    [Plugin] Curve Maker v1.3.6 - July 2012 Update
    5 Posts 4 Posters 8.2k Views 4 Watching
      max-cx
      Curve Maker now draws the Ionic Volute using the formula proposed by Andrey and Galli (see: http://www.springerlink.com/content/r61qh2354m56qt31/ ).
      Optionally, you can draw it with or without an "eye".
      You can download the updated plugin from here: http://www.drawmetal.com/download
      A demonstration video is available: http://www.youtube.com/watch?v=mES14SnIAP8
      For those interested in drawing an Ionic Capital, using Curve Maker and Taper Maker together may be useful as shown in this video: http://www.youtube.com/watch?v=oxXdXy9Gdes
      Edit 2012-07-04:
      This version is recommended for all users of Curve Maker because it also includes a bug fix. In some circumstances, the plugin would incorrectly determine the drawing plane and draw the mirror image of what should have been drawn. And curves should redraw a little bit faster following any edit made using the Measurements box.
      Terry
      • brookefoxB Offline
        brookefox
        Thank you, Terry, for your continued sharing of a very helpful tool.
        ~ Brooke
          smicha
          Terry,
          Thank you so much.
          • F Offline
            firebert85
            I get an error when trying to instal the script through the sketchup preferences, and I believe it's due to mac OSX Mountain Lion's unneccessary need to have password protection on everything moved into any folder in the Application Support folder on the hard drive, but I've already granted my gatekeeper all access to any apps installed, does anyone else have this problem?
              max-cx
              Sorry to be slow in responding, but I cannot replicate this problem. SU's Install Extension option works as expected on my Mac which is running the latest version of Mountain Lion.
              Terry
