    Can you get a list of OSX fonts somehow?
    110 Posts 6 Posters 24.3k Views 6 Watching
    • Dan RathbunD Offline
      Dan Rathbun
      @dan rathbun said:
      @driven said:
      what i was musing, was, is there a way to have SU make one, return true, make next, return true, then next, etc... so each operation is a single font...
      Set chunk = 1
      I really meant, set:
      chunksize = 1
      I'm not here much anymore.
        Dan Rathbun
        It is very bad to modify base classes. (spanky spanky)
        This should do the job:
        chunksize = 12
        chunk = 1
        limit = macFonts.length
        model = Sketchup.active_model
        fsize = 1.0
        linespacing = 1.2
        bold = true
        italic = false
        thick = 0.05
        filled = true
        quality = 0.0
        i = 0
        while i < limit
          begin
            model.start_operation("3D Fontnames (#{chunk})")
              chunksize.times do |n|
                break if i == limit
                item = macFonts[i]
                grp = model.entities.add_group()
                grp.entities.add_3d_text( "#{item}", TextAlignCenter, "#{item}",
                  bold, italic, fsize, quality, 0.0, filled, thick )
                grp.name= item
                grp.move!( Geom;;Transformation.new(Geom;;Vector3d.new(0,-(i*linespacing),0)) )
                i += 1
              end # chunk
            model.commit_operation()
          rescue Exception => e
            puts("\n*** macFonts group Error! ***")
            puts("  i = #{i}")
            puts("  chunk = #{chunk}")
            puts("  font = #{macFonts[i]}\n")
            model.abort_operation()
            puts("Error #<#{e.class.name}; #{e.message}>")
            puts(e.backtrace) if $VERBOSE
            raise
          chunk += 1
        end # while
        EDIT: Added a few Exception messages, and option vars before iteration.
        EDIT(2): Added linespacing var.
          Dan Rathbun
          EDIT(2) previous code post: Added linespacing var.
            driven
            cheers again,
            linespacing is a nice touch.
            all the code runs, returns nil. then draws view with the new groups, changing chuncksize doesn't alter that.
            it doesn't take too long.
            only two fonts don't fully form, may be the size, but not bad really.
            so, the main purpose was to check that the osascript fonts were the right one, and they are...
            and I learnt a little ruby
            thanks dan
              Dan Rathbun
              It occurs to me that because the fontsize is only 1 inch, that many arc segments are ridiculously small, perhaps overloading the SketchUp engine.
              Try setting:
              fsize = 1.0.feet linspacing = 1.25.feet
                driven
                Yeh, I tried that, didn't make a lot of difference,
                I use 100 and 120
                fsize needs to be in inches, doesn't it?a sample of the sample
                  Dan Rathbun
                  1.0.feet will return a Length object == 12"
                    driven
                    I missed the dot... oops should stick to copy/paste
                      I tried this:
                      <span class="syntaxdefault"><br />t</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">Time</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">now<br />&nbsp;&nbsp;&nbsp;&nbsp;macFonts</span><span class="syntaxkeyword">=[]<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">macFonts</span><span class="syntaxkeyword">=(`</span><span class="syntaxstring">osascript&nbsp;-e&nbsp;'tell&nbsp;application&nbsp;"Font&nbsp;Book"&nbsp;to&nbsp;set&nbsp;macFonts&nbsp;to&nbsp;name&nbsp;of&nbsp;every&nbsp;font&nbsp;family'</span><span class="syntaxkeyword">`).</span><span class="syntaxdefault">split</span><span class="syntaxkeyword">(</span><span class="syntaxstring">","</span><span class="syntaxkeyword">).</span><span class="syntaxdefault">uniq</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each&nbsp;</span><span class="syntaxkeyword">{|</span><span class="syntaxdefault">a</span><span class="syntaxkeyword">|&nbsp;</span><span class="syntaxdefault">a</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">strip</span><span class="syntaxkeyword">!&nbsp;if&nbsp;</span><span class="syntaxdefault">a</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">respond_to</span><span class="syntaxkeyword">?&nbsp;;</span><span class="syntaxdefault">strip</span><span class="syntaxkeyword">!&nbsp;}.</span><span class="syntaxdefault">sort<br />&nbsp;&nbsp;&nbsp;&nbsp;quitFontBook</span><span class="syntaxkeyword">=(`</span><span class="syntaxstring">osascript&nbsp;-e&nbsp;'tell&nbsp;application&nbsp;"Font&nbsp;Book"&nbsp;to&nbsp;quit'</span><span class="syntaxkeyword">`)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;if&nbsp;</span><span class="syntaxdefault">macFonts</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">length&nbsp;</span><span class="syntaxkeyword">>&nbsp;</span><span class="syntaxdefault">1<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;then&nbsp;quitFontBook<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;end<br />&nbsp;&nbsp;&nbsp;&nbsp;macFonts</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">length<br />puts&nbsp;Time</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">now</span><span class="syntaxkeyword">-</span><span class="syntaxdefault">t<br /></span>
                      On the first run it yielded 8.500629 seconds.
