    [AppleScript] - Sketchup PrintRight
    75 Posts 7 Posters 8.3k Views 7 Watching
    • jeff hammondJ
      here's the same thing i was trying above except it now uses ruby for the zoom factor instead of messing around with the camera's FOV.. so i'm now able to work with 3D objects instead of just flat ones..
      i think it's just some weird math and a few dialogs to do then this whole idea might actually work 😲
      ` tell application "SketchUp"
      activate
      tell application "System Events" to tell process "SketchUp"
      	set drawwin to count of windows
      	set AppleScript's text item delimiters to {" "}
      	--set the camera to Parallel Projection by checking if Field Of View is enabled
      	--(FOV will NOT be greyed out if Perspective or 2pt Perspective)
      	if enabled of menu item "Field of View" of menu 1 of menu bar item "Camera" of menu bar 1 is true then
      		click menu item "Parallel Projection" of menu 1 of menu bar item "Camera" of menu bar 1
      	end if
      	-- Zoom extents then use ruby console to scale zoom by a factor of 1.05405
      	click menu item "Zoom Extents" of menu "Camera" of menu bar 1
      	click menu item "Ruby Console" of menu "Window" of menu bar 1
      	keystroke "view = Sketchup.active_model.active_view
      	view = view.zoom 1.05405" & return
      	-- close ruby console
      	click button 1 of window "Ruby Console"
      end tell
      end tell`
      [edit].. hmm.. that's not compiling properly once i copy/paste it from the forum back into applescript editor.. the ruby part should look like this in applescript editor :
      maybe if i break it down into separate keystroke entries i'll be able to post it properly here?
      here's the .scpt instead:
      SU_ZOOMRUBY.zip
        driven
        jeff heres a sumac download link, dmg installerhttp://homepage.mac.com/johnboundy/filechute/sumac_dev_2011-03-01-002859.dmg.zip
        I need to go back out for an hour or so, I'll have another look at your stuff.
        What I see as being really good with what your trying is the idea...
        and you've cracked what can't be done from SU ruby.. i.e manipulate the window size and position the window.
        ruby can handle all the other bits really easily, without opening dialogs or console at all, it can even send the applescript to system and avoid an external file altogether.
        What I find interesting is the possibility of doing other things to other SU windows, so if you click a button, Applescript could get the position and pass that info to a ruby WebDialog that then appears in that spot, hiding the button in the process.
        In that WD you could say I want 8 A4 sheets of this drawing, size and zoom the window for accurate printing, and have ruby move camera, save and name image 8 times.
        more later
          driven
          Hey Jeff,
          lets bump this Applescript stuff and get more people in on the act...
          I've been re-reading all the SketchUp Applescript 'google' hits and I think it's time to make it all work.
          One of the past problems was no-one seemed to know how to get Applescript to do this sort of thing from INSIDE a ruby script... e.g. »» RUN IN AppleScript Editor
          activate application "Sketchup"
                click menu item "Weld" of menu "Plugins" of menu bar 1
             end tell
          end tell
          Although you could get other apps to run from SU using 'osascript' e.g. »» RUN IN Ruby Console
          `osascript -e 'activate application "Safari"'`
          Previously, as soon as you changed the app to SketchUp you beach-balled...
          well, I finally got it working e.g. »» RUN IN Ruby
          runAppleScript=Thread.new{
          `osascript <<EOF
          	end tell
          end tell
          EOF
          runAppleScript.kill
          the missing ingredient was a new Thread... and a HEREDOC to simplify the osascript
          so where does that all lead us?
          if it has a menu item you can activate it from ruby
          so if you have "Arc: Center and 2 points"
          #--# UI;;Toolbar why would you want a custom set of menu items?
            def aplscrpt_TB
            		aplscrpt_tb = UI;;Toolbar.new "aplscrpt_TB"
                # This command when clicked
                cmd = UI;;Command.new("aplscrpt_TB-Test") {
          				`osascript <<EOF
          							click menu item "Arc; Center and 2 points" of menu "Draw" of menu bar item "Draw" of menu bar 1
          						end tell
          					end tell
          				EOF
          	    runAppleScript.kill
            		aplscrpt_tb.add_item cmd
            		aplscrpt_tb.show
            end # aplscrpt_TB
          you can have a button even though it's an encrypted file...
          but there's even more we can do with this,
          I've worked out how to 'mine' the menu items, and how to 'activate' them from a ruby script, but I'm trying to optimise the parsing to html for use in a 'WebDialog'.
