    How can I create this shape?
    18 Posts 5 Posters 1.0k Views 5 Watching
    • pbacotP
      Pretty nice, Boo! Now if you'll just post the files, we'll all send in our requests.
      • L
        lbourdo
        Boo,
        that's awesome thanks. How do you get rid of the faceted edges once I make my shape?
        The help plugin documentation isn't very good.
        THanks,
        Lorne
        • Jean LemireJ
          Jean Lemire
          Hi Lorne, hi folks.
          If you want to practice with SketchUp (SU) native tools, click in sequence on the scenes tabs of this SU file for ideas:
          Modern bowl.skp
          • boofredlayB
            boofredlay
            @jean lemire said:
            Hi Lorne, hi folks.
            Well done Jean.
            @lbourdo said:
            Boo,
            THanks,
            Lorne
            I just edited the shapes and used the erase tool while holding the control key. This will soften/smooth the edges.
            • L
              lbourdo
              Thanks for the reply Jean. Great file tutorial.
              However when I try to recreate it I get an error saying that my two solids I am wanting to intersect are not solids and it won't work?
              Ideas as to why?
              Thanks,
              Lorne
              • L
                lbourdo
                Never mind I figured it out. I'll keep playing with it. It is really hard to get this to look right, but I don't know other software. I'll post what I finally come up with. I am trying to layout a bowl to cut in layers on a laser cutter and then sand it all smooth.
                Thanks,
                Lorne
                  How this modern bowl stay in place ?
                  Have you a bottom view ?
                  (I suppose the Jean file is not V6 πŸ’š
                  • boofredlayB
                    boofredlay
                    It is probably a perfectly balanced bowl. And it is about time you upgrade Frenchy πŸ’š
                    • Jean LemireJ
                      Jean Lemire
                      Hi Pilou, hi folks.
                      V6
                      Modern bowl - V6.skp
                      • L
                        lbourdo
                        Yea I was wondering that too, so what I'm gonna do just leave the bottom a little flat when I cut it out in slices. Then glue all the wood rings/slices together and sand smooth for a nice finish. It's going to be a centerpiece/fruit bowl for a christmas gift.
                          Thx Jean! 😎
                          The original πŸ˜„ by Ane Christensen 1700 € (Silver)
                          Seems I will use arc circles + curviloft or extrude edges
                          • L
                            lbourdo
                            So I modeled the silver bowl and didn't really like it. I know after all that! But I did learn a lot so thanks!
                            Here are the two I came up with.
                            I will post pictures when I cut, glue, sand, and finish the final product!
                            Thanks,
                            Lorne
                            • pbacotP
                              You'll want to give those thickness with Joint Push-Pull ruby or Perhaps shell ruby.
                              • L
                                lbourdo
                                thanks pbacot,
                                I tried joint/push pull but it left little wedges in between each surface. But I plan to layout each 1/4" cut for the laser cutter in Revit so it'll be fine for it's purpose then I'll be able to get each layer's shape.
                                Thanks for the tips!
                                Lorne
