    Complex scripting/plugin - to create a component library
    52 Posts 2 Posters 3.7k Views 2 Watching
      Lersince1991
      ABSOLUTELY BRILLIANT!
      This is SO good now!
      LONG STORY SHORT I THINK YOU'VE DONE IT!
      comments (some for me ๐Ÿ˜„ )/
      1 - deleted a duplicate (it was in the scrit twice!) of the img perimeter deleting - this caused everything to be deleted (a page back) ("### REMOVE img's UNWANTED PERIMETER", "### REMOVE OUTER EDGES LEFT FROM EXPLODED IMAGE")
      2 - I will need to sort out the images with small artifacts causing off axis
      3 - I am yet to try the hole deleting part but its not causing any issues on people - doing the trees tomorrow so will try then!
      4 - The layers work perfectly - will have a think whether to leave as default layer or change to People. Thinking of leaving as default as you said.
      5 - Changed to png which works much cleaner
      6 - Thumbnail refresh works well
        Lersince1991
        Ok TIG,
        I think it is deleting all the edges except the external outline. I.e. it is deleting all of the internal edges. I have tried removing the "remove holes" ruby script and I dont think this is what is deleting it. Is some of the script earlier on deleting all of the internal edges before the holes script gets to work?
          If I don't have your current code then how can I comment on what it's doing ?
          Can you PM me with the current code, and two or three dwg/image pairs [all zipped], so I test this properly my self.
          It's almost impossible to debug at arms length like this... ๐Ÿ˜•
            I've managed to mock some files up and test it...
            I think this works now
            ### usage; LukeR.importer
            module LukeR
              def self.importer()
            	model=Sketchup.active_model
            	defs=model.definitions
            	#model.start_operation("importer",true) ### Bugsplats with image.explode !!!
            	### PURGE UNUSED COMPONENTS [NOT NEEDED IF YOU DO IT MANUALLY FIRST]
            	defs.purge_unused
            	### SETUP LIST OF NAMES etc
            	cnames=[]
            	defs.each{|d|cnames << d.name if File.extname(d.name).downcase == '.dwg'}
            	cnames.sort!
            	### ADJUST TO YOUR OWN PATHS
            	fj='P;\02 General\Resource Library\People\JPEG' ### for images
            	ff='P;\02 General\Resource Library\People' ### for saved SKPs
            	#fj='C;\Users\TIG\Desktop\SKPs\PNGs'
            	#ff='C;\Users\TIG\Desktop\SKPs'
            	### PROCESS NAMES...
            	cnames.each{|name|
            		puts name
            		### SET UP defn etc ### COUNT EDGES
            		d=defs[name]
            		count=0
            		bb=Geom;;BoundingBox.new
            		d.entities.each{|e|
            			bb.add(e.bounds)
            			count+=1 if e.is_a?(Sketchup;;Edge)
            		### ADD IMAGE TEXTURES NB; '.png'
            		img=d.entities.add_image(File.join(fj, File.basename(name, ".*")+".png"), [-1.mm, -1.mm, 0], 2.mm+bb.width, 2.mm+bb.height)
            		next unless img
            		img.explode
            		t=Geom;;Transformation.new()
                    count.times{
            			d.entities.intersect_with(true, t, d.entities, t, true, d.entities.to_a)
            		} ### repeat to ensure all splits...
            		togos=[]
            		d.entities.each{|e|togos << e if e.valid? and e.is_a?(Sketchup;;Edge) and e.faces.length<2}
            		d.entities.erase_entities(togos)
            		### ENSURE FACES ARE 'UP' & SET LAYERING
            		hidn=model.layers.add("People Outlines")### or whatever name you like!
            		peep=model.layers.add("People Images")### or whatever name you like!
