    [Tutorial] Piling up of heaping up !
    9 Posts 4 Posters 3.5k Views 4 Watching
      If you need these sort of things maybe SketchyPhysics can help you! ๐Ÿ˜„
      A - Make a Terrain - given By the UI of SketchyPhysics (nothing to do! Pass to the next letter)
      • or make a group or better a component with a thickness!
        Select it : Right click / Sketchyphysics /State/Static)
      B - Make a bowl or any recipient with a thickness: Right click / group or better component
      Put it on the ground! or anywhere you want depending of your final result wished ๐Ÿ˜„
      Select it : Right click / Sketchyphysics /State/StaticMesh)
      C - A Component "Capsule" given By the UI of SketchyPhysics
      Right Click /Sketchyphysics/ Shape Default:/Capsule)
      • or make anything as a group or better a component with thickness!
        Select it : Right click / Sketchyphysics /Shape Default:/Capsule...or other following your object!
      D - Multiply the "Capsule! A simple Vertical Copy / move *x on Z is sufficient!
      E - Put them above the bowl or any container at any high altitude! ๐Ÿ˜„
      F - Press the Run button! (you can drag and move an object during the animation! ) ๐Ÿค“
      G - Press the Run / Pause Button again when you are satify! Crucial point! โ—
      Don't press Restart or the SpaceBar else all will restart from the beginning! ๐Ÿ˜ฎ
      Tips: you can makes some ledges on your terrain else pills can roll and fall to the infinite! ๐Ÿ’š
      H - That all! Save as in V6 for me! "my_box_of_pills.skp" ๐Ÿ’š
      When you have finished : Rename Sketchyphysics.rb in Sketchyphysics.007 because till now this funny plugin works only alone against the other Plugins for mysterious reasons! ๐Ÿ’š
      File New - and reload your pills for some funny textures! โ˜€
      Here with the famous Random Painter by Chris Fullmer! ๐Ÿ˜Ž
      The new Pills thriller ! โ˜€
      This title of this cool movies can be translated by : Watching men fall
      http://www.devoir-de-philosophie.com/images_dissertations/119982.jpg
      Sometimes following the volumes Pills go trough the walls! ๐Ÿ˜ฎ
      Just separate your container in some groups or better components (Right click ...StaticMesh etc..)
      You can hide the container for some curious volume in the space! ๐Ÿ˜„
      By Pierreaudoin with this technic ๐Ÿ˜‰
        SketchUpNoobie
        Pilou,
        Some of your images are broken. Great tutorial though, I am going to try it on a model of mine that I've wanted to try something similar on for a while but never got through the SketchyPhysicsness of it. ๐Ÿ˜„
        SketchUpNoobie: the complete noob in all things SketchUp.
          Some images are broken
          ? How many ?
          I see just one (the movie cover) that I have repaired ๐Ÿ˜‰
          • olisheaO
            olishea
            2,4,5,6,8,9 broken
            oli
              Damned! ๐Ÿ˜ฎ
              I will see what i can do ๐Ÿ˜ณ
              Now that must work, i believe that was arrived due the new forum don't follow the old "internal" links of images!
              • GaieusG
                Mystery solved: http://sketchucation.com/forums/viewtopic.php?p=434173#p434173
                  Not Yet entierely! ๐Ÿ’š
                  • GaieusG
                    I still believe it is: http://sketchucation.com/forums/viewtopic.php?p=434184#p434184 ๐Ÿ˜„
                      Bravo! โ˜€
                      http://www.actualitte.com/images/actualites/Sherlock_Holmes_2.jpg
