    X-wing
    14 Posts 8 Posters 2.3k Views 8 Watching
    • KrisidiousK Offline
      Krisidious
      schweeeeet.
      By: Kristoff Rand
        Ghalko
        Do you know this one ? πŸ˜‰
        (Bi language) πŸ˜‰
        I know a simpler one based on the crane-base. πŸ˜„
        Arrrggghhh! Why won't it make a face!!! Stupid, no good piece of... Oh look! The line went to the wrong point. Whew... moving on. (My fights with sketchup.)
        • Bryan KB Offline
          Looking good.
            Ghalko
            Thanks for the comments!
            Here is a shield generator with waveguides out to the projectors. I am getting detailed....
            • sh00ksS Offline
              sh00ks
              Looking good so far πŸ‘
              Detailed work is looking smooth! You use SS/Artisan?
                Ghalko
                Thanks for the encouragement! No artisan as of yet, I did buy the tool but the shield generator is actually just using follow-me, though it was a beast to clean up. Since then I have found that if you make the path that the follow-me needs to traverse one polyline then it gets around smoothly and hardly needs any clean-up which would have saved at least 30 minutes with the shield generator.
                A bit of down time and travel, but here is the detailed front area. From left to right are the sensors and jammers, the gyro for maneuvering (Destin from smarter every day on youtube inspired that idea.), and the computer bank. The computers still need to be populated and the support structure, cooling, power and data lines need to be designed. On a twelve meter ship I am getting down into millimeter detail sometimes, this is probably why larger projects don't get very far. Practice makes perfect, right?Sensors and computers, needs lots of wires.A computer rack with 5 single board computers. These are flight computers.
                • david_hD Offline
                  david_h
                  Building shield generators ain't like dustin' crops, boy! πŸ’š
                    liam887
                    looks good.
                    What level of detail are you planning to go with?
                    VISIT MY ONLINE GALLERY
                    • hellnbakH Offline
                      hellnbak
                      Looking good, I like models with lots of detail.
                      Can you post some larger detail photos?
                        Ghalko
                        Liam,
                        I am planning on going to a level of detail I am familiar with in a large complex system. I work at a telescope so just the ideas of separate but interworking large systems seems reasonable. And I am all too familiar with single board computers in crates and such. Probably not as detailed as that tank someone did a little while ago.
                        hellnbak,
                        Here are a small picture and a slightly larger one. These are just using the free maxwell render as I work. I will probably go for a better renderer for the final product and those will be big...no huge, so just hang in there.
                        Front sensor package containing forward high density targeting radar with radar dome(belt really) behind, and jammers, should they be shielded?
                        Airducts for the computer racks using artisan, crease tool is my friend!
                        • hellnbakH Offline
                          hellnbak
                            Ghalko
                            Some more detail, the reactor is based on a non sustained reaction idea and being a little over a meter across would put the Skunkworks to shame with their "tiny" trailer-sized reactor they are working on, if it worked.
                            Two neutrons are raced around the track and then collide as femto-second laser pulses hit the same spot. The inner layer collects the waves of energy. The second is magnetic shielding and the third is secondary heat shielding if the first layer fails.
                            This is only half of the reactor. Lots of components used and manipulated.
                            The three shells for the fusion reactor based on particle acceleration.
