    Craftsman Tool Chest
    39 Posts 5 Posters 4.5k Views 5 Watching
      And out of the bars. 😄
        mwm5053
        Well maybe at least before dark
        2011 iMac
        SU 2015 Pro, 2017 Make
        V2 Twilight
        macOS Sierra 10.12.5
          mwm5053
          Well I've had some time to work on the model. I've really never worked with nested components much before this and it proved to be quite 😞 but I got it done to my satisfaction for the time being. The problem came when I started to copy the nested components ie the drawers to put on different layers to show the different drawers open and closed like Dave suggested, the components inside the drawer were on the original layer I'm not sure what the proper workflow for that is but I guess it came out right. I made the drawers unique so I could postion the textures so the pieces looked like the where cut the same board as I would do in the shop.The PDF came form LO not very experienced with it yet but will be before this is done. I hope to do one for the tools inside the drawers and on LO for the tool chest with the dimensions to be milled. And one last thing I modeled a Lie Nielsen low angle block plane the problem I had there was how to model the cap iron right I tried several time with Curviloft but struck out.THe pDF can be found if I did it right
          https://dl-web.dropbox.com/get/Public/craftsman%20tool%20chest.pdf?w=ce7eb84a
          low angle block plane.skp
          2011 iMac
          V2 Twilight
            Walt, as to the nested components and layers, you could just make layer associations for the drawers and leave the sub-components (fronts, sides, back, etc.) on Layer 0. Unless you'd have some reason to hide just parts of the drawers, there's no reason to confuse things. The top level component's layer will control the visibility for all of the contents of the nested component.
            The plane is a good start. I've got one of those planes and it gets the most use of them all. The finger dimple on the front should be larger. If you want me to I can measure it. As for the cap iron, I would think you could curviloft to do what you need and get pretty close. I would split it in half down its length. Draw the edges and the centerline on top of it. Then draw some curves to create the rounding.
            Keep up the good work.
              mwm5053
              Dave your right about the layer association what was I thinking sometimes go down roads I know are wrong.
              As for the finger dimple when your in the shop ya check it out, thanks
              2011 iMac
              V2 Twilight
                I'll get it for you when I get home from work.
                  mwm5053
                  2011 iMac
                  V2 Twilight
                    Walt, I just measured my little bronze 102. The finger rest on the front is about 0.73 in. dia. and about 0.14 in. high. Front of the plane has a bevel on it andmeasuring from the bottom of the bevel to the finger rest at the middle, it measures about 0.15 in. I hope that helps.
                      mwm5053
                      Thanks Dave that works for me
                      2011 iMac
                      V2 Twilight
                      • Jean LemireJ
                        Jean Lemire
                        Hi folks.
                        See this SU file for ideas.
                        Chisel rack.skp