          The best way to explain my goal, is a floating 'localised', 'dynamic' menu/toolbar that can be edited (via option boxes) to show only the items you want, and be positioned anywhere, i.e. another monitor.
          I use full screen mode alot, and I find getting menu items is a pain. There are only so many shortcut keys I can remember...
          Another advantage is it can be 'Stay Open', eg. if you want to check all available camera views in advanced camera tools.
          I have made 'html' that looks like a menu, and others that look like toolbar buttons. but I need to full it all together.
          and then there's window positioning and sizing, a lot can be gain on using Applescripts strengths from inside ruby...
          @ Jeff, if you don't want the highjack, split this to a new thread, but I think it's as good a place as any, mainly cause I like watching RC type itself....
            driven
            I've been working on returning AppleScript Dialogs from SU ruby osascript, [incase it's desired/needed] and I got most of it working, launches and shows in 'SU' but writes result to tmp file.
            This is an experiment something we were trying to get externally... for soemthing like this you would most likely just use in a larger AppleScript, rather than return it to ruby...
            »»RUN in RUBY CONSOLE
            # get the target ratio from the user with an option box
            %x(rm "/private/tmp/Prnt_Format")
            %x(osascript -so > /private/tmp/Prnt_Format <<SU
            activate
            set Land to "Landscape"
            set Portr to "Portrait"
            choose from list {¬
            	"'A'-Series " & Land, ¬
            	"'A'-Series " & Portr, ¬
            	"Architectural " & Land, ¬
            	"Architectural " & Portr, ¬
            	"'US' Letter " & Land, ¬
            	"'US' Letter " & Portr, ¬
            	"Square", ¬
            	"Use Printer Settings"} ¬
            	with title ¬
            	"Print Format" with prompt ¬
            	"Choose one format" OK button name ¬
            	"Format View" cancel button name ¬
            	"Cancel" default items {"Use Printer Settings"} ¬
            	--	with multiple selections allowed
            	end tell
            SU
            runAppleScript.kill;
            then to read back
            (`cat /private/tmp/Prnt_Format`)
            • livemixerL
              livemixer
              Jeff:
              I don't know if you still have any interest in this project, but if you do please check out the script below (based on one of your earlier ones) & see if it works for you like it does for me.
              	-- more robust to error trap for SketchUp not running before telling it anything!
              	activate
              		click menu item "page setup..." of menu "file" of menu bar 1
              		repeat while focused of window drawwin = false
              			try
              				set psz to name of static text 2 of sheet 1 of window drawwin
              				(* To dismiss the page setup sheet as soon as it appears,
              				uncomment the 'click button' line below.
              				May be useful if allowing user changes is not needed &
              				the script just needs to get current values & continue?*)
              				-- click button "OK" of sheet 1 of window drawwin
              			end try
              		end repeat
              	end tell
              end tell
              (* Bring the AppleScript Editor to the front;
              manually check its Result pane for the expected psz text.
              Demonstrates that it can be processed outside the
              'tell SketchUp' loop
              activate me
              psz
              From what I understand, one of the things you wanted to do was drop down the page setup sheet & let users change its settings before continuing. It seems a little weird, but in my testing the inverted logic "repeat while focused of window drawwin = false" line accomplishes that. Here is (I think) how it works:
              The 'Events' pane of the AppleScript Editor shows the script looping through the repeat over & over, grabbing the current 'psz' value on each pass, just as one might expect. But the unexpected part is that SU doesn't seem to return 'focused = true' to the script even if a user changes something in the sheet. That only happens when a button in the sheet is clicked. That causes an error in the repeat loop (because sheet 1 is no longer there) so the script exits the loop & continues with the 'psz' value from the last "good" repeat.
              To keep things simple & make testing easier, I didn't do any processing of the 'psz' text in the script. If you run it from Script Editor, it should bring the script window back to the front as soon as you click "OK" in the SU sheet & the text should be the only thing in the 'Result' pane.
              That also avoids the distraction of a 'Display Dialog' window & messing with AppleScript's Text Item Delimiters (which really should be saved before a change & restored to the saved value ASAP afterwards so the change won't screw up some other script that expects the default or its own changed value).
