a reprieve at the moment..., 'sort of luckily' while the money holds out...
                    I'll start a Dev Forum thread, cause i need help with the ruby anyway and have been PM-ing a-lot, so it makes sense.
                    I chucked it here because you kicked me into gear the last time, so try out some of this stuff when you get a mo, I think it's going to be worth it, I wrote a quasi "grasshopper" script using AppleScript from ruby the other day, and although it was minor league it was great fun seeing it work...
                    • livemixerL
                      livemixer
                      I knew that using 'count of windows' as a reference to the frontmost document window could cause problems if the app had more than one of them open. I was really just trying to call attention to the fact that System Events apparently 'sees' the focused property of the app change to the sheet of a document window only when one of the sheet's buttons is clicked & not (for example) when one of its text fields or some other UI element is changed. That seems strange since the app's focus has to be on a UI element to enable users to change it … right?
                      • jeff hammondJ
                        i worked on some of this stuff later than posted in the thread and i'm not really sure where i left off but.. going through some of the scripts i have, i found i was doing this for dealing with multiple drawing windows..
                        it will give you the frontmost window even if there are others opened behind it..
                        	activate
                        		--identify the frontmost drawing window
                        		set drawwin to 0
                        		set cw to 1 + (count of windows)
                        		repeat until drawwin ≠ 0
                        			set cw to (cw - 1)
                        			if value of attribute "AXmain" of window cw is true then
                        				set drawwin to cw
                        			end if
                        		end repeat
                        	end tell
                        end tell
                        i'll try to go through some of my scripts over the next few days to see if there are any other things i might of tried of interest
                        • livemixerL
                          livemixer
                          i found i was doing this for dealing with multiple drawing windows...
                          Very interesting! Long ago I tried to work out a good general way to get the frontmost document window when using GUI scripting but I never thought of using the attribute class & never got anywhere without it. Thanks very much for that!
                          Another problem with GUI scripting I've never been able to solve is how to reliably detect if the frontmost app window has changed during the execution of the script, like when the script is in a loop waiting for some user action in the app to trigger exiting the loop. That can cause problems even with a foolproof way to get an unambiguous reference to what is frontmost before the script enters the loop.
                          Oh well. One step at a time, I guess.
                          • livemixerL
                            livemixer
                            FWIW, here is yet another AppleScript idea for getting the frontmost window, or more accurately the one that has the app's focus:
                            	activate
                            		set Focus_Is to "nothing"
                            		repeat with i from (count of windows) to 1 by -1
                            			if focused of window i then
                            				set Focus_Is to name of window i
                            				exit repeat
                            			end if
                            		end repeat
                            	end tell
                            end tell
                            activate me
                            {Focus_Is, i}
                            Unlike Jeff's method using the "AXmain" attribute, this script will return whatever window currently has the focus, even if it isn't a drawing document window. It handles multiple drawing windows & even no drawing windows without problems. As is, I assume it will not handle the unusual case in which absolutely no SU windows are open (counting from zero to 1 by -1 isn't going to work!) but except for that I think it is pretty bulletproof (as long as SU is running when it is called, of course.)
                            Aside from that, if anyone can get it to stop on an error, please let me know.
                            I wrote it mostly to explore the conditions in which System Events doesn't get the right focus (like when the page setup sheet is open & users change something in it, as I noted earlier) but maybe it will be useful for something else as well….
                              driven
                              hi,
                              the problem with using 'focused' is that I can only ever get main window to return true, regardless of what's actully focused
                              tell application "Sketchup" to activate
                              delay 0.5
                              		set winCount to count windows
                              		repeat with n from 1 to winCount
                              			set thisWindow to window n
                              			--set winSize to size of thisWindow
                              			--set sw to item 1 of winSize
                              			--set sh to item 2 of winSize
                              			--set winPosition to position of thisWindow
                              			--set pw to item 1 of winPosition
                              			--set ph to item 2 of winPosition
                              			--set winName to ((get name of thisWindow) as string)
                              			--set winTitle to ((get title of thisWindow) as string)
                              			set winFocus to ((get focused of thisWindow) as string)
                              			--set winRole to ((get role of thisWindow) as string)
                              			--set winDisc to description of thisWindow
                              			--set winProps to (get properties of thisWindow)
                              			--set winCont to get the entire contents of thisWindow
                              		end repeat
                              	end tell
                              end tell
                              another problem is using 'name' v 'title', if an item has neither, 'name' returns nothing and 'title' returns an empty string, which you can at lease use to dig deeper...
