    Codec incompatible with video size selected? ERROR
    25 Posts 8 Posters 4.2k Views 8 Watching
      samyell77
      Anyone? Stuck on the default now so cant export anything other than 320x240? Any help much appreciated.
      Cheers
      Sam
      SU Pro 2016
      Dell Precision M4800
      PC Windows 10
      Intel Core i7-4900MQ @ 2.80ghz
      Nvidia Quadro K2100M
      16gb RAM
      • E
        Ecuadorian
        Most video codecs require you to stick with dimensions that are either divisible by either 2, 4, or 8.
        Use 1280x720 or 1920x1080, they should work with any codec.
        -Miguel Lescano
          samyell77
          Thanks, have tried all sorts - even tried typing the default 320x240 but get the same error message.
          SU Pro 2016
          PC Windows 10
          16gb RAM
            samyell77
            SU Pro 2016
            PC Windows 10
            16gb RAM
            • E
              Ecuadorian
              Could you please post a screenshot?
              -Miguel Lescano
                samyell77
                Will post one tomorrow - not at my pc now.
                Thanks for comin back. Hope I can get to the bottom of this!
                Cheers
                SU Pro 2016
                PC Windows 10
                16gb RAM
                  samyell77
                  Hi Ecuadorian - couple of screen grabs attached. Just checked and all my video drivers are up to date.
                  Have tried with a couple of sizes that I know are definitely codec compatible - even tried selecting the default setting, then re typing 320x240 and get the same error message?
                  Just had a look at the last few plugins I installed and removed them incase they were causing a conflict - removed them and still the same issue!
                  Going to re-install now cos I need to be able to export. Thanks
                  SU Pro 2016
                  PC Windows 10
                  16gb RAM
                  • GaieusG
                    Sam, I have not commented so far as your profile says you run a Mac but this clearly shows a Windows system. Are you getting this error when trying to export to a video format or have you also tried with image sequence (in which case no codec is needed - well, "normally")
                      samyell77
                      Hi Gai,
                      Sorry - my signature has two systems on it. 1. PC, 2. Mac - have pretty much moved completely to PC now so will amend my signature.
                      Yeah have tried exporting a 2d jpg and no probs - any size available. Unfortunately have had to uninstall now as I need to get this resloved but have just had the same issue occur on a colleagues machine?
                      Would like not to have to completely uninstall on all machines in the studio that would be great...
                      Any thoughts on this much appreciated 😄
                      SU Pro 2016
                      PC Windows 10
                      16gb RAM
                      • GaieusG
                        What I meant was to export the animation to a series of stills (jpg or png). Just select the suitable file format in the animation export window. Then you can put the whole thing together in any video editor.
                        I know it's just a "workaround" for the time being but you may be at lest export what you need to. Just make sure to export the images into a separate folder (they can easily "populate" your desktop)
                          samyell77
                          Sorry Gai - thats what Ive actually been trying to do. Export jpg or tif files to use in a printed document. In my screen shots jpg has been selected as the output format. Im not trying to make an animation just using the 'animation export' to allow me to export every scene (without transitions) as a jpg. So if I have 10 scenes I get 10 jpgs or tifs to use in indesign.
                          Have tried this with the avi export to to see if it will work as a self contained animation but still no dice - same error message!
                          Cheers
                          SU Pro 2016
                          PC Windows 10
                          16gb RAM
                          • GaieusG
                            Sorry but then I am completely stumped. IMO if on exports to image sequence, the codecs should not even be involved at all.
                            I can move the topic to the SU bugs subforum (not that I would hope that anyone will look into it in these days of moving SU from Google to Trimble though)
                              samyell77
                              Yup - figured that would probably be the case. 😠
                              Thanks tho Gai
                              SU Pro 2016
                              PC Windows 10
                              16gb RAM
                                samyell77
                                Just hope a reinstall will sort it out - will post back once I have some news.
                                SU Pro 2016
                                PC Windows 10
                                16gb RAM
                                  samyell77
                                  SU pro trial reinstalled, no plugins loaded and still no joy. Same error persists. 😞
                                  SU Pro 2016
                                  PC Windows 10
                                  16gb RAM
                                  • E
                                    Ecuadorian
                                    I also consider it must be a bug. I have never seen anything like that before.
                                    I guess you'll have to manually export each image. 😕
                                    -Miguel Lescano
                                      samyell77
                                      Hi Gai,
                                      Are you able to move this to the bug forum just in case someone is inclined to look at it?
                                      SU Pro 2016
                                      PC Windows 10
                                      16gb RAM
                                        Macker
                                        Not sure how old this thread is but I've just encountered the exact same problem on a brand new (clean install) windows 8 machine.
                                        Should also note that the problem is specific to that computer, it renders fine on others.
                                        Check out my blog @ http://macviz.blogspot.co.uk
                                          samyell77
                                          Hi Macker,
                                          Cant remember exactly how I resolved it but have just checked my settings in export animation. I think I simply changed the codec to Microsoft Video 1 - thats what I have it set on now and am able to export. Try a few different codecs but that one works for me....
                                          although not sure this is best quality?
                                          Cheers
                                          SU Pro 2016
                                          PC Windows 10
                                          16gb RAM
                                          • W
                                            woldas
                                            YES!! In the save animation dialog box you need to change to .avi format, than in settings change the codec to microsoft Viedo 1, set resolution, close settings box, change to format You desire e.g. .jpeg and VOILA...