              • jeff hammondJ
                yeah.. i'm pretty much over this project.. i have a version of it which i do use but making it work on pre-lion OSes was too much of a pain for me..
                i use the part which can resize the actual drawing window to a desired aspect ratio as well as the part which gives a true zoom extents.. the rest of it was an attempt at automation for others but i dunno.. i guess i lost the drive to make that happen..
                that said.. i do have another applescript idea brewing but i haven't really dug into it yet.. maybe you guys want to try some stuff with the idea.. i was going to call it TightenUp.. what it would do is grab all the various windows/toolbars then put them in exact locations.. the only thing missing for me is the algorithm (if that's even what it's called in this case).. but i think we've already figured out how to get bounds of everything and how to move them around etc..
                here's the basic idea.. on the left is my typical looking sketchup.. on the right is after running the script (and it would also be useful for people with lost panels etc.. better than sketchup's 'reset workspace' thing..
                  driven
                  not Jeff, but gave it a whirl anyway... it didn't work here... and took a little while to see why.
                  basically I had 2 drawings open, without realising it and it was screwing with the count of windows...
                  This is actually one of the reasons I'm pursuing the ruby interaction...
                  suWin = Sketchup.active_model.title if suWin.to_a.length == 1 then suWin = suWin else suWin = "Untitled" end #if if Sketchup.is_pro? @suW =(suWin + ".skp - SketchUp Pro").inspect else @suW =(suWin + ".skp - SketchUp").inspect end #if
                  returns **"2Arcs_36sided.skp - SketchUp Pro"**
                  if I have the other model forefront I get, "Untitled.skp - SketchUp Pro"
                  if your not runing pro it should chop "Pro"
                  if thats used in the AppleScript there's no ambiguity, which easily, can be a show stopper.
                  also the value is then easier to get...
                  get the value of text field 1 of sheet 1 of window "2Arcs_36sided.skp - SketchUp Pro"
                  @Jeff I do have scripts that do that sort of thing, but integrating them into ruby will make then more portable.
                  you want to split this into the dev forum and we might get more help??
                  • jeff hammondJ
                    ha.. crazy but last time this thread was going, i left for a job then i personally fizzled out on pursuing it further..
                    and yesterday, i flew to a job.. then i go home for 2 days.. then to nashville for a few weeks after that..
                    so all my energy is zapped for at least a month or so 😉
                      driven
                      Ok, know how it feels, the next film I had got put back when the lead actor pulled out so I have a reprieve at the moment..., 'sort of luckily' while the money holds out...
                      I'll start a Dev Forum thread, cause i need help with the ruby anyway and have been PM-ing a-lot, so it makes sense.
                      I chucked it here because you kicked me into gear the last time, so try out some of this stuff when you get a mo, I think it's going to be worth it, I wrote a quasi "grasshopper" script using AppleScript from ruby the other day, and although it was minor league it was great fun seeing it work...
                      • livemixerL
                        livemixer
                        I knew that using 'count of windows' as a reference to the frontmost document window could cause problems if the app had more than one of them open. I was really just trying to call attention to the fact that System Events apparently 'sees' the focused property of the app change to the sheet of a document window only when one of the sheet's buttons is clicked & not (for example) when one of its text fields or some other UI element is changed. That seems strange since the app's focus has to be on a UI element to enable users to change it … right?
                        • jeff hammondJ
                          i worked on some of this stuff later than posted in the thread and i'm not really sure where i left off but.. going through some of the scripts i have, i found i was doing this for dealing with multiple drawing windows..
                          it will give you the frontmost window even if there are others opened behind it..
                          	activate
                          		--identify the frontmost drawing window
                          		set drawwin to 0
                          		set cw to 1 + (count of windows)
                          		repeat until drawwin ≠ 0
                          			set cw to (cw - 1)
                          			if value of attribute "AXmain" of window cw is true then
                          				set drawwin to cw
                          			end if
                          		end repeat
                          	end tell
                          end tell
                          i'll try to go through some of my scripts over the next few days to see if there are any other things i might of tried of interest
                          • livemixerL
                            livemixer
                            i found i was doing this for dealing with multiple drawing windows...
                            Very interesting! Long ago I tried to work out a good general way to get the frontmost document window when using GUI scripting but I never thought of using the attribute class & never got anywhere without it. Thanks very much for that!
                            Another problem with GUI scripting I've never been able to solve is how to reliably detect if the frontmost app window has changed during the execution of the script, like when the script is in a loop waiting for some user action in the app to trigger exiting the loop. That can cause problems even with a foolproof way to get an unambiguous reference to what is frontmost before the script enters the loop.
                            Oh well. One step at a time, I guess.
