Failed to Create Dump File: Large Images
I'm trying to render an Image that is 2048x1152 and when I start the render the Frame Buffer stays black then I get the error message
But with smaller Images I don't have this problem
My Specs are:
Intel i7 2600k
16gb Ram
1tb HD
NVidia GTX 560If anyone could help it would be greatly appreciated.
I forgot to mention I am using Sketchup 8 with Vray 1.49.01
Nevermind I fixed it!! For anyone having this error this is how I fixed it.
I noticed that I had set my model with alot of groups and components so I saved a copy of my model and exploded everything to de-group it and then it rendered fine. I hope this helps anyone facing this issue.
Thanks for the info.
This is not really recommended. vray does not need everything to be exploded. Better would be to figure out which component is causing the error and fix that. Also, any objects that are not needed for the scene, you should hide or put on a hidden layer, it will help reduce the amount of geometry that vray has to render.
I believe what Andybot was suggesting was right.. exploding all object would make the model more messed up.. for me finding the culprit is the more better way to solve it, so before i insert any model from 3d warehouse, i edit it first and try if it can render itself. remove layers, purge.
U think you should purge your model and then your layers, move it all on 1. Well it kinda helps.. : )
