    Get the Click-Style via the Ruby API?
    15 Posts 5 Posters 870 Views 5 Watching
      How?
      • Chris FullmerC Offline
        Seems like it should be stored in the registry for Win and the equivalent for the "other" OS.
          Oh no - not another inaccessible property... 😞
            Jim
            Have a look through the various options collections via the options manager. I don't really know, but it could be there.
            It has Units options, and 3 others I can't recall.
              I did not find it - probably because they are model settings and this appear to be application setting.
              • Dan RathbunD Offline
                Dan Rathbun
                @thomthom said:
                Get the Click-Style via the Ruby API? How?
                Registry
                key: HKCU\Software\Google\Sketchup7\Preferences
                Preferences dialog > Drawing tab (page)
                att: ClickStyle
                • Click-drag-release = 0* Auto Detect = 2* Click-move-click = 1
                  att: ContinueLineMode
                • (boolean) 0 | 1
                  att: DisplayCrosshairs
                • (boolean) 0 | 1
                Sorry.. yes they are all DWORD values.
                As you know by now... read_default and write_default cannot read**|**write DWORD values.
                p Sketchup.read_default('Preferences','ClickStyle','Read Error!')
                >> "Read Error!"
                The only GOOD thing is the values appear to be dynamic (ie, they are updated in the registry when the dialog is closed and NOT when Sketchup shuts down. However.. changing pages in the Preferences dialog does not update the registry value, only when the whole dialog is closed.)
                I'm not here much anymore.
                  Best I can do then is just mimic the default setting "Auto-Detect". sigh Another item for the wish-list.
                    Dan Rathbun
                    Does the above code snippet work on the Mac ??
                    If YES, then for Windows you have 3 options:
                    1. A shell command (or IO.popen,) calling reg.exe, with the key/attribute as args1. use the standard Ruby library Registry1. use a Win32 System call via Win32API.so
                      hm.. dunno. will have to test.
                      This can be done via the SketchUp Ruby? I don't want to bundle another library just to read this setting.
                        Dan Rathbun
                        unless defined? Platform require 'Platform' # Platform.rb
                        if Platform.is_win?
                          clickstylecmd ='REG QUERY HKCU\Software\Google\Sketchup7\Preferences /v ClickStyle'
                          num=nil
                          IO.popen(clickstylecmd) { |f| num=("%x" % f.readlines[4].split(' ').last).to_i }
                        elsif Platform.is_mac?
                          num = Sketchup.read_default('Preferences','ClickStyle','Read Error!')
                        else
                          # error unsupported platform
                        # detect ClickStyle setting
                        unless num=='Read Error!'
                          if num==0
                            # Click-drag-release
                          elsif num==1
                            # Click-move-click
                          elsif num==2
                            # Auto Detect
                          else
                            # error
                        else
                          # raise an exception
                        There is an annoyance.. a cmd window flashes on the screen but disappears.
                          Ah - and that can not be suppressed?
                            Dan Rathbun
                            I haven't yet found a way.
                            maybe with a PIF file we can make it run minimized ?
                              Dan Rathbun
                              And BTW shell commands are done with Kernel.` (backquote character)
                              see http://phrogz.net/ProgrammingRuby/ref_m_kernel.html#Kernel._bq
                                Dan Rathbun
                                More Info: The shell execution also sets the $? variable with the command's exit status.
                                  lionk
                                  still a cmd window...
                                  ex:ipconfig /all
