    Craftsman Tool Chest
    39 Posts 5 Posters 3.8k Views 5 Watching
      mwm5053
      @ Eric maybe someday. Here's peek I got so far
      2011 iMac
      SU 2015 Pro, 2017 Make
      V2 Twilight
      macOS Sierra 10.12.5
      • boofredlayB
        boofredlay
        That looks great. I long to make one of those myself someday. My tools are just laying around inside the cart I posted above, not very organized.
        If I may, a visual tip with SU. If you turn your back face color to a black or near black you wont' get the white jaggies showing up in your image export.
          mwm5053
          Thanks Eric great suggestion 👍
          2011 iMac
          V2 Twilight
            Yes, that's a good suggestion. I do that before I make image exports although I use my default green back face color while drawing.
            Walt, it looks like a good model. Keep up the good work.
              davidheim1
              Am I missing something? Seems to me that modeling a tapered hole and slot for the chisels is infinitely easier in SketchUp than in real life. In real life, I'd probably use a reamer, like the one Dave R. mentioned that Windsor chair makers use. In SU, I'd make a hole for the smallest diameter, then use the Offset Tool to set the largest diameter on the top face of the board. With the Move/Copy Tool, I'd pull the smaller diameter over to the larger one, tapering the hole. Then, for the slot, I'd turn on X-Ray view and hidden geometry. Trace over hidden geometry lines to mark where the tapered slot falls on the hole, then carry those lines through the board and across the faces. A little erasing, and I'm done. Took longer to type these abbreviated instructions than it did to do the modeling.
              dh
                David, I agree with you. Modeling it would be easier than making the real thing. I'd still just use the counterbored holes in real wood.
                I can think of several ways to create the tapered hole in SketchUp. Using Cardinal Points is one, Autofold, another.
                  mwm5053
                  As I agree with Dave I wouldn't go to the trouble to do the tapered holes in the shop a simple hole and dado as he said earlier but he sorta challenged to see if I could do it in SU so this is how I went about it. Circle tool, made cylinder to 1/16 more than top af taper with PP, scaled bottom of cylinder to ah better to just show you
                  Sorry about video quality need to improve on that.
                  2011 iMac
                  V2 Twilight
                    Good work, Walt.
                      mwm5053
                      Thanks, that's an extreme compliment coming from my mentor. 😄
                      2011 iMac
                      V2 Twilight
                        mwm5053
                        Well moving forward, sometimes 1 step forward 2 steps back. the chisels were somewhat tedious but it's all about experimenting and trial and error. I hid the middle drawers so the inside was visible.
                        Thanks for looking
                        2011 iMac
                        V2 Twilight
                          Nice work. I think your drawers should have green felt in them So should those in the tool chest. 😄
                          • boofredlayB
                            boofredlay
                            That is looking great Walt. I am impressed.
                              mwm5053
                              Thanks guy's I think I'm going to model some more tools to put in to it. What's a tool chest without tools right. I'm thinking of a tri square and mallet off the bat. But at a loss for further options. Maybe a few suggestions .
                              2011 iMac
                              V2 Twilight
                                How about a marking gauge, a striking knife, a little block plane like the LN bronze plane? A dovetail gauge, a sliding bevel gauge, dividers (inside, outside and straight), caliper a couple of pencils and a piece of chalk.
                                  mwm5053
                                  Ya why didn't I think of that. Will keep me busy for a while 👍
                                  2011 iMac
                                  V2 Twilight
                                    And out of the bars. 😄
                                      mwm5053
                                      Well maybe at least before dark
                                      2011 iMac
                                      V2 Twilight
                                        mwm5053
                                        Well I've had some time to work on the model. I've really never worked with nested components much before this and it proved to be quite 😞 but I got it done to my satisfaction for the time being. The problem came when I started to copy the nested components ie the drawers to put on different layers to show the different drawers open and closed like Dave suggested, the components inside the drawer were on the original layer I'm not sure what the proper workflow for that is but I guess it came out right. I made the drawers unique so I could postion the textures so the pieces looked like the where cut the same board as I would do in the shop.The PDF came form LO not very experienced with it yet but will be before this is done. I hope to do one for the tools inside the drawers and on LO for the tool chest with the dimensions to be milled. And one last thing I modeled a Lie Nielsen low angle block plane the problem I had there was how to model the cap iron right I tried several time with Curviloft but struck out.THe pDF can be found if I did it right
                                        https://dl-web.dropbox.com/get/Public/craftsman%20tool%20chest.pdf?w=ce7eb84a
                                        low angle block plane.skp
                                        2011 iMac
                                        V2 Twilight
                                          Walt, as to the nested components and layers, you could just make layer associations for the drawers and leave the sub-components (fronts, sides, back, etc.) on Layer 0. Unless you'd have some reason to hide just parts of the drawers, there's no reason to confuse things. The top level component's layer will control the visibility for all of the contents of the nested component.
                                          The plane is a good start. I've got one of those planes and it gets the most use of them all. The finger dimple on the front should be larger. If you want me to I can measure it. As for the cap iron, I would think you could curviloft to do what you need and get pretty close. I would split it in half down its length. Draw the edges and the centerline on top of it. Then draw some curves to create the rounding.
                                            mwm5053
                                            Dave your right about the layer association what was I thinking sometimes go down roads I know are wrong.
                                            As for the finger dimple when your in the shop ya check it out, thanks
                                            2011 iMac
                                            V2 Twilight
                                            • 2 / 2
