    Bump disappears with spotlight on (VRAY for SU)
    renderpluginsextensions
    3 Posts 3 Posters 449 Views 3 Watching
      dr.raoul
      Hi, maybe it is just a silly button
      to press in VRAY for SU, but I can't find a way to keep the bump
      on a wall when it is lit with a spotlight.
      My rendering always keeps shows up very flat.
      Anybody can help?
      Best and thanx in advance
      Raoul
      • chonC
        chon
        Hello,
        PC performances, SU and VRay versions, VRay options and materials settings ?
        SU2019 pro 19.3.253 + VRay 4.00.02 (Next) on Win11-64Bits
        • andybotA
          andybot
          It very much depends on the direction your light is shining from. The more perpendicular your light source is to your surface, the more washed out your bump map will be. If you have your light closer to parallel, you'll get a more raking light and show up your surface texture much better. Can you post an image perhaps?
