    [Tutorial] SketchUp Ruby C Extension
    176 Posts 16 Posters 30.8k Views 16 Watching
    • Dan RathbunD Offline
      Dan Rathbun
      I have chosen STL C++ Library template ... which produces a C++ dynamic shared library (.dylib). I guess it is right type. Unfortunately it does not load with require "extension". Something is still missing.
      It should according to the description of Kernel.require()
      (1) Try the whole filename: require("extension.dylib")
      (2) Try specifying Kernel.require("extension_name") instead of the copy of require() that is inherited by Object. (Some naughty plugin could have changed it.)
      (3) Be aware that require has undergone changes over the years, to both fix some bugs (early on it pushed filepaths into $LOADED_FEATURES before it was determined if the files loaded successfully,) and to change the iteration of paths in $LOAD_PATH (it used to iterate the $LOAD_PATH array multiple times for each filtype { .rb, .so, .o, .dll, ...etc.} This was changed later on so it only iterates each directory once.) One of the major SNAFUs with dealing with different Ruby versions for different SketchUp platforms and versions.
      (4) require() has ALWAYS first checked to see if the argument resolves to a valid absolute filepath, and loads that valid file, instead of iterating through the $LOAD_PATH array.
      I'm not here much anymore.
        tomasz
        @thomthom said:
        Wait, are you making a C++ extension instead of C?
        Yes. I have finally made it. What a nightmare 😄
        Xcode
        New Project
        Template > "Command Line Tool"!
        Enter product name "SX_HelloWorld.bundle"
        Type "C++"
        The *.c file renamed to *.cpp.
        Init_SX_HelloWorld( void ) has to be enclosed in extern "C"
        extern "C" {
        // The init function here
        The last line of the code should read:
        rb_define_module_function( mSUExtTest, "knock_knock", RUBY_METHOD_FUNC(rb_knock), 0 );
        Now the important thing
        Build Settings\Linking\Other Linker Flags > -dynamic -bundle -undefined suppress -flat_namespace
        Build Settings\Search Paths\Header Search Path > has to point to Ruby headers
        Build Settings\Search Paths\Library Search Path > has to point to Ruby compiled library
        I have compiled the extension with LLVM GCC 4.2
        Author of [Thea Render for SketchUp](http://www.thearender.com/sketchup)
          Where does this macro come from? RUBY_METHOD_FUNC
            tomasz
            This sits in ruby.h. Without getting a proper pointer type the code will not compile, since it is C++ now.
            #define RUBY_METHOD_FUNC(func) ((VALUE (*)(ANYARGS))func)
              tomasz
              @dan rathbun said:
              Is v4.4 too new to work with such an old Ruby version as 1.8.5-p0 ??
              I have compiled the sample extension using dynamic library. My Lion has Ruby 1.8.7 present and this simple example worked just fine.
              I am trying to compile Ruby 1.8.5 as a static library now and it looks that with Xcode 4.4, it is next to impossible to get things right. I wish I had Snow Leopard with Xcode 3.2.
                Anton_S
                When recompiling Win32::API under own namespace, do not use -Ox flag.
                The -Ox flag from [Compiler Options](http://msdn.microsoft.com/en-US/library/19z1t1wy(v), which creates maximum optimization causes SketchUp to produce a bugsplat right after completion of callback function enumeration.
                Example:
                module My;;CallbackTest
                  EnumWindows = My;;Win32;;API.new('EnumWindows', 'KP', 'I', 'User32')
                  EnumWindowsProc = My;;Win32;;API;;Callback.new('IP', 'I'){ |hwnd, lParam|
                    puts hwnd
                    1 # continue process
                  def self.listWindowHandles
                    EnumWindows.call(EnumWindowsProc, nil)
                    # With Compiled $CFLAGS = '-MT -Ox -W4'
                    #   SU crashes right after enumation through all parent handles.
                    # With Compiled $CFLAGS = '-MT -W4'
                    #   SU works fine, although the size looks ~1.5 KB greater than with the -Ox flag.
                When compiling Win32::API, I have $CFLAGS = '-MT -W4'
                ...just sharing some Win32::API compilation experiments 🤓
                  Good to know!
                  I should add some warning about the -Ox flag that it might cause problems - since it's very aggressive optimization.
                    Call for information
                    I´ve only used a Mac Mini PPC with 10.4 and a Mac Mini Intel with 105 when compiling C Extensions under OSX.