                            • livemixerL
                              livemixer
                              FWIW, here is yet another AppleScript idea for getting the frontmost window, or more accurately the one that has the app's focus:
                              	activate
                              		set Focus_Is to "nothing"
                              		repeat with i from (count of windows) to 1 by -1
                              			if focused of window i then
                              				set Focus_Is to name of window i
                              				exit repeat
                              			end if
                              		end repeat
                              	end tell
                              end tell
                              activate me
                              {Focus_Is, i}
                              Unlike Jeff's method using the "AXmain" attribute, this script will return whatever window currently has the focus, even if it isn't a drawing document window. It handles multiple drawing windows & even no drawing windows without problems. As is, I assume it will not handle the unusual case in which absolutely no SU windows are open (counting from zero to 1 by -1 isn't going to work!) but except for that I think it is pretty bulletproof (as long as SU is running when it is called, of course.)
                              Aside from that, if anyone can get it to stop on an error, please let me know.
                              I wrote it mostly to explore the conditions in which System Events doesn't get the right focus (like when the page setup sheet is open & users change something in it, as I noted earlier) but maybe it will be useful for something else as well….
                                driven
                                hi,
                                the problem with using 'focused' is that I can only ever get main window to return true, regardless of what's actully focused
                                tell application "Sketchup" to activate
                                delay 0.5
                                		set winCount to count windows
                                		repeat with n from 1 to winCount
                                			set thisWindow to window n
                                			--set winSize to size of thisWindow
                                			--set sw to item 1 of winSize
                                			--set sh to item 2 of winSize
                                			--set winPosition to position of thisWindow
                                			--set pw to item 1 of winPosition
                                			--set ph to item 2 of winPosition
                                			--set winName to ((get name of thisWindow) as string)
                                			--set winTitle to ((get title of thisWindow) as string)
                                			set winFocus to ((get focused of thisWindow) as string)
                                			--set winRole to ((get role of thisWindow) as string)
                                			--set winDisc to description of thisWindow
                                			--set winProps to (get properties of thisWindow)
                                			--set winCont to get the entire contents of thisWindow
                                		end repeat
                                	end tell
                                end tell
                                another problem is using 'name' v 'title', if an item has neither, 'name' returns nothing and 'title' returns an empty string, which you can at lease use to dig deeper...
                                a question- if using 'set winProps to (get properties of thisWindow)' how can you filter out missing value?
                                • livemixerL
                                  livemixer
                                  @driven said:
                                  hi,
                                  Odd. That doesn't happen for me. For instance, if I select an arc in a new, unsaved draw window named "Untitled - SketchUp" & then click on the Entity Info "Segments:" box, in part the events/replies for your script shows the following :
                                  get focused of window "Entity Info" of application process "SketchUp"
                                  		--> true
                                  get focused of window "Untitled - SketchUp" of application process "SketchUp"
                                  		--> false
                                  In this case my script results shows
                                  {"Entity Info", 2}
                                  Interestingly, the Outliner window gives different results. If I select a group in the Outliner list or click in its search/filter box, it is clearly the focus, but both scripts indicate that 'focused' is true for no window. It is this kind of behavior that prompted me to write my script in the first place.
                                  True, but my script was intended to only to look for application windows that might have the focus. AFAIK only named windows in SU can do that.
                                  I have never found a very elegant general method for dealing with 'missing value' properties, mostly because I don't know how to do that without explicitly using the property's name (like "whose size is not missing value"), which leads to a separate line for each property of interest.
                                  Along those lines, something like this might work for you:
                                  	activate
                                  		set HasSize to {}
                                  		set HasName to {}
                                  		-- etc.
                                  		repeat with n from 1 to count of windows
                                  			set WinProps to properties of window n
                                  			if size of WinProps is not missing value then set end of HasSize to n
                                  			if name of WinProps is not missing value then set end of HasName to n
                                  			-- etc.
                                  		end repeat
                                  	end tell
                                  end tell
                                  activate me
                                  {HasSize, HasName}
                                  That will give you lists of window numbers that exclude those with missing values for one specific property each. You can use each of them in a 'repeat with loopVariable in list' type loop (like "repeat with i in HasSize") to process just the windows that have values.
                                  Just an idea.
                                    driven
                                    I been distracted getting this to work... and just had success!!!
