    Scenes and geometry position or a solution
    8 Posts 3 Posters 242 Views 3 Watching
      mwm5053
      I'm modeling a wooden tool chest from a wood magazine and I would like to be able to setup scenes to display the doors and drawers closed and open in different scenes but don't seem to able to figure it out or not possible any suggestions?
      2011 iMac
      SU 2015 Pro, 2017 Make
      V2 Twilight
      macOS Sierra 10.12.5
      • cottyC Offline
        cotty
        You will need a plugin for this, e.g. keyframe animation.
        my SketchUp gallery
          No. You don't need a plugin for this.
          Walt, you can make multiple copies of the doors and drawers in an array and assign a different layer to each copy. then change which layers are visible for each successive scene. I did a tutorial on this along time ago.
          If you only want to show the doors and drawers in either their open or closed positions, you only need copies positioned at both ends of their travel.
            mwm5053
            Thanks cotty I've haven't used that before.
            Thanks Dave I forgot about that. You did a blog about stopped chamfers but I couldn't seem to find it. Can you give me a link? I will post it in the woodworking forum soon maybe Mike would like to add it to models for sale. 🤣
            PS When you show details of joints in LO good idea to use clipping masks for presentations or not?
            2011 iMac
            V2 Twilight
              Hi Walt, here's the link on the stopped chamfers.
              I'll be interested to see your model.
              As to the masks, it depends upon what you are wanting to show exactly. How are you envisioning the results? Usually when I show joinery details it is in plan documents. There'll be an exploded view and then the individual parts are dimensioned typically in 2D views.
                mwm5053
                Wow there's a lot that goes into play here in setting up the arc length, radius and bulge. I tried last year to get my head around this and gave up. 😍
                stopped chamfers.skp
                2011 iMac
                V2 Twilight
                  Well, you got it this time. 👍
                    mwm5053
                    2011 iMac
                    V2 Twilight
