    [Plugin] Snapshot – (1.0.1) — updated 09.10.2012
    74 Posts 12 Posters 58.6k Views 12 Watching
    • simon le bonS Offline
      simon le bon
      @aerilius said:
      fixed!
      Hi Ae,
      it is not necessarily very comfortable to be tester 😉 😕
      It seems that increment still doesn't work...
      (that decrements from 1 to 0 and then overwrites)
      Cheers,
      Simon.
      PS:It should certainly be very useful to add the usages of {nr} parameter to the first post
        simon le bon
        ~~ content outdated --> erased ~~~
          glro
          one step further...
          would it be possible to:
          scan a folder
          open automatically all skp files in the folder
          produce the thumbnail and the file shortcut
          store them in the specified folder?
          Because the plugin is great to keep track of the future skp files, and it would be nice to collect the informations also for the already existing skp files...
            driven
            Hi Giro,
            I just popped in to post another idea and thought I'd use your query to clarify some thoughts, hope you don't mind.
            @glro said:
            one step further...
            scan a folder
            'SketchUp Menu' >> File >> Open >> Browse to Folder >> Select All .skp files >> Click 'Select'
            on a mac all will open in SketchUp, does it not on a PC?
            does it not do this, now? on the mac the 'shortcut's' not needed if you 'apply' the new icon image to the .skp file
            This is already a preference, but once they're on the .skp storing a copy [as a material, maybe?] in the model would be more useful [for transferring to another computer or sharing]
            You can already use this with old or new files, the problem with batch processing [fully auto] is getting bad views of some models that haven't been optimally positioned when last saved. You could code in a 'Perspective >> Zoom Extents' type event, but what if its a part of a huge scheme or a 2D floorPlan etc...
              driven
              a hidden editor pops down on hover
              allowing you to add all sorts of detail to the icon
              Everything is made inside a SU WebDialog [could just be an extra option in this plugin]
              I have a hard coded 'proof of principle' plugin that works on a mac and possibly a PC...
              You can add your own borders [made in SU]
              add logos
              add text
              can anyone else see any advantages to this concept or should I just finish it for myself and mac only.?
                glro
                @driven said:
                Hi Giro,
                @glro said:
                one step further...
                scan a folder
                on my computer this doesn't open all skp files automatically...
                i have to open each file manually one by one
                but you are right about the snapshot: to make sure it is taken with the model in the right position, it would be better to have a look on it
                maybe i can find the code to open automatically all files in a folder, one after the other, and set the zoom coefficient so that the model is visible completely
                the only thing to do manually would be to gather all the skp files in a folder and then launch the plugin
                i'll work on it soon
                  glro
                  this plugin could be a useful addition to ae snapshot, because, as i understand it, it would make possible to add information on the thumbnail
                  when trying to retrieve a model, you would have the image, and also text, to make sure it is the model you are looking for
                    simon le bon
                    Hey! very interesting perspectives engaged by Giro and Driven 👍
                    +1 for Driven Icon Editor!
                    As the increment feature still don't work for me, I have tried to delete the plugin and to reinstall it. I have been surprised by the fact that my previous settings are reloaded.
                    That means that they are stored somewhere else, probably in a ini textfile (that I have not found).
                    Can you please Aerilius elucidate this point ? May be from this comes my problem ?
                    *s
                      Aerilius
                      writing from my phone from Boulder (wonderful sunny morning after the bad weather yesterday).
                      SketchUp gives us developera access to the default place where settings are stored, that is on Windows the registry. Open the start menu, "regedit" or run regedit.exe, then navigate to users, software, google, sketchup, plugins_ae
                      More details/news later
                        simon le bon
                        Thank you for the phone reply dear Ae.
                        I see what I ignored that many plugins are installed into the registry. What happens if I delete a key? nothing annoying I guess. If the plugin is still in use, the key must be reloaded, am I right?
                        Well forget this, I wish you a good trip in Boulder and a nice Basecamp 2012 with SCF friends 👍 👍 😄
                        simon
                          driven
                          I've been having a look at 'less' cutting edge editor's to see if I can get enough usable feature on a PC version.
                          I'll PM the volunteers Giro + simon to test the basic concept using hard linked files with this template.
                          you should be able to edit any text and replace/remove the 'logo'
                          here's the teaser images...
                          using NicEdit for wysiwyg...should be more MISE friendly
                          I won't get it packaged till monday night UK time
                            tulacong
                            oh lala zeeeee....thank you
                              driven
                              sorry for delays, there's a couple of 'PC' unknowns for me that this version may have avoided, but needs some testing.
