    Easy and best render engine for Grass?
    extensions
    13 Posts 7 Posters 4.1k Views 7 Watching
    • cottyC Offline
      cotty
      Most render engines are able to use instancing, so you can use simple geometry proxies to reduce model complexity in SU.
      my SketchUp gallery
      • andybotA Offline
        andybot
        Hey Kalu -
        I'm curious what you found difficult about Thea or Maxwell. Since you already know vray, I can imagine most of the knowledge about rendering can transfer fairly easily. Especially I found maxwell to be very easy to pick up, and it looks like the grass texture seems pretty cool (see: http://sketchucation.com/forums/viewtopic.php?f=80&t=46053 ) There are some things I don't like about those engines, but nothing that has to do with ease of use. Maybe try some tutorials and see if you like them more.
        Andy
        • novenaN Offline
          novena
          hi Kalu,
          to complement andybots comment:
          Maxwell grass feature is really easy to use (even with standalone plugin), here you can find some examples and parameter values for grass:
          http://support.nextlimit.com/display/knfaq/Grass+Examples
          of course if you want to render a golf club then probably the solution is what cotty suggests, use geometry proxies...
          or you can try with make-fur plugin, see this thread (http://sketchucation.com/forums/viewtopic.php?f=333&t=47858) where I explain briefly grass making with make-fur and geometry proxies
          best
          V
          http://hdzarkitektur.wordpress.com/
          • N Offline
            notareal
            Thea can handle huge amount on instances... so probably you just need to get more familiar with the UI and instancing tool. You can find new Thea render viewport and instancing tutorials from Thea render resources.
            Next version of exporter plugin will be a integrated with SU; Thea for SketchUp. You can take a look on a preview video from BaseCamp 2012.
            Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
            • daleD Offline
              dale
              Here is an example of instancing grass in Thea. The grass may seem a little coarse, but I wanted to turn it into a an old looking black and white photo, so I made it this way.
              There are about 4 different grass models from SketchUp made into an instance. The terrain model group was chosen as a canvas, and the amount and type of populations for the instance chosen, and presto! there it is.
              It is extremely simple.
              • pbacotP Offline
                Wow, Dale. Why isn't this in the "Gallery" Gallery? The B&W works great. Although it also reminds me of a ca 60's B movie grading, and that could be a graveyard, and it is that time of year...
                • daleD Offline
                  dale
                  Thanks Peter.
                  This was my entry in the Thea "Seasons" contest. I don't often get the pleasure of just playing in SketchUp, but I made a point of doing it for the contest, as like with the SketchUcation Forums, I want to be a contributing part of another great and helpful community.
                  Your right, I should add a few ghouls! πŸ‘Ώ
                  • kaluK Offline
                    kalu
                    @andybot said:
                    Hey Kalu -
                    Andy
                    Hi Andy:
                    thank you for the information. It take me a couple of months to learn Vray for Sketchup most learn at the beginning with Fernando Rentas videos from rhino plus the forum before Chaos take over Asgvis. Now we have tons of videos tutorials to learn quickly. The forum is kind of dead after Chaos take over. I still want to render in Vray the buildings and the grass just render in a second render engine and combine all in PH. I do not want to learn a new render engine again, and the option of use fur in sketchup is almost prohibited since it take forever to render. I am still looking for good options integrated to Sketchup as possible so I keep the same viewport.
                    Kalu. 😎
                    THE ONLY DIFFERENCE BETWEEN FICTION AND REALITY IS WHEN FICTION HAS TO BE CREDIBLE
                    • andybotA Offline
                      andybot
                      Hi Kalu,
                      If you are still needing to do post-processing, then it seems adding in a grass texture in post (use a material-ID mask of the grass plane) is much quicker than having to render a whole extra render - especially if the other engine is unbiased like Maxwell (so it takes significantly longer to render... plus it has a whole different texture to the image, generally more "grainy")
                      Andy
                      • daleD Offline
                        dale
                        Hi Andy:
                        Kalu. 😎[/quote]
                        Sorry Kalu, I was under the impression that you were looking for other render engines judging by the title of the post. Didn't mean to hi-jack you.
                        Cheers
                        • kaluK Offline
                          kalu
                          Hi Dale:
                          Thank you for your comments. i really want to learn a quick way to do a grass in HQ but I already love Vray, and take me more than 6 months to learn that. I looking for any way just to make grass quick and real instead to Photoshop. thea and maxwell are awesome render engines but I already know how render in Vray I just do not want to start over again.
                          thank you for your info.
                          kalu.
                          • kaluK Offline
                            kalu
                            Hi Andy,
                            Thank you for your comments. You are right, this is some that I always forgot.
                            Kalu.