                              a question- if using 'set winProps to (get properties of thisWindow)' how can you filter out missing value?
                              • livemixerL
                                livemixer
                                @driven said:
                                hi,
                                Odd. That doesn't happen for me. For instance, if I select an arc in a new, unsaved draw window named "Untitled - SketchUp" & then click on the Entity Info "Segments:" box, in part the events/replies for your script shows the following :
                                get focused of window "Entity Info" of application process "SketchUp"
                                		--> true
                                get focused of window "Untitled - SketchUp" of application process "SketchUp"
                                		--> false
                                In this case my script results shows
                                {"Entity Info", 2}
                                Interestingly, the Outliner window gives different results. If I select a group in the Outliner list or click in its search/filter box, it is clearly the focus, but both scripts indicate that 'focused' is true for no window. It is this kind of behavior that prompted me to write my script in the first place.
                                True, but my script was intended to only to look for application windows that might have the focus. AFAIK only named windows in SU can do that.
                                I have never found a very elegant general method for dealing with 'missing value' properties, mostly because I don't know how to do that without explicitly using the property's name (like "whose size is not missing value"), which leads to a separate line for each property of interest.
                                Along those lines, something like this might work for you:
                                	activate
                                		set HasSize to {}
                                		set HasName to {}
                                		-- etc.
                                		repeat with n from 1 to count of windows
                                			set WinProps to properties of window n
                                			if size of WinProps is not missing value then set end of HasSize to n
                                			if name of WinProps is not missing value then set end of HasName to n
                                			-- etc.
                                		end repeat
                                	end tell
                                end tell
                                activate me
                                {HasSize, HasName}
                                That will give you lists of window numbers that exclude those with missing values for one specific property each. You can use each of them in a 'repeat with loopVariable in list' type loop (like "repeat with i in HasSize") to process just the windows that have values.
                                Just an idea.
                                  driven
                                  I been distracted getting this to work... and just had success!!!
                                  # get the name of current window to use in Applescript using window -- set size (item 2) of window "#{@suW}"
                                  @suW = ' "' + suWin + '.skp - SketchUp"'
                                  end #if
                                  if  suWin.to_a.length == 1 && Sketchup.is_pro? then
                                  @suW = ' "' + suWin + '.skp - SketchUp Pro"'
                                  end #if
                                  if suWin.to_a.length == 0 then
                                  @suW = 's whose name begins with "Untitled"'
                                  end #if
                                  # test in osascript... harder than imagined- you need to 'write the osascript in the 'main thread' to collect the variables from ruby,
                                  # but you need to run it in a separate thread to avoid 'blocking' the main thread when you 'tell' SketchUp, eval works, but is it a problem?
                                  appleScript=(<<MT
                                  runAS=Thread.new{
                                  `osascript -ss <<ST
                                  delay 0.5
                                  		set size of window#{@suW} to {1000, 1000}
                                  	end tell
                                  end tell
                                  ST`
                                  MT
                                  eval appleScript;
                                  can you give it a try while I grab a coffee and mull over my reply?
                                  EDIT: re-jigged top to pickup 'Pro' more reliably
                                    driven
                                    > 		--> true
                                    > 		--> false
                                    {"Entity Info", 2}...
                                    I only tested 17 of the 19 I had open, guess which I missed...
                                    True, but my script was intended to only to look for application windows that might have the focus. AFAIK only named windows in SU can do that....
                                    I think 'title' and 'description' give all the info needed to re-size, re-position, or dig deeper using 'entire contents' [seems to be 4 different types of window and if the title is empty it's an SU Toolbar!!!]
                                    I have never found a very elegant general method for dealing with 'missing value' properties,...
                                    I keep forgetting it's a constant and try to test for it...
                                    I should probably head for bed, it's gone 1am already
                                    • jeff hammondJ
                                      wait what? you're british?
