    [Plugin] Create Section Drawing V1.3(update Dec16.2012.)
    50 Posts 30 Posters 56.9k Views 30 Watching
      tak2hata
      Hi,Paolo.
      I update this plugin in Jun 28.2012.
      v1.2 Improve about dxf value scaling by units in sketchup.
      Export dxf as inch values when the length unit in sketchup is inch.
      Hi,Phanga.
      Thanks your sharing. πŸ˜„
      @refy said:
      Sir Tak2hata you have contributed very useful plug-ins but this is off topic because i did find your plug-in multi export using the vidro. Could you please make a tutorial on exporting and adding material with vidro. i just don't know how to use the vidro renderer.
      Hi refy.
      I will improve su2objmtl_vidro in future.
      I will add material edit function for vidro.
      In this time,material name is used for vidro material setting.
      Su2objmtl_vidro material setting manual.http://onigiriburning.so.land.to/su2objmtl_page.html
      Thanks.
      by TAK2HATA
        tulacong
        ok thank you men
          Bertier
            paolomiana
            thanks a lot!
            Paolo
            • Z Offline
              z200121
              thanks
                lubessy
                Thank you for creating this plugin!
                however, when i open the section cut dxf file.. nothing comes out!!
                but the section cut and saving all worked from sketchup , and it automatically saves my file
                so when i open the dxf file.. nothing shows in autocad...
                any idea why??
                please let me know!
                • JVT_LTDJ Offline
                  JVT_LTD
                  @tak2hata said:
                  Hi,everyone.
                  I release plugin named "Create Section Drawing".
                  ##General disclaimer
                  ##I MAKES NO GUARANTEE OF VALIDITY about reports by using this script.
                  ##Please use this script at your own risk.
                  ##This plugin need sketchup v8 higher.
                  ##May 02.2012:v1.0 Fisrt release.
                  ##May 06.2012:v1.1 Bugfix about calculating baselines on mac.
                  ##Jun 28.2012:v1.2 Improve about dxf value scaling by units in sketchup.
                  #Description
                  #Select the section plane and pulldown menu "Create Section Drawing".
                  #And The section will be created in the component definition list of the model.
                  #and export to "DrawingSection" folder as skp and dxf.
                  #The section from solid will be filled.
                  #The infomation of component or group will add text to drawings.(name,and BST info)
                  #The ComponentDefinition named "BST_BASELINES" will add baselines to drawings.
                  ##Under the line added in May03.2012.
                  ##"DrawingSection" folder will be created in the same folder with the editing sketchup model file.
                  ##Do not create new folder when it is not saved.
                  ##But section drawing is created as component definition ,too.
                  ##So looking for the component list.It will be found.
                  Download Version1.2:[attachment=0:145k1iop]<!-- ia0 -->create_section_drawings.rb<!-- ia0 -->[/attachment:145k1iop]
                  Enjoy! πŸ˜„
                  Thanks.
                  Indeed this one of the best plugin... Many thanks! πŸ‘ πŸ‘
                  But may I suggest or if possible to add a specify distance/measure (D=?) from section base forward see attached so that we could add some details we've like to include or exclude vice versa in the sections... thanks in advance... πŸ‘
                  http://img405.imageshack.us/img405/3760/image001dpu.jpg
                    tak2hata
                    Hi,JVT_LTD.
                    It is very useful suggestion.
                    I will add the depth text under the section drawing.
                    Hi,lubessy.
                    I can not see your state of sketchup.
                    So,please upload or send your file include that problem.
                    Thanks.
                    by TAK2HATA
                    • JVT_LTDJ Offline
                      JVT_LTD
                      @tak2hata said:
                      Hi,JVT_LTD.
                      Hi,lubessy.
                      Thanks.
                      @tak2hata
                      Thanks for considering my suggestion... looking forward to your update! πŸ‘ πŸ‘
                        tak2hata
                        I update this plugin,and version become 1.3 in Dec 16,2012.
                        The text about distance of section plane is placed in left bottom of the drawing.
                        And "About This" was added in menu.
                        Version information will be shown there.
                        Thanks.
                        by TAK2HATA
                        • JVT_LTDJ Offline
                          JVT_LTD
                          @tak2hata said:
                          Thanks.
                          Nice one... πŸ‘
                          I don't know if I'm the only one experiencing this, 😞 the text about distance of section plane is placed in left bottom of the drawing does not appeared? after giving the section name the process is same as old version ❓
                          What I did is replacing the old .rb files...
                            tak2hata
                            Hi,JVT_LTD.
                            You may overwrite this.rb file on already exists rb file.
                            Restart your sketchup after the current version is installed.
                            "About This" is added in create section drawing menu.
                            Please watch this video.
                            Thanks.
                            by TAK2HATA
                            • JVT_LTDJ Offline
                              JVT_LTD
                              @tak2hata said:
                              Hi,JVT_LTD.
                              Thanks.
                              Thanks for such a nice video tuts... πŸ‘
                              But I don't know if its possible to your plugin? what I would like to suggest? See attached below...
                              http://img843.imageshack.us/img843/6605/image002kk.png
                              My suggestion is ... After giving ComponentName, if possible, if you could include another process where you could add Distance(D=?)such as Section Plane as starting/origin point then by applying a certain Distance (D=?)and it will be the end point, the result will be like see attached below, in dwf and skp format as your plugin did.
                              http://img607.imageshack.us/img607/8746/image003k.png
                              Well this is just a suggestion of mine, you may or you may not include it, but the potential of your plugin is truly amazing if you could include this kind of process...
                              Again thank you & looking forward to your plugin... πŸ‘ πŸ‘ πŸ‘
                                tak2hata
                                Hi,JVT_LTD.
                                It is difficult for me.
                                And It will take too very long time to calculate the projection by script.
                                Thanks.
                                by TAK2HATA
                                  tulacong
                                  thank you huhuhu
                                    chooyod
                                    Hi tak2hata,
                                    How do you create a BST-Baselines on sketchup?
                                    Please suggest...
                                      tak2hata
                                      @chooyod said:
                                      Hi tak2hata,
                                      Please suggest...
                                      Hi,chooyod.
                                      The Group named "BST_BASELINES" will become BST-Baselines group.
                                      Lines/Clines in that group will be drawn as the baseline in section drawing.
                                      Notice: Allcharacters of "BST_BASELINES" are written in capital letters.
                                      by TAK2HATA
                                        Deportivolu
                                        Hi this problem
                                        Error: #<Errno::ENOENT: No such file or directory - C:/Users/fatiheker/Desktop/Yeni klasΓΆr/DrawingSection>
                                        C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/create_section_drawings.rb:655:in mkdir' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/create_section_drawings.rb:655:in makeSolidSections'
                                        C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/create_section_drawings.rb:1037
                                          @Faith
                                          The 'Yeni klasΓΆr' is the culprit.
                                          SketchUp's Ruby on PCs can't cope with non ASCII characters in file-/folder-names and file-paths - so do not use accented letters etc!
                                          Try renaming that folder 'Yeni klasoer' or 'Yeni klasor'...
                                          It should then work... πŸ˜•
                                            tak2hata
                                            Hi,TIG.
                                            Thanks for your advice!
                                            That is the problem of ruby in sketchup.
                                            Hi,Fatih.
                                            Please refer to that advice!
                                            Thanks.
                                            by TAK2HATA
                                            • 2 / 3