                                    # get the name of current window to use in Applescript using window -- set size (item 2) of window "#{@suW}"
                                    @suW = ' "' + suWin + '.skp - SketchUp"'
                                    end #if
                                    if  suWin.to_a.length == 1 && Sketchup.is_pro? then
                                    @suW = ' "' + suWin + '.skp - SketchUp Pro"'
                                    end #if
                                    if suWin.to_a.length == 0 then
                                    @suW = 's whose name begins with "Untitled"'
                                    end #if
                                    # test in osascript... harder than imagined- you need to 'write the osascript in the 'main thread' to collect the variables from ruby,
                                    # but you need to run it in a separate thread to avoid 'blocking' the main thread when you 'tell' SketchUp, eval works, but is it a problem?
                                    appleScript=(<<MT
                                    runAS=Thread.new{
                                    `osascript -ss <<ST
                                    delay 0.5
                                    		set size of window#{@suW} to {1000, 1000}
                                    	end tell
                                    end tell
                                    ST`
                                    MT
                                    eval appleScript;
                                    can you give it a try while I grab a coffee and mull over my reply?
                                    EDIT: re-jigged top to pickup 'Pro' more reliably
                                      driven
                                      > 		--> true
                                      > 		--> false
                                      {"Entity Info", 2}...
                                      I only tested 17 of the 19 I had open, guess which I missed...
                                      True, but my script was intended to only to look for application windows that might have the focus. AFAIK only named windows in SU can do that....
                                      I think 'title' and 'description' give all the info needed to re-size, re-position, or dig deeper using 'entire contents' [seems to be 4 different types of window and if the title is empty it's an SU Toolbar!!!]
                                      I have never found a very elegant general method for dealing with 'missing value' properties,...
                                      I keep forgetting it's a constant and try to test for it...
                                      I should probably head for bed, it's gone 1am already
                                      • jeff hammondJ
                                        wait what? you're british?
                                        i mistook you as american.. sorry 😉
                                        • livemixerL
                                          livemixer
                                          It's easy to miss: from what I can tell, the Entity Info window is the only window besides any open drawing windows that will retain the focus of SU when it is made frontmost by the "Activate" action, & only if the cursor was in one of its regular editable text fields when it was last frontmost. (It won't even retain the focus if the cursor was in the layer field.)
                                          However, if any window besides a drawing window or the Entity Info window with a text field selected last had the focus, both our scripts show that no window has the focus when the script makes SU frontmost again. At first I thought this was some quirk of GUI Scripting or the "Activate" action or something like that, but now I think it is a quirk of SU itself.
                                          I haven't worked out all the details yet but it appears that if SU is made frontmost by any other method besides clicking on one of its windows (like via a script's "Activate" action or clicking on its icon in the Dock when it is already open), it can go into a weird, 'indefinite focus' state.
                                          For instance, if I click on a group in the drawing window & then click on the "name" field in the Entity Info window, the focus shifts to the Entity Info window, as expected. But if I then click on some other open app in the Dock & then click on the SU icon in the Dock, the focus isn't on either the Entity Info window or any drawing window. It actually seems to be on the "Large Tool Set" palette (if it is present), because for instance if I type "a" for the arc tool, the arc icon highlights in that palette … but not in the toolbar of the drawing window. At this point, the drawing window isn't frontmost or the focus:something is amiss! Moreover, the mouse pointer has not been updated with the arc icon, & even after clicking in the drawing window to get it & even after drawing an arc, the toolbar icon in the drawing window remains "stuck" on the select tool's arrow icon.
                                            driven
                                            not so much a quick, but how Su specifies the Nib files for all the sub-windows
                                            the majority are NSPanels that have been left as 'click thru' so that they 'don't' take 'focus' when clicked.
                                            this is why 'Toolbars' work immediately, but a button in a 'Webdialog'[ has 'click thru' off by default ] needs 'click' to 'focus'; 'click' to 'activate'; 'click' to 'de-focus'; making 'webDialog' toolbars on a mac a pain.
                                            Can you test this in 'Ruby Console', it's an old 'what works here' script that I automated with Applescript...
                                            Draw a cube the paste in console and return, should generate a list of all SU names for tools used...
