    Render line styles?
    12 Posts 8 Posters 939 Views 8 Watching
    • novenaN
      novena
      interesting solo... can it be used for example as bump or displacement map??? vray has something similar at least within 3D max
      best
      V
      http://hdzarkitektur.wordpress.com/
      • soloS
        best
        V
        Hmmm,dunno, never thought of trying, I will give it a go when i get a chance, got a link to the Vray thing you mentioned?
        • novenaN
          novena
          @solo said:
          best
          V
          hi,
          Peter Guthrie's blog:
          http://www.peterguthrie.net/blog/2009/03/vray-edge-fillet-tutorial/
          it also works fine to simulate for example tiles if applied to the displacement channel
          • soloS
            Here is a first try,
            The SU Raw image:
            Here is the render, edges have prcedural map, will try get more displacement next.
            • cottyC
              cotty
              Very promising ...
              my SketchUp gallery
              • olisheaO
                olishea
                excellent!!
                oli
                • pbacotP
                  I was comparing to Kerky lines. I can't see that the hiddenline as in your sculpture could be done, but there is a line per material option that sort of looks like this. Just not versed in using it. Is there a way in Thea that you can do hard edges only or filter the angle? It appears in one picture you have panels in the doors, but not the others? Was that an effect of this?
                  • olisheaO
                    olishea
                    Pete is there a general dirt tutorial? I just can't see its effect most of the time, or will it only be more pronounced on rectilinear forms?
                    oli
                    • Mike LuceyM
                      Mike Lucey
                      Cool Pete πŸ‘
                      • T
                        tomasz
                        You have quite a lot of control in Thea over which edges get wire-frame procedural. By default it is applied to all edges, but you can mark only Silhouette & Hard Inner & Hard outer edges, same way as in Kerkythea.