                    I´m getting all sorts of warning that 10.5 isn´t supported anymore, from Apple and the software. Fair enough.
                    But what I´d like to know is:
                    If I update to Montain Lion - what would I need to get SketchUp Ruby C Extensions running?
                    I take it that the OS Ruby versions is much newer now - and I´d have to link the build to something other than the OS Ruby?
                    Also, when compiling a C Extension under Mountain Lion - how backwards compatible will it be?
                    • AdamBA Offline
                      AdamB
                      No, a Plugin resolves the symbols on load.
                      As much as you ask for it to be: eg -mmacosx-version-min=10.4 will ensure it runs on 10.4 and up.
                      Just to correct this. The optimization does not produce 'wrong code' per se. Its that it commonly will remove leaf function stack frames to increase performance, meaning Ruby's GC can't find a reference to a Object and it gets marked for collection. So ensure you keep references and you'll be fine.
                        Really? But if the OS Ruby is 1.9, and I compile without doing anything. Won't it be compiled for 1.9 only then? Isn't there completely different functions between 1.8 and 1.9?
                        Where does this flag go in the compile process? In the MAKEFILE? In the arguments of the make command?
                        (I'm very green to this.)
                        Thanks for the clarification.
                          @designingcrime said:
                          Hey guys, so I finally got a Ruby C extension to compile on both os x and windows and link curllib. I got a lot of help from Luis at the RubyInstaller group and ended up using RubyInstaller and DevKit to link curl and build using the gcc compiler included with devkit.
                          Here is the extension. Its a modified version of Dana's sketchup downloader, but also included uploading, basic http authentication and ssl certificate checking(all through curl). I provided instructions on how to build on both os x and windows.
                          https://github.com/sunglass/SunglassPlugins/tree/master/SG-SketchupHook/src/Connection%20Manager
                          Thanks for all your help guys.
                          Dana - Lets get your Sketchup downloader plugin working.
                          Link is dead. 😞
                          • W Offline
                            Whaat
                            Just wanted to thank Thomas and everyone else for the contributions in this thread. I tried to get Thomas' Hello World extension working and had no problems at all, thanks to his clear documentation.
                            My next experiment will be to incorporate SketchUp SDK calls into the Ruby Extension. Has anyone done this? Is it relatively straightforward? Any 'gotchas' that you could warn me about? Thanks
                            • W Offline
                              Whaat
                              Problems already...
                              I have the SDK .h files installed in the same folder as 'SX_HelloWorld.c'. I'm not sure what to do with the binary files provided with the SDK.
                              I tried to include just one header <slapi/model/model.h> file from the SDK and this was the result.
                              Feeling clueless...
                              • tt_suT Offline
                                tt_su
                                We're actually working on a Hello World example for Visual Studio and Xcode for compiling Ruby C/C++ Extensions for SketchUp. We can expand that (create a work or extra branch) with SLAPI configured as well.
                                By the way can you post a Gist of your code? You got some syntax errors there that appear to not be related to linking to the correct headers.
                                • W Offline
                                  Whaat
                                  Interesting, I was just now doing some research into 'extconf.rb' and I'm starting to think my problem is related to not configuring the location of the .lib and .h files inside of 'extconf.rb' using the 'dir_config' and 'have_library' commands.
                                  BTW, the only difference between my code and your 'hello world' code on bitbucket is that I #included one the SLAPI .h files at the top.
                                  I had assumed (or hoped) that it would be properly linked since I put the files in the same location as the .c file that I was trying to compile. 👊
                                  It goes without saying that I am a complete noob at this.
                                  • tt_suT Offline
                                    tt_su
                                    Hi Dale
                                    I looked into this and found that you cannot use Visual Studio's nmake for this as it's C89 - and the SLAPI is written in C99.
                                    It would work if you install the DevKit at Ruby Windows Installer - though I'm still working out some minor quirks. We're preparing some Hello World examples to get started with Ruby C Extensions. Can you hang in there a little bit more?
                                    • W Offline
                                      Whaat
                                      @tt_su said:
                                      Hi Dale
                                      No problem. Thanks for looking into this. I am excited to see the new examples... 🎉
                                      • tt_suT Offline
                                        tt_su
                                        Good news is that I got the SLAPI example compiling under OSX. I need to test on Windows and clean up the extconf.rb file a little.
                                        • W Offline
                                          Whaat
                                          Cool! 👍
                                            tomasz
                                            It will be very good indeed to have those examples easy to compile and ready to expand.
                                            • 4 / 9