            		d.entities.each{|e|e.reverse! if e.is_a?(Sketchup;;Face) && e.normal!=Z_AXIS; e.layer=hidn if e.is_a?(Sketchup;;Edge); e.layer=peep if e.is_a?(Sketchup;;Face);}
            		### STAND COMPONENT'S CONTENTS TO BE VERTICAL
            		tr=Geom;;Transformation.rotation(ORIGIN, X_AXIS, 90.degrees)
            		d.entities.transform_entities(tr, d.entities.to_a)
            #=begin		### REMOVE ANY 'HOLES'
            		faces=[]
            		d.entities.each{|e|faces << e if e.is_a?(Sketchup;;Face)}
            		(faces.length-1).times{
            		   for face in faces
            			if face.valid?
            			  for edgeuse in face.outer_loop.edgeuses
            				 if not edgeuse.partners[0] ### outermost face
            					faces = faces - [face]
            					loops = face.loops
            					for loop in loops
            					   for fac in faces
            						  if fac.valid? and (fac.outer_loop.edges - loop.edges) == []
            							 faces = faces - [fac]
            							 fac.erase! if fac.valid?
            							 ### fac abutts kept face so it must be erased...
            						  end #if fac
            					   end #for fac
            					end #for loop
            				 end #if outermost
            			  end #for edgeuse
            			end #if valid
            		   end #for face
            		}#times
            #=end
            		### ALL FACES GET MAIN MATERIAL
            		faces=[]
            		mat=nil
            		faces.each{|e|mat=e.material if e.material}
            		faces.each{|e|
            			e.material=mat
            			e.back_material=mat
            		### MOVE ORIGIN TO BOTTOM-CENTER OF OUTLINE
            		tr=Geom;;Vector3d.new(-bb.center.x, 0, 0)
            		### MAKE IT A FACE-ME COMPONENT
            		#d.behavior.always_face_camera=true
            		### FINALLY... SAVE IT INTO 'PEOPLE' AS A' SKP'
            		d.refresh_thumbnail
            		d.save_as(File.join(ff, File.basename(name, ".*")+".skp"))
            	}#names
            	#model.commit_operation
            	puts
            	puts 'Done.'
            	puts
            	return true
            	end#def
            end#module
            NOTE: the image files' PNG and folder names you might want to adjust...
              Lersince1991
              Brilliant thanks TIG, sorry I didnt get back to you - not much free time yesterday.
              Will test today at some point.
              I have also thought of a better solution for matching the images up with the geometry. originally the image and the dwg are the same - the dwg is just live traced from the image. So if I keep the image border the bounding box of the dwg when imported will perfectly match the texture image in sketchup. I originally removed this frame in illustrator but realised this is removed in su anyway and therefore it is making it worse not better ๐Ÿ˜ฎ silly me.
              Just wondering, is there anyway to scale the geometry with constrained proportions to a set height? (ok if not) but at the moment illustrator is sort of a half manual, half automatic process for scaling which takes time.
                Lersince1991
                scrap the scaling ! ๐Ÿ˜„
                Managed to add the scaling in the images (canvas size in photoshop) before it goes to a dwg - I think it will keep its scaling
                  Lersince1991
                  OK TIG!
                  This looks like it could be the last edit! ๐Ÿ˜„ (sorry there was a lot of work!! - I really appreciate it and will make sure I share the work on the warehouse after getting permission from vyonyx)
                  The images are all mapping perfectly now!
                  So the issue is that now I have added a frame from the original jpeg for the bounding box to reference its size correctly to (as notede 2 post ago). I think the could requires editing to delete this external frame as well. At the moment I believe that the following is happening:
                  • The image is made slightly bigger (good as it just makes them a little sharper at least).
                  • The image is exploded and frame removed but as it is 1mm bigger the other frame now in the components is not deleted.
                    Summary - I think we need to add another delete for the outer frame as well as the img exploded frame.
