    Generating relief on top of torus
    36 Posts 9 Posters 2.0k Views 9 Watching
    • Jean LemireJ Offline
      Jean Lemire
      Hi Jon, hi folks.
      See this SU file for ideas.
      Helical ribs around torus.skp
        sketchymick
        @jean lemire said:
        Hi Jon, hi folks. See this SU file for ideas.
        Apart from manually stitching together the rib, is there a mathematical solution to this?
        I thought that by increasing the number of sides in the rib, say to 180 or some multiple of the rotations, it would fix this problem and the rib would become a solid, however this didn't seem to be the case. I'm intrigued now.
        "I love the sound that deadlines make as they rush past"
          Jean Lemire
          Hi Mick, hi folks.
          There is probably one. when I have a few spare minutes, I will investigate this.
          In the meantime, I would suggest trying the plugin Follow me and keep to check the concept.
          Just ideas.
            sketchymick
            @jean lemire said:
            Hi Mick, hi folks.
            Just ideas.
            Thanks Johnny, yes I tried this out first up. Conceptually it is easy (sort of!) to see what is happening, but was expecting that there would be a magic number of facets with allow an exact match of the faces after twisting around the torus. I just can't figure out what that number would be. All I know is that it isn't 180 or 360 or 48 or 16. I didn't try 720 as my machine got bogged down and I needed to get on an do some work. 😎
              Jean Lemire
              Hi Mick, hi folks.
              I though about that helical path that goes around the torus and got these ideas:
              1 - As it goes around, the path rotates two full turns around the torus.
              2 - As it goes around, the path starts on the top, then goes inside and down and then outside and up. This is done twice. Each of these lateral movements, one from inside to outside and vice versa and the other one up and down, are like sinusoidal curves.
              3 - Add to this the fact that, when using the Follow me tool, the path rotates about two axes at the same time, which produces a rotation around the third axis.
              4 - I still need to figure out the orientation of the circular facet after it completes its two rotation to see by how much it actually rotates and what is the needed correction to have it register perfectly after two turns.
              5 - I will also try the Follow me and keep plugin to see if I can have a solid group without any more interventions.
              6 - I will try to set the small circular facet on the midpoint of a sement of the path instead of on an endpoint. This should works.
              Just ideas.
              • jeff hammondJ Offline
                i am more_likely_than_not misinterpreting what you're saying here but if the 'rib' your referring to is the smaller 'rope' going twice around the torus -and- by 'solid' you mean a solid group (sketchup solid) then jean has already accomplished that..
                it's the path line which remains in the middle of the rib which prevents it from registering as solid.. erase it and the rib will be solid.
                  sketchymick
                  No you're not misinterpreting it. I was just curious as to whether there was an elegant solution, rather than having to manually stitch up the ends (Johnny's method). Of course the pragmatic way is to spend 30 seconds to stitch it up like this, but the purest in me is searching for the combination of facets that would avoid needing to do this. It's pure curiosity.
                  • gillesG Offline
                    gilles
                    Here is a way:
                    DO NOT TRY TO EXPLODE ALL IN ONE SHOT AND SAVE BEFORE!
                      Jean Lemire
                      Hi Gilles, hi folks.
                      Very clever.
                      Best regards.
                      Brillant.
                      Salutations.
                      • gillesG Offline
                        gilles
                        You are right, I forgot one step.
                        Thanks to clarify.
                        • cottyC Offline
                          cotty
                          @gilles said:
                          Here is a way:
                          Nice and detailed solution! 👍
                          my SketchUp gallery
                            sketchymick
                            @gilles said:
                            Here is a way:
                            Nice !!!!
                              @gilles said:
                              Here is a way:
                              • gillesG Offline
                                gilles
                                Hello Jeff, had a good night?
                                  Seems Follow me and rotate by Wikii make something similar ? 😉
                                    [attachment=0:26zw3j75]<!-- ia0 -->far.jpg<!-- ia0 -->[/attachment:26zw3j75]
                                    hmm.. maybe component stringer then curviloft can do the trick too?
                                    (can't check right now because I'm on a bus but doesn't component stringer have a rotate option?)
                                      ha.. yeah right.. 3hrs sleep 😕
                                        Component Stringer by Chris Fullmer
                                        Yes it has, it's even its principal quality ☀
                                        It's only default is the no intuitive position of the Axis default 💚
                                        • gillesG Offline
                                          gilles
                                          surely Rhino Muhahahahah.
                                            jon bondy
                                            I created this in what I assume is the normal fashion: started with a torus, drew a line that wrapped around the torus twice, removed one line segment, created a surface orthogonal to the line end, drew a circle, and used a follow-me to create the "pipe". I then attempted to stitch the ends of that pipe together with a series of manually drawn lines to create triangles. I gather that this attempt failed. The original instructions said to use Skin to stitch the pipe together, but I could not get that to work at all.
                                            So, I cannot see how to fix this helix. And I gather that the original torus also has a defect, but I've not had a chance to tend to that.
                                            Again, any hints would be appreciated.
                                            Jon
                                            James Torus 1b2.skp
