    My plugin work on Windows not on Mac
    18 Posts 6 Posters 945 Views 6 Watching
      The API's weddialog.set_file() is known to fail...
      Put simply set_html() fails under OSX because of a ill contrived Safari update.
      Whereas using set_url() should work on all Platforms.
        Never had any issues with it - on any platform. Example?
          Typo - I meant set_html() 😒
          Doh!
          Hence my reference to it in my next sentence 😕
          Still confused about how that happened... too much Rioja with my Sunday dinner 😮
          • Mike LuceyM
            Mike Lucey
            Ahhhh ..... I know only too well that one Tinto can lead to many 😄
            http://upload.wikimedia.org/wikipedia/commons/thumb/8/82/Rioja_wine_crop_of_ImagePinchos_aperitivo.JPG/220px-Rioja_wine_crop_of_ImagePinchos_aperitivo.JPG
            • X
              xfifi
              I replaced set_file by set_url and i have the same issue (on Mac "empty white" content in webdialog).
                Revert to as it was - didn't you read the posts about my typo?
                Without seeing exactly how you rb interacts with the html/js etc we are stuck... 😕
                • X
                  xfifi
                  Ok I put it back like it was before.
                  I put the full archive of my plugin a few posts above.
                    OK. 😄
                    You are typically using:
                    @wnd_params.execute_script("$('#longueur').val('#{s_longueur}')")
                    to set the 'value' of id=longueur to be s_longueur
                    Try constructing it a different way: perhaps the MAC doesn't like it: perhaps something more like:
                    @wnd_params.execute_script("document.getElementById('longueur').setAttribute('value','#{s_longueur}');")
                    If it's not a 'value' then try something like 'innerHTML' OR 'innerTEXT': e.g.:
                    @wnd_params.execute_script("document.getElementById('longueur').innerHTML='#{s_longueur}');")
                    etc...
                      Not near a Mac to test at the moment. But have you tried with adding ; at the end of each command you execute?
                      (Sidenote, if you use that script in a model with untis settings set to display feet you'll get ' characters that will break your javascript because you're no escaping your string.)
                      (Sitenote 2: 120.cm.to_l the .to_l is redundant as .cm will return a Length object.)
                        TT, well spotted that he has missed a ' **;**' terminating his script string - I missed that - however, it doesn't why it's PC friendly / MAC unfriendly - I recall something about MAC's changing the way 'innerHTML' / 'innerTEXT' worked a few Safari updates ago - perhaps that's the rub? 😕
                          Nah - he's using jQuery. It takes care of all compatibility issues like that. I've used jQuery for several years now and none of them has broken. Certainly not the ones he's using there.
                          • X
                            xfifi
                            First, thank you both try to help me on these issues.
                            Well done for small errors in my code.
                            I added the ";" at the end of javascript strings and i changed the code as :
                            @wnd_params.execute_script("$('#longueur').val(#{s_longueur.inspect});") to escape ' and " characters
                            I don't have a Mac at hand either. I have to wait for a Mac user have the time to try my corrections and then give me the result.
                              driven
                              if I change the rubies encoding to uft8 and I zapp the gremlins I get this which shows the css for font size is not good. use ems