                  Good news is the remove holes seem to be working well! (just inverted at the moment as the second outer frame remains)
                    If you duplicate this code
                          togos=[]
                    immediately after itself... then first time it runs the outer perimeter edges of the original image are deleted - it was actually added 1mm bigger all round than the original outline's size to ensure its edges were separated from the outline's. The second go it erases the 'frame' of the outline so you have the 'real' outline left - frankly this 'frame' seems superfluous to me โ“
                    The potential problem is that if this 'frame' shares any horizontal/vertical short edges [that you will actually want to be kept because they are outlining the desired form] then it simply screws up, because they'll go too and no face loop is left for later processing, AND we have no way of knowing which of these single-faced edges is which... so don't even ask how we can do it... ๐Ÿ˜ฎ
                    If you don't have this 'frame' the result is fine without the second step.
                    Alternatively add the 'frame' as being a discontinuous loop - perhaps just the max-x/y dims on two sides only, which then gets erases in the first run to the perimeter deletion code anyway, because these edges can never have any faces so ..faces.length<2 applies
                    BUT if you must have this continuous looped 'frame', then its edges can only touch the main outline's edges at points, any 'coincident' edges - no matter how short - will get removed in the second run, and then the facing of the discontinuous outline's edge will fail dismally... ๐Ÿ˜•
                      Lersince1991
                      sorry just posted at the same time you did so didnt see the above
                      • The extra frame is to make the bounding box of the component match the texture. As you saw before, because these textures (pngs) are not cut out properly, the bounding box is different to the bounding box of the geometry component. so causing a mis match in the mapping of the texture to the geometry. This solves this.
                      However yes you are right in the fact that this extra frame would mess things up IF the geometry we want to keep is the same. however this only happens when the image is cut off at the edge of the png file. And I don't care for these images as they wont be used. i.e. is you have a person that is cropped off and not whole, I wouldnt put this in a model. Some of the trees do this, but they wouldnt be used anyway and would be deleted.
                      A SOLUTION - if we needed one, i.e. if some of the geometry is the same as the frame.
                      I could extent the canvas size of the original image via photoshop at the start. Hence extending the frame beyond the boundaries of the image we want to keep. ๐Ÿ˜„
                      ๐Ÿ˜„
                      EDIT: Also just noticed the face me code wasnt put in again. Copied this back in ๐Ÿ˜„
                      NOW TO PROCESS THESE! ๐Ÿ˜„ (overnight)
                        Lersince1991
                        EDIT!
                        SORTED TIG, I just copied it again ๐Ÿ˜„
                        heres the final Code.
                        One LAST thing - How easy is it to apply this to a folder of seperate Skp files rather than active components? Onyl because it takes about 15 minutes to process a single component and when they are all (or some of them about 50 or so) in one model it slows down considerably and I would leave it on overnight to do a batch. Probably not necesary but just be interested in your thoughts to improve the processing speed?
                        FINAL CODE:
                        module LukeR
                          def self.importer()
                           defs.purge_unused
                           cnames=[]
                           cnames.sort!
                           fj='P;\02 General\Resource Library\People\PNG' ### for images
                           ff='P;\02 General\Resource Library\Sketchup People' ### for saved SKPs
                           cnames.each{|name|
                              puts name
                              d=defs[name]
                              count=0
                              d.entities.each{|e|
                                 bb.add(e.bounds)
                              next unless img
                              img.explode
                                count.times{
                              togos=[]
                              ### REMOVE outline's UNWANTED PERIMETER
                              togos=[]
                              peep=model.layers.add("People")### or whatever name you like!
                              faces=[]
                                 for face in faces
                                 if face.valid?
                                       loops = face.loops
                                       for loop in loops
                                          for fac in faces
                                            end #if fac
                                          end #for fac
                                       end #for loop
                                     end #if outermost
                                   end #for edgeuse
                                 end #if valid
                                 end #for face
                              }#times
                        #=end
                              faces=[]
                              mat=nil
                              faces.each{|e|
                                 e.material=mat
                                 e.back_material=mat
                              d.refresh_thumbnail
                           }#names
                           puts
                           puts 'Done.'
                           puts
                           return true
                           end#def
                        end#module
                          Lersince1991
                          TIG, this is working perfectly now - I compressed the images a bit more and they import much faster now so thats good.
