    How to PDF One Page Only?
    layout
    4 Posts 3 Posters 481 Views 3 Watching
      Penguin2
      I have a 10 page Layout document converted to PDF. The file is 40MB and way too large for my Client.
      My question is: Can an individual page be exported to PDF? If so can anyone point me in the right direction on how to do this please?
      Many thanks,
      Penguin2
      • dcauldwellD Offline
        dcauldwell
        Easy-peasy
        When creating the pdf export in Layout, one of the options is 'Pages' - 'All' or '1,2,3', etc. - just select the page you want. Probably because you end up with huge pdf files, but I always export each page (i.e. each drawing) as a separate pdf, with the file name as the drawing number.
        David
        Sketchup 2017
        (vray 2.00)
          David covered the way to export a single page. You can export a range of pages, too.
          If you are doing this on Mac, be sure to click on Options before blindly hitting Save. On the PC, you get a dialog box popping up that gives you the options.
          Penguin2, please update your profile to include the operating system you use as well as the SketchUp version. It's a whole lot easier to answer your questions when we know that stuff because some things are different between operating systems. I'm guessing you have Mac because you'd surely have seen the export options on Windows.
            Penguin2
            Thank you David & David,
            I guess I had Senior Moment.
            Everyone on this site has been so helpful. I must learn to try harder before troubling you.
            Have also, as requested updated my profile.
            Thank you again.
            Regards,
            Andrew
