    Get the Click-Style via the Ruby API?
    15 Posts 5 Posters 1.2k Views 5 Watching
    • Dan RathbunD Offline
      Dan Rathbun
      @thomthom said:
      Get the Click-Style via the Ruby API? How?
      Registry
      key: HKCU\Software\Google\Sketchup7\Preferences
      Preferences dialog > Drawing tab (page)
      att: ClickStyle
      • Click-drag-release = 0* Auto Detect = 2* Click-move-click = 1
        att: ContinueLineMode
      • (boolean) 0 | 1
        att: DisplayCrosshairs
      • (boolean) 0 | 1
      @thomthom said:
      Oh no - not another inaccessible property...
      Sorry.. yes they are all DWORD values.
      As you know by now... read_default and write_default cannot read**|**write DWORD values.
      p Sketchup.read_default('Preferences','ClickStyle','Read Error!')
      >> "Read Error!"
      The only GOOD thing is the values appear to be dynamic (ie, they are updated in the registry when the dialog is closed and NOT when Sketchup shuts down. However.. changing pages in the Preferences dialog does not update the registry value, only when the whole dialog is closed.)
      I'm not here much anymore.
        Best I can do then is just mimic the default setting "Auto-Detect". sigh Another item for the wish-list.
          Dan Rathbun
          Does the above code snippet work on the Mac ??
          If YES, then for Windows you have 3 options:
          1. A shell command (or IO.popen,) calling reg.exe, with the key/attribute as args1. use the standard Ruby library Registry1. use a Win32 System call via Win32API.so
            hm.. dunno. will have to test.
            This can be done via the SketchUp Ruby? I don't want to bundle another library just to read this setting.
              Dan Rathbun
              unless defined? Platform require 'Platform' # Platform.rb
              if Platform.is_win?
                clickstylecmd ='REG QUERY HKCU\Software\Google\Sketchup7\Preferences /v ClickStyle'
                num=nil
                IO.popen(clickstylecmd) { |f| num=("%x" % f.readlines[4].split(' ').last).to_i }
              elsif Platform.is_mac?
                num = Sketchup.read_default('Preferences','ClickStyle','Read Error!')
              else
                # error unsupported platform
              # detect ClickStyle setting
              unless num=='Read Error!'
                if num==0
                  # Click-drag-release
                elsif num==1
                  # Click-move-click
                elsif num==2
                  # Auto Detect
                else
                  # error
              else
                # raise an exception
              There is an annoyance.. a cmd window flashes on the screen but disappears.
                Ah - and that can not be suppressed?
                  Dan Rathbun
                  I haven't yet found a way.
                  maybe with a PIF file we can make it run minimized ?
                    Dan Rathbun
                    And BTW shell commands are done with Kernel.` (backquote character)
                    see http://phrogz.net/ProgrammingRuby/ref_m_kernel.html#Kernel._bq
                      Dan Rathbun
                      More Info: The shell execution also sets the $? variable with the command's exit status.
                        lionk
                        still a cmd window...
                        ex:ipconfig /all
