    Render package options?
    38 Posts 13 Posters 3.0k Views 13 Watching
      You have also the new Octane Render who can interest you but NVidia Graphic card needing!
      • jason_marantoJ
        jason_maranto
        @solo said:
        Then there is the price, by far the best value for money based on what you get.
        I think this can be a bit misleading -- it is a good value, but if you take Maxwell for comparison you can see that Thea is not the best value. The full Render Suite of Maxwell comes with all plugins for free (and offers many that Thea does not like Photoshop, Nuke, and After Effects... 17 in all) -- it also offers 5 free render nodes.
        If you add up all the price of all plugins Thea offers, and the render node difference, Thea comes out to be more expensive -- and you could easily make the argument that you get less for your money (depending on your needs).
        Each engine has it's strengths and weaknesses (which can be listed on and on) but "value" is definitely in the eye of the beholder, and depends entirely on your needs.
        Best,
        Jason.
        • StinkieS
          Stinkie
          @toynlet said:
          Anymore suggestions / comments are welcome.
          Don't buy hastily. Try extensively first.
          BTW, and out of mere curiosity, do you have any images by your '3rd party' you could show us? If you can't -no worries. πŸ˜‰
          @ Jason: one could argue that with Thea, you only pay for the plugins you actually need. 😎
          • jason_marantoJ
            jason_maranto
            Certainly true, but working in a large company having access to all of the Maxwell plugins can be useful -- with just one license you can have several people working in several different applications at the same time (via the plugins)... some doing scene setup (SketchUp, 3DSMax, etc.), others doing postwork (Photoshop, Nuke, After Effects). And with the 5 render nodes you could have as many as 6 scenes rendering at a time... as far as I can see the only thing the license is tied to is the computer(s) doing the actual rendering.
            My point wasn't so much that Thea was a bad value, just that "value" is a subjective idea.
            But yes, testing and research is the only way to know what might be your best fit. πŸ‘ πŸ‘
            Best,
            Jason.
            • T
              toynlet
              Best,
              Jason.
              Forgive me, Render nodes?
              Would I be correct in thinking these are seperate PC's linked together to render multiple scenes or a scene in a shorter time?
              • jason_marantoJ
                jason_maranto
                Render nodes can be installed on all your machines in a network, the main machine with the license could be considered one render node by itself (meaning it can render) but it could also be the manager of the other networked computers.
                Essentially you can render up to how many licenses you may have (in this instance 1+5) -- this can be used to render 6 different scenes or render 1 scene 6 times faster... or any combination you like.
                This is particularly valuable in a large company setting because these renders can be queued up to render overnight while the staff is not using the machines for any other purpose.
                A clarification of my last post -- The plugins may not be intended to be usable over several computers, that is just my experience. Meaning I have one license and use both my computers to work. While one machine is rendering I am on the other setting up scenes (SketchUp or otherwise)... It works very well for me.
                Best,
                Jason.
                • StinkieS
                  Stinkie
                  I know. And I agree. πŸ˜„
                  • soloS
                    As Jason above mentions render nodes are a great asset for large rendering jobs, animations etc, Thea offers three nodes as a basic package as well as options to install full suite on two machines. My workflow is pretty simple if I am working on one large project and need to render I will use all 4 machines in a network setup to get the job done fast, if it's a single scene I just farm it off to one machine and keep working on a new project using my main rig. I have also started using Dropbox as a great trick instead of using the internal nodes I just pack my scene and paste into dropbox, open it up on another machine and hit render, thus I can close it on main machine and start next project.
                    • soloS
                      Just took a look at the example you posted, firstly I'd work on the materials, getting better quality seamless materials will help when rendering, I pretty much left your model as is, just added pavement and road and some tree proxy's, used HDRI lighting and background, 5 minutes setup and 10 minutes render, all within SU (not studio) no post processing.
                      • pbacotP
                        Pete,
                        That's impressive Pete. (of course these are YOUR times πŸ˜„ ) Is this with the Thea "soon to be released" πŸ˜’ plugin? I can't wait.
                        Did you modify the window material?
                        Peter
                        • Al HartA
                          Al Hart
                          @toynlet said:
                          Hi Guys
                          Apologise if this is posted in the wrong section but I thought asking people who use different packages and regularly produce high quality photorealistic renders would be the best to ask for a bit of advice!
                          Steve
                          There are some sample SketchUp renderings, from various rendering packages, on this site:
                          http://sketchuprendering.com/sample-models-and-renderings/
                          I think my main observation of them is that all the packages can product good renderings one the user spends a little time learning how t set things up.
                          Al Hart
                          IRender nXt from Render Plus
                          • StinkieS
                            Stinkie
                            Pete, looks good. Bsd?
                            • soloS
                              TR1 (unbiased), I tested BSD and it rendered in 2 min 46
                              • StinkieS
                                Stinkie
                                Not bad, not bad at all. I assume you downsampled the image?
                                • soloS
                                  I set supersampling on 'normal', I did a quick video of the interactive BSD engine.
                                  Let me upload it to someplace and post in this reply when done.
                                  Here it is, It's in this wide format as I recorded over two monitors (both 27 inches)
                                  So take into account I am rendering at a huge ratio of 1870x850 (my SU ratio)
                                  http://dl.dropbox.com/u/1129899/Thea4SU.mp4
                                  • StinkieS
                                    Stinkie
                                    Cool vid. Thanks for that.
                                    My assumption was you made your image smaller in post, thus compressing the noise.
                                      jpalm32
                                      Twilight will give great results at very reasonable price. Learning curve can be applied to Thea!
                                      • soloS
                                        Absolutely, Twilight is another great option.
                                        The new Thea4SU is very simple to use by the way.
                                        • StinkieS
                                          Stinkie
                                          @solo said:
                                          Ah, yes. Forgot about that one. Good choice for a beginner. Easy to use, cheap, nice forum. And there's a tutorial on Lynda.com.
                                          • T
                                            toynlet
                                            Thankyou to everyone for their input!
                                            Even more research for me and hopefully an opportunity to use some of these packages.
                                            Steve
                                            • 2 / 2