                                      i mistook you as american.. sorry 😉
                                      • livemixerL
                                        livemixer
                                        It's easy to miss: from what I can tell, the Entity Info window is the only window besides any open drawing windows that will retain the focus of SU when it is made frontmost by the "Activate" action, & only if the cursor was in one of its regular editable text fields when it was last frontmost. (It won't even retain the focus if the cursor was in the layer field.)
                                        However, if any window besides a drawing window or the Entity Info window with a text field selected last had the focus, both our scripts show that no window has the focus when the script makes SU frontmost again. At first I thought this was some quirk of GUI Scripting or the "Activate" action or something like that, but now I think it is a quirk of SU itself.
                                        I haven't worked out all the details yet but it appears that if SU is made frontmost by any other method besides clicking on one of its windows (like via a script's "Activate" action or clicking on its icon in the Dock when it is already open), it can go into a weird, 'indefinite focus' state.
                                        For instance, if I click on a group in the drawing window & then click on the "name" field in the Entity Info window, the focus shifts to the Entity Info window, as expected. But if I then click on some other open app in the Dock & then click on the SU icon in the Dock, the focus isn't on either the Entity Info window or any drawing window. It actually seems to be on the "Large Tool Set" palette (if it is present), because for instance if I type "a" for the arc tool, the arc icon highlights in that palette … but not in the toolbar of the drawing window. At this point, the drawing window isn't frontmost or the focus:something is amiss! Moreover, the mouse pointer has not been updated with the arc icon, & even after clicking in the drawing window to get it & even after drawing an arc, the toolbar icon in the drawing window remains "stuck" on the select tool's arrow icon.
                                          driven
                                          not so much a quick, but how Su specifies the Nib files for all the sub-windows
                                          the majority are NSPanels that have been left as 'click thru' so that they 'don't' take 'focus' when clicked.
                                          this is why 'Toolbars' work immediately, but a button in a 'Webdialog'[ has 'click thru' off by default ] needs 'click' to 'focus'; 'click' to 'activate'; 'click' to 'de-focus'; making 'webDialog' toolbars on a mac a pain.
                                          Can you test this in 'Ruby Console', it's an old 'what works here' script that I automated with Applescript...
                                          Draw a cube the paste in console and return, should generate a list of all SU names for tools used...
                                          if it baulks at anything, comment that line out with a #
                                          def runASclk
                                          `osascript <<EOF
                                          			if description of thisWindow is "alert" then
                                          				delay 0.5
                                          				click button "OK" of thisWindow
                                          			end if
                                          		end repeat
                                          	end tell
                                          end tell
                                          EOF`
                                          runAppleScript.kill
                                          end #  runASclk
                                          list=<<-HereDoc
                                          Sketchup.send_action('showRubyPanel;')
                                          Sketchup.send_action('viewZoomToSelection;')
                                          Sketchup.send_action('editUndo;')
                                          Sketchup.send_action('viewBack;')
                                          Sketchup.send_action('editRedo;')
                                          Sketchup.send_action('viewBottom;')
                                          Sketchup.send_action('editHide;')
                                          Sketchup.send_action('viewFront;')
                                          Sketchup.send_action('editUnhide;') #!   dosn't work on mac
                                          Sketchup.send_action('viewIso;')
                                          Sketchup.send_action('editUnhideLast;') #*  does work on mac
                                          Sketchup.send_action('viewLeft;')
                                          Sketchup.send_action('viewUndo;')
                                          Sketchup.send_action('editUnhideAll;') #*  does work on mac
                                          Sketchup.send_action('viewRight;')
                                           !Sketchup.send_action('viewShowAxes;') #*  does work on mac
                                          Sketchup.send_action('viewTwoPointPerspective;') #* does work on mac
                                          Sketchup.send_action('renderShaded;')
                                          Sketchup.send_action('viewTop;')
                                          Sketchup.send_action('viewPerspective;')
                                          Sketchup.send_action('viewParallelProjection;') #* does work on mac
                                          Sketchup.send_action('renderWireframe;')
                                          Sketchup.send_action('renderMonochrome&#058;')
                                          Sketchup.send_action('viewShowGuides;') #*  does work on mac
                                          !Sketchup.send_action('viewShowGuides;') #*  does work on mac
                                          !Sketchup.send_action('viewShowHidden;') #*  does work on mac
                                          Sketchup.send_action('pageAdd;')
                                          Sketchup.send_action('viewSectionPlanes;')  #?
