    [Plugin]Export Collada with texture names 1.2b [30/9/11]
    38 Posts 15 Posters 50.6k Views 15 Watching
    • pep75P Offline
      pep75
      Hey Gaius,
      In Cinema4D I normally get "Material 1, Material 2, etc" instead of the material names I use in SketchUp. When I use the collada-plugin (file > export collada with material names) it really doesn't export it with the material names. I'm working with Windows and version 8...mmm
      grtzz
      Pep
        We can't see how to rename 'Materials' in a DAE file.
        We can rename their 'Texture' files however.
        SO depending on the app that you import into - all materials will become something like material0, material1 etc, or in a SKP <auto>1 etc.
        Assigning a name to a material in the DAE is simply ignored and the app's imported materials are named using their simple numerical order in the DAE file.
        However, if the material has a texture many apps will list that against the material, so you can then spot it by that image-name IF you've used this exporter-tool and had used sensible image names for textured-materials. With the native DAE exporter material1 will have a texture called perhaps texture1.png etc... but at least this tools gives material1 with ' brick_666.png'...
        • pep75P Offline
          pep75
          Aaaaaah...so only the names of TEXTURED materials will show up...mmm...well that means no improvement for me...😞....grrr....I could already see the linked texture-names in Cinema and the textures are clear to me wich material it is....well...
          Thanks though!!
          Grtzz
          Pep
            Aerilius
            That could be a explanation (I can't check because I don't have C4D).
            It seems collada files contain several "similar" elements like %(#000000)[<image>], %(#000000)[<effect>], %(#000000)[<material>] and %(#000000)[<instance_material>]. SketchUp's exporter applies generic IDs and names ("Material2") to these elements and generic names to the texture files.
            I added already the capability to apply the original material's name to %(#000000)[<material name="...">] and %(#000000)[<instance_material symbol="...">] (although that was risky and caused lots of the errors in the posts above, but it should work now). I regret if those names aren't imported into other applications.
            • pep75P Offline
              pep75
              Hey Aerilius, please don't apologise for this...you did a great job, and I was getting used for waiting on a more streamlined import method to C4D. It will come! πŸ˜„
              Thanks anyway!
              Grtz
              Pep
                StamatisPsarras
                First of all Thanks for your efford!
                I am having 2 problems with this particular plugnin
                1. The normal collada file from the native exporter in sketchup is about 62mb but with your is more that 250mb. Is there anything, like filenames, material names or whatever matter when exporting?
                2. Importng it to Lumion doesn't seem to show up the names of the materials. Has anyone make it to work properly with lumion? Meaning lots of re-sync with correct materials?
                p.s. I don't know if that matters but I am notusing "textres" in sketchup just color "materials" that I change the name (!)
                Thanks for your time!
                edit: I also tried with "textured" materials and some materials got idd renamed in the first time, but 1) The texture seamed to go to more surfaces than i put it 2) The names on a second export seemed to seize renamed and go to a generic material01, material03...
                Although as I understanding there is not a perfect solution here. Has anyone understood what order sketchup uses in order to apply the generic material names? My first thought was alphabetical but this seems not to be the case...Plz help me.... 😞
                • McGyverM Offline
                  McGyver
                  I'm curious if anyone has found out if it is possible to keep the material names (by that I mean the SketchUp "color only type materials" not image textures) when exporting using DAE... Has this been determined to be impossible?
                  Visit My ShareCG Freebie Gallery
                    rraallvv
                    Could someone add an option to swap Y and Z axis, please
                    I am using Collada2POD to import my models into my application, but Y and Z axis appears swapped
                    I'd appreciate it a lot
                    • E Offline
                      electrician
                      I have problem, i use this plug in but still texture names comes like texture0.bmp, texture01.bmp ect... What is possibly happening? I use File > "Export collada with texture names"
                        MKumar
                        Even when i use this exporter it creates lot of textures, instead of one. the above comments are too technical for me. can you professional give me a simple solution or an updated exporter which works.
                          The native exporter works fine, except that material-names get changed [even worse in older versions], hence the attempt here to 'fix' the names, the exported DAE format is no different... πŸ˜•
                          Here's my analysis...
                          When you get lots of texture files relating to something that appears to be the same texture it is because most exported file formats rely on triangulated mesh faces and therefore only have three vertex normals to map the UVs of the textures [i.e. to work out how the texture is positioned exactly on each facet]. Now, if a texture has been simply positioned on a face [i.e. slid around], or rotated or scaled, then these three points are sufficient to determine what the texture should be like on the related exported facet. However, if you have a 'skewed/perspective-like' texture [even slightly distorted like this] - perhaps by moving one corner inadvertently whilst positioning/rotating it, or somehow projecting it - then to UV map that texture in the exported format successfully would need four vertices, and of course as explained before we only ever get three to use !
                          So to overcome this many exporters will spot these distortions and create a unique distorted texture-map of that particular texture and save it as another 'similar' image-file... and then apply that without any other UV mapping as the texture - so that it then looks the same in the exported version; but of course it has to use this other image-file. Thus, is you have lots of weirdly distorted textures in a SKP that you export it can include many of these distorted image-files... Some Pro exporters try to reuse distorted image-files for several matching facets, others like my OBJexporter have a built-in tolerance and if the distortion is very slight the undistorted standard version of the image-file is still used to avoid zillions of slightly different files/textures getting made...
                          So, in conclusion... I suspect your SKP has many distorted textures that cannot be easily exported without distorted image-files being created. 😒
                            Mra
                            Nice plugin,
                            but it seems this does not support the exporting of instances/symbols/components etc?
                            I import in Maya and SketchUp components are no longer instances.
                            However if I export using regular Collada DAE exporter, maya reads SketchUp components as instances.
                              sbht
                              @aerilius said:
                              This plugin allows to export the whole model or the selection to Collada file format while preserving/restoring the the texture's original file and the material's screen names.
                              This is useful since SketchUp's Collada exporter creates generic names which don't allow to identify materials anymore when you want to use the file in another software.
                              SketchUp also creates new textures images for each face with distorted texture coordinates; however these won't receive the original material's name.
                              If you need specific export options (from SketchUp's options dialog), feel free to edit the options_hash.
                              Unfortunately, SketchUp also creates generic material names ( %(#000000)[<auto>1]) when you import Collada files into SketchUp.
                              Version: 1.2b
                              Date: 30.09.2011
                              Usage:
                              (Menu) File -> 'Export Collada with texture names'
                              πŸ‘ it works for my pc
                              Aerilius, thanks a lot your helps
                              • I Offline
                                Irteza
                                Dear, i am still getting my textures renamed as _auto_4.bmp, i read all the posts but couldn,t figured out the issue, using windows and Sketchup 2017, can you help.
                                • 2 / 2
