    Adobe Photoshop CS version 8
    15 Posts 3 Posters 1.3k Views 3 Watching
    • Chris FullmerC Offline
      The "elements" and the "CS" lines of photoshop are not the same. CS is the full powered version, elements is the watered down version and is a bit cheaper. Elements sometimes comes bundled with computers or other hardware.
      Elements is now on version 11 and CS is now on version "CS6".
      If you have Elements 8 on your machine, then it is not the same as Photoshop 8. There never really was a photoshop 8. Once it hit version 8, it became CS1. So the only "version 8" is Elements v8.
      So if you've got Elements version 8, make sure you get a book for Elements version 8 and nothing else.
      • E Offline
        eccowboy
        when I open the program it says adobe photoshop cs version 8.0
        so your telling me that its the same as cs version 6.0
          Go to Help > About to see what version you are running.
          PhotoShop CS 6 is version 13
          • E Offline
            eccowboy
            rich...
            I'm running adobe photoshop version 8.0
            thats what it said when I checked........
            so what would be a good reference book to use...please
            thx
            eccowboy
              Anything by Deke McClelland
                If it says Photoshop cs, Photoshop 8 - then yes, you have the full version of Photoshop (not Elements). It is the first version of Photoshop where they switch to the "CS" nomenclature. So they probably also referred to it as "8" in places, but in truth, it is widely known as version Photoshop CS(1).
                So look for a book on Photoshop CS. Here is the Dummy's book by the author Rich recommends:
                ERROR: The request could not be satisfied
                (www.amazon.com)
                • E Offline
                  eccowboy
                  thanks......Chris....
                  your always very very helpful..eccowboy
                  and I'll get that dummies book
                  • E Offline
                    eccowboy
                    Background clouds...ok I'm new to PS...and I've found a couple utube videos to help...
                    but for some reason its just not working. CAN someone please help me so that I can import
                    backgrounds to my SU models, I'm really trying, maybe its my PS...nor sure. BUT it would really be appreciated here.....eccowboy thanks
                      A background in SU is not really connected to photoshop....
                      Do you just want a background in SU? Try adding a watermark in the styles dialog window. Is that what you're trying to do?
                      • E Offline
                        eccowboy
                        actually I want to import the SU model into photoshop.....and insert a background there, i.e. clouds...I have an idea how it works...but its not going to well.
                        thx..eccowboy
                          Ahh, got it!
                          So did you manage to open the sketchup jpg in photoshop? In the Layers pane, double click on the "Background" layer (the sketchup image) and when the little box pops up, just hit enter. That should unlock the layer so you can work with it better.
                          Then use magic wand to select the sky in the model image and delete it. Then insert the could picture into the image, make sure its layer is below the sketchup model image. And then move it around how you want it.
                          That is a very simplified explanation of it all. But is that approximately what you';re trying to do? What part is not working?
                          • E Offline
                            eccowboy
                            I know how to insert the SU image, thats easy, but I want to insert cloud backgrouns, I followed the steps, like to name a selection etc and you see the outline of the background around the building. Then I go into google and copy a background scene. BUT when its time to insert it it doesn't happen. SO what do I do Chris
                              Ahh, its hard to copy and paste from the internet directly into Photoshop. Some webpages make it harder than others, some browsers make it harder than others. I would say to save the picture from the internet onto your computer (like your desktop) and then just drag it into the photoshop image.
                              Does that help?
                              • E Offline
                                eccowboy
                                as always chris yes it does.................thanks so much
