    How to get the absolute coordinates of faces?
    7 Posts 4 Posters 2.7k Views 4 Watching
    • lbsswuL Offline
      lbsswu
      I want to get the absolute center coordinates of faces. But I find the coordinates are affected by the edit mode. Two images in the attachment is an illustration. The first image shows model in edit mode, while the second does not. My goal is to get the absolute coordinate of the center of the red face. However, in the first image, the center is Point3d(-9.0624, -22.0221, 63.6455); in the second image, the center is Point3d(-0.178652, -0.258835, 1.39058).
      The first coordnate is what I wanted. But this required me to use mouse to clik the model several times. Could anyeone tell me if there are some methods to get the absolute coordinate without mouse clik?
        I assume you have somehow got the center of the face inside its 'context' - let's call it pt.
        You have a reference to the face's 'container' [a group or instance].
        You can get the transformation of that - e.g. tr=instance.transformation.
        You can apply a transformation to a point thus:
        pt.transform!(tr)
        You can also do the inverse - e.g. you have a point outside of the context and want to convert it as if it's inside the context...
        pt.transform!(tr.inverse)
        I'm unsure about which way round you want to do this, but somewhere in this is your answer...
          Anton_S
          Here's what I've got.
          def self.currentPos(parent, child_pos) #Get the position of the point relative to parent's transformation
              return child_pos unless (parent.class == Sketchup;;Group) and (parent.class == Sketchup;;ComponentInstance)
              tra = parent.transformation.origin.to_a
              xaxis = parent.transformation.xaxis.to_a
              yaxis = parent.transformation.yaxis.to_a
              zaxis = parent.transformation.zaxis.to_a
              # my experimented formule
              external_pos[x] = tra[0] + child_pos[0]*xaxis[0] + child_pos[1]*yaxis[0] + child_pos[2]*zaxis[0]
              external_pos[y] = tra[1] + child_pos[0]*xaxis[1] + child_pos[1]*yaxis[1] + child_pos[2]*zaxis[1]
              external_pos[z] = tra[2] + child_pos[0]*xaxis[2] + child_pos[1]*yaxis[2] + child_pos[2]*zaxis[2]
              #external_pos = child_pos.transform(parent.transformation).to_a #alternative sketchup formula
              return external_pos
          Copy to editor to unwrap the code lines.
          It basically shows how that transform formula works
          By the way If you have sketchy physics, you can see play with something similiar here: Navigation System
          • lbsswuL Offline
            lbsswu
            pt.transform!(tr)
            I split my 3D car model in several parts, e.g. door, wheel, etc. I want to locate their center no matter the user change the view point.
            Use the top of the car as an example, I built a "car_top" group, and used the group as a container, but still did not get the correct coordinate.
            • lbsswuL Offline
              lbsswu
              >     return external_pos
              > end
              Thanks for your code. But I still did not get the coordinate that I want, the return coordinate is equal to the child's coordinate. The type of the child is Sketchup::Face, and the type of its parent is Sketchup::ComponentDefinition. I made a group like this:
              model = Sketchup.active_model;
              groups = [];
              model.definitions.each{|d| groups << d if d.group? }
              entities = model.entities;
              selection = model.selection;
              pgrp = [];
              groups.each{|d| pgrp << d.instances[0] if d.instances[0].name=="car_top" }
              tmpents = pgrp[0].entities;
              #print pgrp[0]
              faces = tmpents.find_all{|entity|entity.class==Sketchup;;Face}
              ctr = faces[8].bounds.center
              print ctr
              pos = self.currentPos(pgrp[0], ctr)
              print pos
              pgrp[0] is a group that contain faces[8]. May be there are some bugs...
                Anton_S
                Sorry, rewritten it with errors. 😳 Here's a better version:
                def currentPos(parent, child_pos) #Get the position of the point relative to parent's transformation
                  return false if (parent.class != Sketchup;;Group) and (parent.class != Sketchup;;ComponentInstance)
                  external_pos = Array.new(3)
                  external_pos[0] = tra[0] + child_pos[0]*xaxis[0] + child_pos[1]*yaxis[0] + child_pos[2]*zaxis[0]
                  external_pos[1] = tra[1] + child_pos[0]*xaxis[1] + child_pos[1]*yaxis[1] + child_pos[2]*zaxis[1]
                  external_pos[2] = tra[2] + child_pos[0]*xaxis[2] + child_pos[1]*yaxis[2] + child_pos[2]*zaxis[2]
                  #external_pos = child_pos.transform(parent.transformation).to_a # alternative sketchup formula
                  return external_pos
                Copy to nowpad++ to unwrap all lines
                Note its no more self.currentPos, its just currentPos
                • liquid98L Offline
                  liquid98
                  Hi Ibswu,
                  Check this:
                  http://sketchucation.com/forums/viewtopic.php?f=180&t=48769
                  -- Liquid
                  Things that flourish fall into decay. This is not-Tao, And what is not-Tao soon ends ~ Lao tse
