    Model.import not working for newbie.
    13 Posts 7 Posters 816 Views 7 Watching
      Can you post sample 3ds model?
        jprisbe
        3ds file uploaded.
        B473.zip
          Jim
          Worked fine for me.. The import is not automatically placed in the model, instead it is attached to the cursor where you need to place it by clicking.
          True, the summary dialog did not appear.
          • TIGT Online
            If you import a 3ds file from the menu there is no summary dialog either, so the argument as true/false in the scripted method is irrelevant as it's ignored and there never is one !
            Some importers use that option, 3ds does not...
            It works just as the menu version and imports using the last used Options values, like 'units'...
            Incidentally your code includes a closing model.commit_operation but there is no matching model.start_operation("Import3ds") near the start πŸ˜•
              jprisbe
              Still doesn't work for me. There is nothing attached to my cursor.
              • TIGT Online
                Works fine for me... πŸ˜•
                • timberlineT Offline
                  timberline
                  Would this work in the 'free' version of SU or only the 'pro' version?
                    Yes, it would (or at least should)
                    • Chris FullmerC Offline
                      I haven't looked much into this, but it won't work on file formats that SketchUp free does not support, like dwg.
                        timberline
                        So, the free version only has the interfaces GUI blocked for say DXF import, but I could get around that programmically by providing a ruby plug-in or C++ code?
                        Is there a plug-in for adding back the import functionality that was removed?
                          Try these:
                          http://forums.sketchucation.com/viewtopic.php?t=31186
                          or
                          http://sketchucation.com/forums/viewtopic.php?t=22199
                            timberline
                            Thanks, That plug-in will do nicely. I have imported a test file and it worked well.
