    [Code] Grepping entities
    19 Posts 6 Posters 3.0k Views 6 Watching
    • Chris FullmerC
      Looks like its a bit faster from what I can tell. Here's the test I ran.
      Model of 90,090 edges, 35,035 faces, and 4004 groups.
      The code:
      edges = []
      t = Time.now
      Sketchup.active_model.entities.each do |e|
      if e.is_a? Sketchup;;Edge
      edges << e #Optional line
      puts Time.now-t
      edges = []
      t = Time.now
      edges = Sketchup.active_model.entities.grep(Sketchup;;Edge)
      puts Time.now-t
      The results:
      This is the results when the first section of code actually builds an array of edges
      0.159
      0.048
      This is the results when the first section of code does nothing, merely iterates over the entire collection.
      0.1
      0.05
      Anyhow, its at least 2x faster from what I saw. Anyone else?
        @tig said:
        It would need to be something like:
        fs=Sketchup.active_model.entities.grep(Sketchup::Face).select{|f|f.material}
        to get an array of all faces that have a material assigned to them etc.
        But then you do a double iteration. I'd think it's be best to do this as:
        fs=Sketchup.active_model.entities.select{|f|f.is_a?(Sketchup::Face) && f.material}
        That's just one iteration.
          Test script:
          <span class="syntaxdefault"><br />model&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model<br /><br />num_edges&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">grep</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Edge</span><span class="syntaxkeyword">).</span><span class="syntaxdefault">size<br /><br />puts&nbsp;</span><span class="syntaxstring">"===&nbsp;Select&nbsp;Entities&nbsp;by&nbsp;Type&nbsp;==="<br /></span><span class="syntaxdefault">puts&nbsp;</span><span class="syntaxstring">">&nbsp;#{model.active_entities.length}&nbsp;entities&nbsp;in&nbsp;the&nbsp;active&nbsp;context."<br /></span><span class="syntaxdefault">puts&nbsp;</span><span class="syntaxstring">">&nbsp;#{num_edges}&nbsp;edges&nbsp;in&nbsp;the&nbsp;active&nbsp;context."<br /><br /></span><span class="syntaxdefault">puts&nbsp;</span><span class="syntaxstring">"\n---&nbsp;#select{}&nbsp;---"<br /></span><span class="syntaxdefault">10.times&nbsp;</span><span class="syntaxkeyword">{<br />&nbsp;&nbsp;</span><span class="syntaxdefault">GC</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">start<br />&nbsp;&nbsp;t</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">Time</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">now<br />&nbsp;&nbsp;edges&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">select</span><span class="syntaxkeyword">{&nbsp;|</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">|&nbsp;</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">is_a</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Edge</span><span class="syntaxkeyword">)&nbsp;}<br />&nbsp;&nbsp;</span><span class="syntaxdefault">puts&nbsp;Time</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">now</span><span class="syntaxkeyword">-</span><span class="syntaxdefault">t<br /></span><span class="syntaxkeyword">}<br /><br /></span><span class="syntaxdefault">puts&nbsp;</span><span class="syntaxstring">"\n---&nbsp;#grep&nbsp;---"<br /></span><span class="syntaxdefault">10.times&nbsp;</span><span class="syntaxkeyword">{<br />&nbsp;&nbsp;</span><span class="syntaxdefault">GC</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">start<br />&nbsp;&nbsp;t</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">Time</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">now<br />&nbsp;&nbsp;edges&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">grep</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Edge&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;</span><span class="syntaxdefault">puts&nbsp;Time</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">now</span><span class="syntaxkeyword">-</span><span class="syntaxdefault">t<br /></span><span class="syntaxkeyword">}<br /><br /></span><span class="syntaxdefault">puts&nbsp;</span><span class="syntaxstring">"\n---&nbsp;for&nbsp;in&nbsp;---"<br /></span><span class="syntaxdefault">10.times&nbsp;</span><span class="syntaxkeyword">{<br />&nbsp;&nbsp;</span><span class="syntaxdefault">GC</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">start<br />&nbsp;&nbsp;t</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">Time</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">now<br />&nbsp;&nbsp;edges&nbsp;</span><span class="syntaxkeyword">=&nbsp;[]<br />&nbsp;&nbsp;for&nbsp;</span><span class="syntaxdefault">e&nbsp;in&nbsp;model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_entities<br />&nbsp;&nbsp;&nbsp;&nbsp;edges&nbsp;</span><span class="syntaxkeyword"><<&nbsp;</span><span class="syntaxdefault">e&nbsp;</span><span class="syntaxkeyword">if&nbsp;</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">is_a</span><span class="syntaxkeyword">?(&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Edge&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;</span><span class="syntaxdefault">end<br />&nbsp;&nbsp;puts&nbsp;Time</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">now</span><span class="syntaxkeyword">-</span><span class="syntaxdefault">t<br /></span><span class="syntaxkeyword">}<br />&nbsp;</span><span class="syntaxdefault"></span>
          Results:
          ` === Select Entities by Type ===
          497078 entities in the active context.
