๐Ÿค‘ SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
[Tutorial] Piling up of heaping up !
9 Posts 4 Posters 3.0k Views
    If you need these sort of things maybe SketchyPhysics can help you! ๐Ÿ˜„
    A - Make a Terrain - given By the UI of SketchyPhysics (nothing to do! Pass to the next letter)
    • or make a group or better a component with a thickness!
      Select it : Right click / Sketchyphysics /State/Static)
    B - Make a bowl or any recipient with a thickness: Right click / group or better component
    Put it on the ground! or anywhere you want depending of your final result wished ๐Ÿ˜„
    Select it : Right click / Sketchyphysics /State/StaticMesh)
    C - A Component "Capsule" given By the UI of SketchyPhysics
    Right Click /Sketchyphysics/ Shape Default:/Capsule)
    • or make anything as a group or better a component with thickness!
      Select it : Right click / Sketchyphysics /Shape Default:/Capsule...or other following your object!
    D - Multiply the "Capsule! A simple Vertical Copy / move *x on Z is sufficient!
    E - Put them above the bowl or any container at any high altitude! ๐Ÿ˜„
    F - Press the Run button! (you can drag and move an object during the animation! ) ๐Ÿค“
    G - Press the Run / Pause Button again when you are satify! Crucial point! โ—
    Don't press Restart or the SpaceBar else all will restart from the beginning! ๐Ÿ˜ฎ
    Tips: you can makes some ledges on your terrain else pills can roll and fall to the infinite! ๐Ÿ’š
    H - That all! Save as in V6 for me! "my_box_of_pills.skp" ๐Ÿ’š
    When you have finished : Rename Sketchyphysics.rb in Sketchyphysics.007 because till now this funny plugin works only alone against the other Plugins for mysterious reasons! ๐Ÿ’š
    File New - and reload your pills for some funny textures! โ˜€
    Here with the famous Random Painter by Chris Fullmer! ๐Ÿ˜Ž
    The new Pills thriller ! โ˜€
    This title of this cool movies can be translated by : Watching men fall
    http://www.devoir-de-philosophie.com/images_dissertations/119982.jpg
    Sometimes following the volumes Pills go trough the walls! ๐Ÿ˜ฎ
    Just separate your container in some groups or better components (Right click ...StaticMesh etc..)
    You can hide the container for some curious volume in the space! ๐Ÿ˜„
    By Pierreaudoin with this technic ๐Ÿ˜‰
      SketchUpNoobie
      Pilou,
      Some of your images are broken. Great tutorial though, I am going to try it on a model of mine that I've wanted to try something similar on for a while but never got through the SketchyPhysicsness of it. ๐Ÿ˜„
      SketchUpNoobie: the complete noob in all things SketchUp.
        Some images are broken
        ? How many ?
        I see just one (the movie cover) that I have repaired ๐Ÿ˜‰
        • O Offline
          olishea
          2,4,5,6,8,9 broken
          oli
            Damned! ๐Ÿ˜ฎ
            I will see what i can do ๐Ÿ˜ณ
            Now that must work, i believe that was arrived due the new forum don't follow the old "internal" links of images!
              Mystery solved: http://sketchucation.com/forums/viewtopic.php?p=434173#p434173
                Not Yet entierely! ๐Ÿ’š
                  I still believe it is: http://sketchucation.com/forums/viewtopic.php?p=434184#p434184 ๐Ÿ˜„
                    Bravo! โ˜€
                    http://www.actualitte.com/images/actualites/Sherlock_Holmes_2.jpg