                              I created 5 separate edit boxes that can be moved or resized or left blank[by deleting the content]
                              they can be 'rich text' edited by hovering at the top of page [after clicking into a text box].
                              if you can see the edit controls before you 'hover', I'll need to find another hide method, as they will be in the final image.... not good.
                              To Test:
                              1. unzip and place iConEdit folder in plugins
                              2. open the iConEdit/ruby's/create_demo_Icon.rb in a text editor, 1. add your path i.e.
                                iconSu.set_file("C:YOUR PATH/SketchUp/plugins/iConEdit/dragresize_iConEdit.html")
                              3. then copy paste it into SketchUp 'Ruby Console'[if that works on a PC?]1. or type in
                                load("C:YOUR PATH/SketchUp/plugins/iConEdit/ruby's/create_demo_Icon.rb") 1. and hit enter.
                              see what works... report back
                              latest, possibly 'PC' freindly version?
                              all the hardcode files/images are in their right folders, don't move [for now]
                                glro
                                i tried
                                on a PC
                                following your indications, i managed to open a html
                                but then, i don't know how to proceed
                                the buttons in the html window are not active
                                i learnt a lot, though, trying to understand your code
                                thank you
                                  driven
                                  Hi giro,
                                  good you got that far, shame it's not all working...
                                  if you hover over or click on the "Placeholder text", do you get the resize handles[six green squares]?
                                  if not there's a simpler version in the folder to test the other bits...
                                  first test- can you open dragresize_iConEdit.html in a Browser [ IE, Chrome ] just to see if more works there.
                                  second test- open demo_Icon.html [it's in the same folder] in your Browser and swap the name in the 'ruby to test in SU...
                                  all the 'opacity' settings appear to not work, the toolbar hiding and the transparent SU logo.
                                  in either the html if you 'comment out' the first background to look like this and reload you should see the fireman!!!
                                  <body>
                                  <!--  <div class="SketchUp"></div> -->
                                  if not, it may be because that files name is in 'Cyrillic', change it to fireman_3 on the file and in the html reference
                                   background; url(ae_snapshot_images/ØÆ¶†‡≠Ω_3.png) no-repeat;
                                  to
                                   background; url(ae_snapshot_images/fireman_3.png) no-repeat;
                                  I'll modify the settings to hide the 'nicEditor' on a button.
                                  thanks for testing
                                    glro
                                    @driven said:
                                    Hi giro,
                                    yes i can resize the handles, both in sketchup and in chrome
                                    and i realize now that the menu in the html window is activ, but only once... the first time.
                                    if i close it and open it again, it is not active anymore.
                                    If i close sketchup and reload the plugin, it depends...
                                    What would be the next step: "file://" ? what is expected by the program at this point?
                                      driven
                                      the target for it appearing is very small [a 10px strip above the edit area... might be that]
                                      shouldn't need to close SU, can you right click 'Reload' on the 'WebDialog' to reload the html only?
                                      you need to type or drag'n'drop an image path onto it.
                                      But that's just for extra 'logo type' images, the "firemen image" should be there already. try 'commenting' out the "Sketchup div" to see it.
                                      I'm just trying a simpler version to click a button for the menu...
                                      [highlight=#80ff80:17yzd2rt]EDIT: I forgot to add this to the Sketchup css class in the html file,
                                      Add it and you should see two backgrounds
                                          zoom;1;
                                          filter; alpha(opacity=0);
                                      [/highlight:17yzd2rt]
                                        driven
                                        I did an update of a few things that might help,,,
                                        add the html to the iConEdit folder in plugins and replace the nicEdit.js in the nicEdit folder.
                                        cheers
                                        hover right hand corners and click SU button to show/hide toolbars
                                          glro
                                          i added the html to the iConEdit folder in plugins and replaced the nicEdit.js in the nicEdit folder.
                                          i didn't add the text in the css section, because i don't know where to add it exactly
                                          it doesn't help...
                                          i get 2 errors messages
                                            driven
                                            @glro said:
                                            it doesn't help...
                                            oops,I missed a step,,, your ruby file needs to point to /iConEdit/test_3_iConEdit.html
                                            the nicEdit.js error on line 169 character 2 is a tab and unchanged, I only tidied up the text sizes and the color picker, so revert to the other if you still have the error.
                                            • 3 / 4