          474629 edges in the active context.
          --- #select{} ---
          0.452
          0.281
          0.281
          0.281
          0.28
          0.281
          0.28
          0.281
          0.265
          0.281
          --- #grep ---
          0.14
          0.156
          0.156
          0.141
          0.14
          0.14
          0.156
          0.156
          0.156
          0.156
          --- for in ---
          0.297
          0.297
          0.296
          0.281
          0.28
          0.281
          0.281
          0.297
          0.297
          0.296`
          I'm seeing similar results as Chris - 80%-90% faster with grep when you only need one type of entities.
            Jim
            Wow, nice improvement. You should add a link from the Optimizations topic to here.
            404 Not Found
            (sketchucation.com)
              Further test - just to see how select scales with multiple entities:
              <span class="syntaxdefault"><br />model&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model<br /><br />num_edges&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">grep</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Edge</span><span class="syntaxkeyword">).</span><span class="syntaxdefault">size<br /><br />puts&nbsp;</span><span class="syntaxstring">"===&nbsp;Select&nbsp;Entities&nbsp;by&nbsp;Type&nbsp;==="<br /></span><span class="syntaxdefault">puts&nbsp;</span><span class="syntaxstring">">&nbsp;#{model.active_entities.length}&nbsp;entities&nbsp;in&nbsp;the&nbsp;active&nbsp;context."<br /></span><span class="syntaxdefault">puts&nbsp;</span><span class="syntaxstring">">&nbsp;#{num_edges}&nbsp;edges&nbsp;in&nbsp;the&nbsp;active&nbsp;context."<br /><br /></span><span class="syntaxdefault">puts&nbsp;</span><span class="syntaxstring">"\n---&nbsp;#select{}&nbsp;---"<br /></span><span class="syntaxdefault">10.times&nbsp;</span><span class="syntaxkeyword">{<br />&nbsp;&nbsp;</span><span class="syntaxdefault">GC</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">start<br />&nbsp;&nbsp;t</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">Time</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">now<br />&nbsp;&nbsp;edges&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">select</span><span class="syntaxkeyword">{&nbsp;|</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">|&nbsp;</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">is_a</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Edge</span><span class="syntaxkeyword">)&nbsp;}<br />&nbsp;&nbsp;</span><span class="syntaxdefault">puts&nbsp;Time</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">now</span><span class="syntaxkeyword">-</span><span class="syntaxdefault">t<br /></span><span class="syntaxkeyword">}<br /><br /></span><span class="syntaxdefault">puts&nbsp;</span><span class="syntaxstring">"\n---&nbsp;#grep&nbsp;---"<br /></span><span class="syntaxdefault">10.times&nbsp;</span><span class="syntaxkeyword">{<br />&nbsp;&nbsp;</span><span class="syntaxdefault">GC</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">start<br />&nbsp;&nbsp;t</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">Time</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">now<br />&nbsp;&nbsp;edges&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">grep</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Edge&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;</span><span class="syntaxdefault">puts&nbsp;Time</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">now</span><span class="syntaxkeyword">-</span><span class="syntaxdefault">t<br /></span><span class="syntaxkeyword">}<br /><br /></span><span class="syntaxdefault">puts&nbsp;</span><span class="syntaxstring">"\n---&nbsp;for&nbsp;in&nbsp;---"<br /></span><span class="syntaxdefault">10.times&nbsp;</span><span class="syntaxkeyword">{<br />&nbsp;&nbsp;</span><span class="syntaxdefault">GC</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">start<br />&nbsp;&nbsp;t</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">Time</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">now<br />&nbsp;&nbsp;edges&nbsp;</span><span class="syntaxkeyword">=&nbsp;[]<br />&nbsp;&nbsp;for&nbsp;</span><span class="syntaxdefault">e&nbsp;in&nbsp;model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_entities<br />&nbsp;&nbsp;&nbsp;&nbsp;edges&nbsp;</span><span class="syntaxkeyword"><<&nbsp;</span><span class="syntaxdefault">e&nbsp;</span><span class="syntaxkeyword">if&nbsp;</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">is_a</span><span class="syntaxkeyword">?(&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Edge&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;</span><span class="syntaxdefault">end<br />&nbsp;&nbsp;puts&nbsp;Time</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">now</span><span class="syntaxkeyword">-</span><span class="syntaxdefault">t<br /></span><span class="syntaxkeyword">}<br /><br /></span><span class="syntaxdefault">puts&nbsp;</span><span class="syntaxstring">"\n---&nbsp;#select{}&nbsp;Edge&nbsp;or&nbsp;Face&nbsp;---"<br /></span><span class="syntaxdefault">10.times&nbsp;</span><span class="syntaxkeyword">{<br />&nbsp;&nbsp;</span><span class="syntaxdefault">GC</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">start<br />&nbsp;&nbsp;t</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">Time</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">now<br />&nbsp;&nbsp;edges&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">select</span><span