🛣️ Road Profile Builder | Generate roads, curbs and pavements easily  Download
Including a hole in a composant
Is the city one big component or are there a lot of smaller components?
some small ones, and inside one small component there are some smaller buildings which are components to
For numereous reasons, I think your only option is to copy the city and explode all components and sub-components. Intersect that with the cylinder, remove all unwanted geometry and make that into a component.
You can follow these steps:
- put the cylinder in the right position
 - select all components which are touched by it (parallel top view)
 - group them, explode all in that group (colored in the example, just to clarify)
 - use booltools with the new group and the group with the cylinder
 - delete remaining components and add hole
thanks for your explanation
I will try it
