    Get the Click-Style via the Ruby API?
    15 Posts 5 Posters 1.3k Views 5 Watching
      I did not find it - probably because they are model settings and this appear to be application setting.
      • Dan RathbunD
        Dan Rathbun
        @thomthom said:
        Get the Click-Style via the Ruby API? How?
        Registry
        key: HKCU\Software\Google\Sketchup7\Preferences
        Preferences dialog > Drawing tab (page)
        att: ClickStyle
        • Click-drag-release = 0* Auto Detect = 2* Click-move-click = 1
          att: ContinueLineMode
        • (boolean) 0 | 1
          att: DisplayCrosshairs
        • (boolean) 0 | 1
        @thomthom said:
        Oh no - not another inaccessible property...
        Sorry.. yes they are all DWORD values.
        As you know by now... read_default and write_default cannot read**|**write DWORD values.
        p Sketchup.read_default('Preferences','ClickStyle','Read Error!')
        >> "Read Error!"
        The only GOOD thing is the values appear to be dynamic (ie, they are updated in the registry when the dialog is closed and NOT when Sketchup shuts down. However.. changing pages in the Preferences dialog does not update the registry value, only when the whole dialog is closed.)
        I'm not here much anymore.
          Best I can do then is just mimic the default setting "Auto-Detect". sigh Another item for the wish-list.
          • Dan RathbunD
            Dan Rathbun
            Does the above code snippet work on the Mac ??
            If YES, then for Windows you have 3 options:
            1. A shell command (or IO.popen,) calling reg.exe, with the key/attribute as args1. use the standard Ruby library Registry1. use a Win32 System call via Win32API.so
              hm.. dunno. will have to test.
              This can be done via the SketchUp Ruby? I don't want to bundle another library just to read this setting.
              • Dan RathbunD
                Dan Rathbun
                unless defined? Platform require 'Platform' # Platform.rb
                if Platform.is_win?
                  clickstylecmd ='REG QUERY HKCU\Software\Google\Sketchup7\Preferences /v ClickStyle'
                  num=nil
                  IO.popen(clickstylecmd) { |f| num=("%x" % f.readlines[4].split(' ').last).to_i }
                elsif Platform.is_mac?
                  num = Sketchup.read_default('Preferences','ClickStyle','Read Error!')
                else
                  # error unsupported platform
                # detect ClickStyle setting
                unless num=='Read Error!'
                  if num==0
                    # Click-drag-release
                  elsif num==1
                    # Click-move-click
                  elsif num==2
                    # Auto Detect
                  else
                    # error
                else
                  # raise an exception
                There is an annoyance.. a cmd window flashes on the screen but disappears.
                  Ah - and that can not be suppressed?
                  • Dan RathbunD
                    Dan Rathbun
                    I haven't yet found a way.
                    maybe with a PIF file we can make it run minimized ?
                    • Dan RathbunD
                      Dan Rathbun
                      And BTW shell commands are done with Kernel.` (backquote character)
                      see http://phrogz.net/ProgrammingRuby/ref_m_kernel.html#Kernel._bq
                      • Dan RathbunD
                        Dan Rathbun
                        More Info: The shell execution also sets the $? variable with the command's exit status.
                        • L
                          lionk
                          still a cmd window...
                          ex:ipconfig /all