class="syntaxkeyword">{&nbsp;|</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">|&nbsp;</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">is_a</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Edge</span><span class="syntaxkeyword">)&nbsp;||&nbsp;</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">is_a</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Face</span><span class="syntaxkeyword">)&nbsp;}<br />&nbsp;&nbsp;</span><span class="syntaxdefault">puts&nbsp;Time</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">now</span><span class="syntaxkeyword">-</span><span class="syntaxdefault">t<br /></span><span class="syntaxkeyword">}<br /><br /></span><span class="syntaxdefault">puts&nbsp;</span><span class="syntaxstring">"\n---&nbsp;#select{}&nbsp;Face&nbsp;or&nbsp;Edge&nbsp;---"<br /></span><span class="syntaxdefault">10.times&nbsp;</span><span class="syntaxkeyword">{<br />&nbsp;&nbsp;</span><span class="syntaxdefault">GC</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">start<br />&nbsp;&nbsp;t</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">Time</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">now<br />&nbsp;&nbsp;edges&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">select</span><span class="syntaxkeyword">{&nbsp;|</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">|&nbsp;</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">is_a</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Face</span><span class="syntaxkeyword">)&nbsp;||&nbsp;</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">is_a</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Edge</span><span class="syntaxkeyword">)&nbsp;}<br />&nbsp;&nbsp;</span><span class="syntaxdefault">puts&nbsp;Time</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">now</span><span class="syntaxkeyword">-</span><span class="syntaxdefault">t<br /></span><span class="syntaxkeyword">}<br />&nbsp;</span><span class="syntaxdefault"></span>
              Results:
              --- #select{} ---
              0.27
              0.27
              0.26
              0.26
              0.26
              0.26
              0.27
              0.27
              0.26
              0.26
              --- #grep ---
              0.15
              0.15
              0.15
              0.15
              0.15
              0.15
              0.16
              0.15
              0.16
              0.15
              --- for in ---
              0.29
              0.28
              0.29
              0.28
              0.28
              0.28
              0.28
              0.28
              0.29
              0.29
              --- #select{} Edge or Face ---
              0.28
              0.28
              0.28
              0.27
              0.29
              0.28
              0.29
              0.28
              0.281
              0.28
              --- #select{} Face or Edge ---
              0.37
              0.37
              0.38
              0.38
              0.38
              0.38
              0.37
              0.37
              0.37
              0.37`
                Notice when I select Edges and Faces it matters what I test for first. The whole collection of entities is nearly all edges. If I test for them first it's just about as fast as just selecting edges - because of short-circuiting.
                But if I test for faces first - which there isn't any of then there's a penalty.
                So test for the most likely cause first!
                • Dan RathbunD
                  Dan Rathbun
                  How about this ?
                  fs=Sketchup.active_model.entities.grep(Sketchup::Face){|f| f.material ? f : nil }.compact
                  compact removes the nil elements afterward.
                  I'm not here much anymore.
                    Again - a second iteration. Of the result, but none the less - an extra iteration.
                    What's interesting here is what the performance is.
                      I've looked st a couple of methods in Vertex Tools - where I refactored them to use grep in combo with hashes and I'm getting huge improvements! 😄
                      • dkendigD
                        dkendig
                        Glad I got frustrated on Wednesday and started throwing stuff at the wall to see what stuck! Nice benchmarks Thomthom, hope my find can help some folks out!
                        Devin Kendig
                        Developer
                        • dkendigD
                          dkendig
                          Dan, did you try benchmarking your pattern? It might not have much of a performance hit if you have the extra filtering criteria in the grep block:
                          Don’t forget the extra processing — a map operation — comes “free” if you provide grep with a block
                          404 Not Found
                          (www.globalnerdy.com)
                          Devin Kendig
                          Developer
                          • Dan RathbunD
                            Dan Rathbun
                            No, but it can be added to TT's code above if your interested. (As TT said compact() needs to re-iterate the array to remove the nil elements. I tried using next but the block still returns a nil.)
                            And BTW.. I checked the C source for compact() which uses dup() to create a new array, and then calls compact!(), ie %(#008080)[rb_compact_bang()] on the C-side, so to save time, this pattern might as well use the "bang" edition of the method, and save the time to create a new array.