                                          Sketchup.send_action('viewZoomExtents;')
                                          Sketchup.send_action('selectOrbitTool;')
                                          Sketchup.send_action('selectPositionCameraTool;')
                                          Sketchup.send_action('selectDollyTool;')
                                          Sketchup.send_action('selectTurnTool;')
                                          Sketchup.send_action('selectWalkTool;')
                                          Sketchup.send_action('selectZoomTool;')
                                          Sketchup.send_action('selectFieldOfViewTool;')
                                          Sketchup.send_action('selectZoomWindowTool;')
                                          Sketchup.send_action('pageUpdate;')
                                          Sketchup.send_action('pageNext;')
                                          Sketchup.send_action('pagePrevious;')
                                          Sketchup.send_action('pageDelete;')
                                          Sketchup.send_action('renderHiddenLine;')
                                          Sketchup.send_action('renderTextures;')
                                          Sketchup.send_action('selectArcTool;')
                                          Sketchup.send_action('selectAxisTool;')
                                          Sketchup.send_action('selectCircleTool;')
                                          Sketchup.send_action('selectEraseTool;')
                                          Sketchup.send_action('selectFreehandTool;')
                                          Sketchup.send_action('selectLineTool;')
                                          Sketchup.send_action('selectMeasureTool;')
                                          Sketchup.send_action('selectMoveTool;')
                                          Sketchup.send_action('selectOffsetTool;')
                                          Sketchup.send_action('selectPaintTool;')
                                          Sketchup.send_action('selectPolygonTool;')
                                          Sketchup.send_action('selectProtractorTool;')
                                          Sketchup.send_action('selectPushPullTool;')
                                          Sketchup.send_action('selectRectangleTool;')
                                          Sketchup.send_action('selectRotateTool;')
                                          Sketchup.send_action('selectScaleTool;')
                                          Sketchup.send_action('selectSectionPlaneTool;')
                                          Sketchup.send_action('selectTextTool;')
                                          Sketchup.send_action('selectDimensionTool;')
                                          Sketchup.send_action('selectExtrudeTool;')
                                          Sketchup.send_action('selectSelectionTool;')
                                          Sketchup.send_action('fixNonPlanarFaces;')
                                          Sketchup.send_action('addBuilding;')
                                          Sketchup.send_action('getPhotoTexture;')
                                          Sketchup.send_action('selectImageIglooTool;')
                                          Sketchup.send_action('selectNorthTool;')
                                          HereDoc
                                          list.split("\n")
                                          t1=Time.now.dup
                                          list.each { |l|
                                          UI.start_timer(1) {UI.messagebox(l.to_s)
                                          reply=(IO.readlines("/private/tmp/SketchUpUndo0.log"))[-1]
                                          puts reply;p (Time.now-t1);
                                          eval(l.chomp!);
                                          runASclk
                                          EDIT: I added # to stop it pausing on black lines... didn't help so removed blank lines
                                          • livemixerL
                                            livemixer
                                            if it baulks at anything, comment that line out with a #...
                                            When I run this, I get a very long succession of dialog boxes with various messages & just an OK button. Sometimes the message is just "#," sometimes "##," & sometimes something more descriptive. Sometimes the dialog boxes auto-dismiss themselves, sometimes I have to click "OK" to get things moving again.
                                            After letting it run ~ 10 minutes, I started clicking furiously on the "OK" button as soon as it appeared & it finally finished. Only then could I could scroll through the RC window's hundreds of lines of output. A few of them ended with "#* does work on mac" or "#! dosn't work on mac" EDIT: which I see now are just part of your script.
                                            I haven't looked at it too closely but it seems to repeat everything several times, almost as if it was stuck in an infinite loop.
                                            I'll PM you the RC output as a Textedit file -- it's too long to post here.
                                            EDIT: aside from the output in the RC window, nothing else happened. What should have?
                                            • 4 / 4
