    Render line styles?
    12 Posts 8 Posters 923 Views 8 Watching
      Line power πŸ˜„
      • novenaN Offline
        novena
        interesting solo... can it be used for example as bump or displacement map??? vray has something similar at least within 3D max
        best
        V
        http://hdzarkitektur.wordpress.com/
        • soloS Offline
          best
          V
          Hmmm,dunno, never thought of trying, I will give it a go when i get a chance, got a link to the Vray thing you mentioned?
          • novenaN Offline
            novena
            @solo said:
            best
            V
            hi,
            Peter Guthrie's blog:
            http://www.peterguthrie.net/blog/2009/03/vray-edge-fillet-tutorial/
            it also works fine to simulate for example tiles if applied to the displacement channel
            • soloS Offline
              Here is a first try,
              The SU Raw image:
              Here is the render, edges have prcedural map, will try get more displacement next.
              • cottyC Offline
                cotty
                Very promising ...
                my SketchUp gallery
                • olisheaO Offline
                  olishea
                  excellent!!
                  oli
                  • pbacotP Offline
                    I was comparing to Kerky lines. I can't see that the hiddenline as in your sculpture could be done, but there is a line per material option that sort of looks like this. Just not versed in using it. Is there a way in Thea that you can do hard edges only or filter the angle? It appears in one picture you have panels in the doors, but not the others? Was that an effect of this?
                    • olisheaO Offline
                      olishea
                      Pete is there a general dirt tutorial? I just can't see its effect most of the time, or will it only be more pronounced on rectilinear forms?
                      oli
                      • Mike LuceyM Offline
                        Mike Lucey
                        Cool Pete πŸ‘
                          tomasz
                          You have quite a lot of control in Thea over which edges get wire-frame procedural. By default it is applied to all edges, but you can mark only Silhouette & Hard Inner & Hard outer edges, same way as in Kerkythea.