                                            if it baulks at anything, comment that line out with a #
                                            def runASclk
                                            `osascript <<EOF
                                            			if description of thisWindow is "alert" then
                                            				delay 0.5
                                            				click button "OK" of thisWindow
                                            			end if
                                            		end repeat
                                            	end tell
                                            end tell
                                            EOF`
                                            runAppleScript.kill
                                            end #  runASclk
                                            list=<<-HereDoc
                                            Sketchup.send_action('showRubyPanel;')
                                            Sketchup.send_action('viewZoomToSelection;')
                                            Sketchup.send_action('editUndo;')
                                            Sketchup.send_action('viewBack;')
                                            Sketchup.send_action('editRedo;')
                                            Sketchup.send_action('viewBottom;')
                                            Sketchup.send_action('editHide;')
                                            Sketchup.send_action('viewFront;')
                                            Sketchup.send_action('editUnhide;') #!   dosn't work on mac
                                            Sketchup.send_action('viewIso;')
                                            Sketchup.send_action('editUnhideLast;') #*  does work on mac
                                            Sketchup.send_action('viewLeft;')
                                            Sketchup.send_action('viewUndo;')
                                            Sketchup.send_action('editUnhideAll;') #*  does work on mac
                                            Sketchup.send_action('viewRight;')
                                             !Sketchup.send_action('viewShowAxes;') #*  does work on mac
                                            Sketchup.send_action('viewTwoPointPerspective;') #* does work on mac
                                            Sketchup.send_action('renderShaded;')
                                            Sketchup.send_action('viewTop;')
                                            Sketchup.send_action('viewPerspective;')
                                            Sketchup.send_action('viewParallelProjection;') #* does work on mac
                                            Sketchup.send_action('renderWireframe;')
                                            Sketchup.send_action('renderMonochrome&#058;')
                                            Sketchup.send_action('viewShowGuides;') #*  does work on mac
                                            !Sketchup.send_action('viewShowGuides;') #*  does work on mac
                                            !Sketchup.send_action('viewShowHidden;') #*  does work on mac
                                            Sketchup.send_action('pageAdd;')
                                            Sketchup.send_action('viewSectionPlanes;')  #?
                                            Sketchup.send_action('viewZoomExtents;')
                                            Sketchup.send_action('selectOrbitTool;')
                                            Sketchup.send_action('selectPositionCameraTool;')
                                            Sketchup.send_action('selectDollyTool;')
                                            Sketchup.send_action('selectTurnTool;')
                                            Sketchup.send_action('selectWalkTool;')
                                            Sketchup.send_action('selectZoomTool;')
                                            Sketchup.send_action('selectFieldOfViewTool;')
                                            Sketchup.send_action('selectZoomWindowTool;')
                                            Sketchup.send_action('pageUpdate;')
                                            Sketchup.send_action('pageNext;')
                                            Sketchup.send_action('pagePrevious;')
                                            Sketchup.send_action('pageDelete;')
                                            Sketchup.send_action('renderHiddenLine;')
                                            Sketchup.send_action('renderTextures;')
                                            Sketchup.send_action('selectArcTool;')
                                            Sketchup.send_action('selectAxisTool;')
                                            Sketchup.send_action('selectCircleTool;')
                                            Sketchup.send_action('selectEraseTool;')
                                            Sketchup.send_action('selectFreehandTool;')
                                            Sketchup.send_action('selectLineTool;')
                                            Sketchup.send_action('selectMeasureTool;')
                                            Sketchup.send_action('selectMoveTool;')
                                            Sketchup.send_action('selectOffsetTool;')
                                            Sketchup.send_action('selectPaintTool;')
                                            Sketchup.send_action('selectPolygonTool;')
                                            Sketchup.send_action('selectProtractorTool;')
                                            Sketchup.send_action('selectPushPullTool;')
                                            Sketchup.send_action('selectRectangleTool;')
                                            Sketchup.send_action('selectRotateTool;')
                                            Sketchup.send_action('selectScaleTool;')
                                            Sketchup.send_action('selectSectionPlaneTool;')
                                            Sketchup.send_action('selectTextTool;')
                                            Sketchup.send_action('selectDimensionTool;')
                                            Sketchup.send_action('selectExtrudeTool;')
                                            Sketchup.send_action('selectSelectionTool;')
                                            Sketchup.send_action('fixNonPlanarFaces;')
                                            Sketchup.send_action('addBuilding;')
                                            Sketchup.send_action('getPhotoTexture;')
                                            Sketchup.send_action('selectImageIglooTool;')
                                            Sketchup.send_action('selectNorthTool;')
                                            HereDoc
                                            list.split("\n")
                                            t1=Time.now.dup
                                            list.each { |l|
                                            UI.start_timer(1) {UI.messagebox(l.to_s)
                                            reply=(IO.readlines("/private/tmp/SketchUpUndo0.log"))[-1]
                                            puts reply;p (Time.now-t1);
                                            eval(l.chomp!);
                                            runASclk
                                            EDIT: I added # to stop it pausing on black lines... didn't help so removed blank lines
                                            • 4 / 4