                      The next was 2.422791 and 2.286048 seconds.
                      If I comment out the code the closes Font Book the times are 0.241677 and 0.228576.
                      So the overhead of launching Font Book is just all too high.
                        driven
                        but you only need to run once, and write the 'Users' personal font-list to file [save in TT-Lib]
                        if the User instals new fonts [very rare] they could delete the file and make a new one, or that could be an option?
                          That could be a fallback. But I'm still hoping to find a method that works quickly which I can use. the fc-list is fast - it's just that I cannot get the output from that. ..and for some reason I cannot seem to direct the output to a file... Maybe one can trigger a new console command that might actually be able to write to file?
                          • TIGT Online
                            But this is bringing us full circle πŸ˜•
                            You might as well try to use something like:
                            fonts_file="\"path/to/fonts.txt\"" system(fc-list : file family | grep /Library > fonts_file)
                            Or something similar ? #{fonts_file} ??... Whatever can be made to work !
                            Or even a more convoluted
                            UI.openURL('file:///'+commandfilepath)
                            And then read the ttf-font names from the fonts_file πŸ˜•
                            There is a simple solution [KISS]...
                            In my own [far less sophisticated] '2dText' tool and some of my similar tools like 'AreaTextTag', which make 3dText as '2d flat editable text', my drop-down-list of the available fonts is simply a combined list of some ttf fonts that are usually shipped with recent PCs A_N_D MACs.
                            For the reduced list in the AreaTextTag it a simple array of a reduced list, typed in the code that the user can customize. In the more wide-ranging 2dText tool it's read in a simple txt text file ['2DtextTool_Fonts.txt' in the tool's subfolder] of the 44 common font-names - the user can edit this [there are instructions in the tool's Help] - either to remove unwanted ones [e.g. in case he doesn't use 'Wingdings' very much], or to add custom one he has also installed on his computer [like 'Architext' or 'Consolas'] that are not in the default combo list... This allows the user to have their own customized fonts list and it's not that hard to alter/update/customize either... πŸ˜•
                              Dan Rathbun
                              Other option(s):
                              (a) Use UI.openpanel to let users manually pick font files, that are then added to the plugin's fontlist (kept as a hash file in the plugin's folder. The file distro's with a base set of standard Mac fonts.)
                              (b) Use the SDK and C/C++/Objective-C to get the list of Fonts Sketchup knows.
                              (From memory, I do think Sketchup's known fonts is exposed in the SDK.)
                                driven
                                I've found the KISS Applescript version, just figuring out if it's easier to strip the results first or in ruby.
                                the basic can then run as osascript...
                                set search1 to do shell script "mdfind -onlyin /Library/Fonts 'kMDItemContentTypeTree = \"public.truetype-ttf-font\"'" as text
                                set search2 to do shell script "mdfind -onlyin ~/Library/Fonts 'kMDItemContentTypeTree = \"public.truetype-ttf-font\"'" as text
                                results look like this
                                %(#0000FF)[/Library/Fonts/NISC18030.ttf
                                /Library/Fonts/Kai.ttf
                                /Library/Fonts/Hei.ttf
                                /Library/Fonts/BiauKai.ttf
                                /Library/Fonts/Apple LiSung Light.ttf
                                /Library/Fonts/Apple LiGothic Medium.ttf
                                /Library/Fonts/Microsoft/Lucida Console.ttf
                                /Library/Fonts/Microsoft/Candara Bold Italic.ttf]
                                also, I think if a plugins is offering font manipulation for artistic usage, it should have all the 'SU' fonts and let the User decide which to use
                                  So that returns the filenames, but do the filenames represent the font names exactly?
                                  I know that I would not be able to do that with the fonts on a Windows machine as they usually are abbreviations.
                                    Dan Rathbun
                                    XP
                                    %(#004080)[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Fonts]
                                    • TIGT Online
                                      I suspect that the ttf file name is not always the font name πŸ˜’
                                      MAC's 'fc-list' will provide the font-name, font-family etc -
                                      I can't believe that 'we' can't get it to write the list to a variable using system(...) πŸ˜•
                                      Have you tried something like this?
                                      font_list=system(fc-list : family | cat)
                                      or similar, where the output gets piped to something that can return a value like 'cat' ?
                                      OR perhaps:
                                      font_list=system(cat (fc-list : family))
                                      OR probably with 'escaped' (), more like:
                                      πŸ˜•
                                        Yea, I wish I knew why this is mis-behaving inside SketchUp. πŸ˜•
                                        • TIGT Online
                                          Have you tried any of my 'convolutions', to redirect / pipe its output to some other function that then might successfully return the values to 'system' ?
                                          As it does several 'lines' of output in the console can we pipe it through a loop ?
                                          Or like font_list=system(cat ($(fc-list : family)))
                                          Perhaps with some \ escaping of the various () ???
                                            Not the recent ones. I only have access to a Mac at home, and last week I haven't been home for very long - certainly no time to test anything. 😞
                                            • 3 / 6