                          Bar just one more thing:
                          Can we change the axis/origin to the center of the people? at the moment the insertion point when adding the components into SU is a bit below the people by about 150mm or so. Would just be nice to get them to be inserted at the correct level. Got any code for this?
                          Heres the current module:
                          ### usage; Importer.people
                          module Importer
                            def self.people()
                             #model.start_operation("people",true) ### Bugsplats with image.explode !!!
                             defs.purge_unused
                             cnames=[]
                             cnames.sort!
                             cnames.each{|name|
                                puts name
                                d=defs[name]
                                count=0
                                d.entities.each{|e|
                                   bb.add(e.bounds)
                                next unless img
                                img.explode
                                  count.times{
                                togos=[]
                                togos=[]
                                faces=[]
                                   for face in faces
                                   if face.valid?
                                         loops = face.loops
                                         for loop in loops
                                            for fac in faces
                                              end #if fac
                                            end #for fac
                                         end #for loop
                                       end #if outermost
                                     end #for edgeuse
                                   end #if valid
                                   end #for face
                                }#times
                          #=end
                                faces=[]
                                mat=nil
                                faces.each{|e|
                                   e.material=mat
                                   e.back_material=mat
                                d.refresh_thumbnail
                             }#names
                             puts
                             puts 'Done.'
                             puts
                             return true
                             end#def
                          def self.trees()
                             #model.start_operation("trees",true) ### Bugsplats with image.explode !!!
                             defs.purge_unused
                             cnames=[]
                             cnames.sort!
                             fj='P;\02 General\Resource Library\Trees\PNG' ### for images
                             ff='P;\02 General\Resource Library\Sketchup Trees' ### for saved SKPs
                             cnames.each{|name|
                                puts name
                                d=defs[name]
                                count=0
                                d.entities.each{|e|
                                   bb.add(e.bounds)
                                next unless img
                                img.explode
                                  count.times{
                                togos=[]
                                togos=[]
                                hidn=model.layers.add("Tree Outlines")### or whatever name you like!
                                peep=model.layers.add("Trees")### or whatever name you like!
                                faces=[]
                                   for face in faces
                                   if face.valid?
                                         loops = face.loops
                                         for loop in loops
                                            for fac in faces
                                              end #if fac
                                            end #for fac
                                         end #for loop
                                       end #if outermost
                                     end #for edgeuse
                                   end #if valid
                                   end #for face
                                }#times
                          #=end
                                faces=[]
                                mat=nil
                                faces.each{|e|
                                   e.material=mat
                                   e.back_material=mat
                                d.refresh_thumbnail
                             }#names
                             puts
                             puts 'Done.'
                             puts
                             return true
                             end#def
                          end#module
                            This bit of the code moves the component's origin to be at the bottom-center of the image-that's-now-geometry...
                            ### MOVE ORIGIN TO BOTTOM-CENTER OF OUTLINE tr=Geom::Vector3d.new(-bb.center.x, 0, 0) d.entities.transform_entities(tr, d.entities.to_a)
                            At this point we have already stood it up 'on its end'.
                            The 'vector' moves everything across in the 'X', to the center [note how it's a -ve value].
                            To move if down you change the 'Z' value.
                            It can only be easily done by a set distance.
                            So to move everything down in every imported set, by 150mm, we make it this...
                            ### MOVE ORIGIN TO BOTTOM-CENTER OF OUTLINE tr=Geom::Vector3d.new(-bb.center.x, 0, **-150.mm**) d.entities.transform_entities(tr, d.entities.to_a)
                            Note the value's format -150**.**mm because the base-units in SketchUp are inches, so -6 would have a similar result at 6" [actually that is 152.mm]...
                              Lersince1991
                              Nice one thanks, I had an inkling that it would have to be a set value, I'll drop loads in and find the best value to change them to and process again.
                              We are now using these and its working very well. Gets nicer images without a long post-processing in photoshop.
                              Thanks again TIG
                                Lersince1991
                                Processed all the people last night and works REALLY WELL.
                                Thanks again TIG!
                                • 3 / 3