                            I'm deep into a Javascript mod for the forums, presently, and not doing much in Ruby.
                              Can you post your result data as well?
                                And what was the comparison code?
                                • dkendigD
                                  dkendig
                                  drawing_ele_test time: 0.00999999046325684, resulted in 1103 elements found
                                  types_test time: 0.00999999046325684, resulted in 1103 elements found
                                  magic_test time: 0.0420000553131104, resulted in 1103 elements found
                                  loop_test time: 0.0190000534057617, resulted in 1103 elements found
                                  that's my results from the huge one-liner that I copy and pasted for a scene with 13108 total entities. 10,000 edges, 1,000 component instances, 1,000 groups, 1,000 faces. The goal was to find anything that could have a material applied to it, so I wanted to filter out edges.
                                  So actually it appears my test was flawed. I'm adding entities to a hash, and looping through the desired types in the "types_test" results. In the "drawing_ele_test" I am just doing a comparison to see if the type matches one of the types I am looking for. They both end up taking the same exact amount of time, so there's probably a cleaner way to write this, but under the hood both of those tests are essentially doing the same thing.
                                  Devin Kendig
                                  Developer
                                  • dkendigD
                                    dkendig
                                    Just ran a benchmark in a scene with 10,000 edges, one component instance, one face, and one group. It appears that grepping specific classes you are interested in, is faster than doing a more general grep and then comparing within the block.
                                    sample code soon to follow
                                    Devin Kendig
                                    Developer
                                    • dkendigD
                                      dkendig
                                      actually, here's the benchmark code I ran
                                      class Magic;def initialize(&block)
                                      	@block=block;end
                                      	def ===(other)
                                      		@block.call(other)
                                      def GetVrayImportantArrayFromGrepDrawingelement(entities)
                                      	return entities.grep(Sketchup;;Drawingelement){|ent| false == (ent.class == Sketchup;;Edge) ? ent ; nil}.compact
                                      def GetVrayImportantArrayOfTypesFromGrep(entities,typeHash)
                                      	for curType in typeHash.keys()
                                      		typeHash[curType] = entities.grep(curType )
                                      def GetVrayImportantArrayFromGrepMagic(entities)
                                      	return entities.grep(Magic.new {|ent| ent if(ent.class == Sketchup;;ComponentInstance or ent.class == Sketchup;;Group or ent.class == Sketchup;;Face)})
                                      def GetVrayImportantArrayFromLoop(entities)
                                      	vrayImportant = Array.new()
                                      	for ent in entities.to_a
                                      		if ent.class == Sketchup;;Face or ent.class == Sketchup;;ComponentInstance or ent.class == Sketchup;;Group
                                      			vrayImportant.push(ent)
                                      	return vrayImportant
                                      def RunBenchmarkOnEntities(entities)
                                      	testHash = Hash.new()
                                      	testHash[Sketchup;;Face] = []
                                      	testHash[Sketchup;;ComponentInstance] = []
                                      	testHash[Sketchup;;Group] = []
                                      	grep_drawing_ele_result = grep_magic_result = compare_loop_result = nil
                                      	grep_drawing_ele_start_time = Time.now.to_f
                                      	grep_drawing_ele_result = GetVrayImportantArrayFromGrepDrawingelement(entities)
                                      	grep_drawing_ele_end_time = Time.now.to_f
                                      	grep_types_start_time = Time.now.to_f
                                      	grep_types_result = GetVrayImportantArrayOfTypesFromGrep(entities,testHash)
                                      	grep_types_end_time = Time.now.to_f
                                      	grep_magic_start_time = Time.now.to_f
                                      	grep_magic_result = GetVrayImportantArrayFromGrepMagic(entities)
                                      	grep_magic_end_time = Time.now.to_f
                                      	compare_loop_start_time = Time.now.to_f
                                      	compare_loop_result = GetVrayImportantArrayFromLoop(entities)
                                      	compare_loop_end_time = Time.now.to_f
                                      	puts "drawing_ele_test time; #{grep_drawing_ele_end_time - grep_drawing_ele_start_time}, resulted in #{grep_drawing_ele_result.size} elements found"
                                      	puts "types_test time; #{grep_types_end_time - grep_types_start_time}, resulted in #{testHash.values.flatten.size} elements found"
                                      	puts "magic_test time; #{grep_magic_end_time - grep_magic_start_time}, resulted in #{compare_loop_result.size} elements found"
                                      	puts "loop_test time; #{compare_loop_end_time - compare_loop_start_time}, resulted in #{compare_loop_result.size} elements found"
                                      	return nil
                                      RunBenchmarkOnEntities(Sketchup.active_model.entities)
                                      Devin Kendig
                                      Developer
