⚠️ Important | Please update Libfredo to v15.3a for bugfixes associated to SketchUp 2025 and below
Download
Road Markings
Hi all, has anyone any advice on how to make road markings... ie centreline, dashed, solid, lane markers etc. I use Pro V8 & dender with SU Podium on Windows 7. I've looked at Rick Wilson's PathCopy plugin which doesn't rotate the group around a curve & wondered if there is any other method of copying a group/cpmponent or indeed another approach alltogether. Maybe a texture mapping method that could cope with curves/bends?
Texture mapping would be good although I would be inclined to use Offset from the inside edge of the roadway to create the marking at least around the corner.
Ta, do you mean draw each marking individually around a bend?
Thanks Dave!
