    How can I create this shape?
    18 Posts 5 Posters 988 Views 5 Watching
      lbourdo
      Thanks for the reply Jean. Great file tutorial.
      However when I try to recreate it I get an error saying that my two solids I am wanting to intersect are not solids and it won't work?
      Ideas as to why?
      Thanks,
      Lorne
        lbourdo
        Never mind I figured it out. I'll keep playing with it. It is really hard to get this to look right, but I don't know other software. I'll post what I finally come up with. I am trying to layout a bowl to cut in layers on a laser cutter and then sand it all smooth.
        Thanks,
        Lorne
          How this modern bowl stay in place ?
          Have you a bottom view ?
          (I suppose the Jean file is not V6 πŸ’š
          • boofredlayB Offline
            boofredlay
            It is probably a perfectly balanced bowl. And it is about time you upgrade Frenchy πŸ’š
            • Jean LemireJ Offline
              Jean Lemire
              Hi Pilou, hi folks.
              V6
              Modern bowl - V6.skp
                lbourdo
                Yea I was wondering that too, so what I'm gonna do just leave the bottom a little flat when I cut it out in slices. Then glue all the wood rings/slices together and sand smooth for a nice finish. It's going to be a centerpiece/fruit bowl for a christmas gift.
                  Thx Jean! 😎
                  The original πŸ˜„ by Ane Christensen 1700 € (Silver)
                  Seems I will use arc circles + curviloft or extrude edges
                    lbourdo
                    So I modeled the silver bowl and didn't really like it. I know after all that! But I did learn a lot so thanks!
                    Here are the two I came up with.
                    I will post pictures when I cut, glue, sand, and finish the final product!
                    Thanks,
                    Lorne
                    • pbacotP Offline
                      You'll want to give those thickness with Joint Push-Pull ruby or Perhaps shell ruby.
                        lbourdo
                        thanks pbacot,
                        I tried joint/push pull but it left little wedges in between each surface. But I plan to layout each 1/4" cut for the laser cutter in Revit so it'll be fine for it's purpose then I'll be able to get each layer's shape.
                        Thanks for the tips!
                        Lorne
