    Help Understanding Classes and Class objects
    30 Posts 4 Posters 2.6k Views 4 Watching
    • Dan RathbunD
      Dan Rathbun
      @dan rathbun said:
      There is still a basic grouping protocol steps that are out of sequence in your original example, and in mine above.
      Can you figure out what the proper sequence is ???
      @thomthom said:
      ... when creating Group with the API you create the group first - then add the entities directly into the group. As oppose to when you model in SketchUp where you draw the geometry - then group.
      Thomas gave away the answer.
      So ... lets see the my example, using this protocol.
      We will first create the conveyor group, add a temporary construction point to it, so SU does not clean it up, then past that parent group's entities reference into the other method, and have the subordinate method add it's subgroup to the parent group. Finally we will add pully primitives to the subgroup and return it's reference.
      module Magans
        class Conveyor
          # make @group var and .group() instance method;
          attr_reader(;group)
          private
          def initialize(st_point, end_point)
              @st_point = st_point
              @end_point = end_point
              ents = Sketchup.active_model.active_entities
              # hold reference to group;
              @group = ents.add_group()
              cpt = @group.entities.add_cpoint(ORIGIN)
              @group.name = "CONVEYOR ASSY"
              # pully1
              create_end_pully(@group.entities,@st_point,36,18)
              # pully2
              create_end_pully(@group.entities,@end_point,36,18)
              cpt.erase!
          end #of initialize()
          def create_end_pully(ents,pts,width,length)
              pt1 =[pts[0] - (width/2),pts[1],pts[2]]
              pt2 =[pts[0] - (width/2),pts[1]+length,pts[2]]
              pt3 =[pts[0] + (width/2),pts[1]+length,pts[2]]
              pt4 =[pts[0] + (width/2),pts[1],pts[2]]
              subgroup = ents.add_group()
              face = subgroup.entities.add_face( pt1,pt2,pt3,pt4 )
              subgroup.name = "END PULLEY"
              face.reverse!
              face.pushpull( 5 )
              # return the pully's group reference;
              return subgroup
          end #of create_end_pully()
          public
          # Example "wrapper" methods
          def name()
             return @group.name
          end #of name()
          def valid?()
             return @group.valid?
          end #of name()
        end #of Conveyor class
      end # module Magans
      I'm not here much anymore.
      • P
        pmagans
        First of all I would like to thank you guys for all of the help. My thought process was skewed in the wrong direction and I don't think I would've come up with the passing the group object. Also starting with the group and then adding the entities is now clear in my head. I had read that before in other posts but could never quite understand the "how". That was where I was hopelessly stuck for the past day. I have re-written the previous code and module-ized it and it works perfectly.
        I kept the classes for Conveyor and EndPulley seperate so that I can use both seperately for inheritance in the future.
        I still need to check into "Wrapper" classes further for how I can implement them effectively.
        The only snag was I had to remove the private designation for the methods under the Conveyor class to work. I'm not really certain why.
        module Pmagans
        	# Type in Console
        	# load 'Conveyor/CONVEYOR2.rb'
        	# conv = Pmagans;;Conveyor.new([0,0,0], [0,120,0])
        	class Conveyor
        		#make the @group var and .group()instance
        		attr_reader(;group)
        		#private #why does this need to be private?
        			ents = Sketchup.active_model.entities
        			#hold reference to group;
        			self.create_geometry
        			cpt.erase!
        		def create_geometry()
        			puts ents.length
        			#pulley 1
        			st_ep = EndPulley.new(@group, @st_point)
        			#pulley 2
        			end_ep = EndPulley.new(@group, @end_point)
        			puts ents.length
        		end #of create_geometry()
        	class EndPulley
        			attr_reader(;group)
        		def initialize(conv_group, ins_pt)
        			#TODO; add *args if a group not passed to EndPulley just "create_geometry"
        			@conv_group = conv_group
        			@ins_pt = ins_pt
        			pts = @ins_pt
        			width = 36
        			length = 18
        			@group = @conv_group.entities.add_group()
        			face = @group.entities.add_face pt1,pt2,pt3,pt4
        			face.reverse!
        			face.pushpull 5
        			@group.name = "END PULLEY"
        	end #of EndPulley class
        end #of module Pmagans
        • P
          pmagans
          I'm not sure if my last post went through. I wanted to thank everyone though. Also I got everything working and kept the two classes seperate for future inheritence. I had to remove the "private" so that the methods for the Conveyor class could be accessed. I'm not really sure why?
          module CONVEYOR #CONVEYOR.rb
          	# Type in Console
          	# ex. conv = CONVEYOR;;Conveyor.new([0,0,0], [0,120,0])
          	require 'sketchup.rb'
          	class Conveyor
          		attr_reader(;group)
          			t1 = Geom;;Transformation.translation [0,0,-5]
          			@group.transform! t1
          			cpt.erase!
          			puts ents.length
          			#pulley 1
          			#pulley 2
          			puts ents.length
          	class EndPulley
          			attr_reader(;group)
          			@ins_pt = ins_pt
          			pts = @ins_pt
          			width = 36
          			length = 18
          			face.reverse!
          			face.pushpull 5
          end #of module CONVEYOR
            The first few posts of new members must be approved by a moderator before it appear on the forum - this is an anti-spam measure.
              You still have this
              which won't return the new object [group] unless you add
              return @group
              as the final code in the EndPulley method...
              • P
                pmagans
                So I added the return @group per your recommendation TIG however I am having some confusion as to how Sketchup sees the newly created groups. It doesn't seem like you can manipulate the returned groups as per the example code below returns undefined method transform!
                It seems as though Sketchup is treating the groups st_ep and end_ep as objects not groups. I have been creating "dummy-container groups to bypass this like Conveyor but I'm guessing from your comment there is an easier way to access the groups that I am creating in the EndPulley class?
                   # Type in Console
                   class Conveyor
                      attr_reader(;group)
                         #t1 = Geom;;Transformation.translation [0,0,-5]
                         #@group.transform! t1
                         cpt.erase!
                         #pulley 1
                         #puts st_ep
                         st_ep.transform! t1
                         #pulley 2
                         end_ep.transform! t1
                   class EndPulley
                         attr_reader(;group)
                         @ins_pt = ins_pt
                         pts = @ins_pt
                         width = 36
                         length = 18
                         face.reverse!
                         face.pushpull 5
                         return @group
                  NOW ADD
                  puts 'end_tp details...' puts end_tp puts end_tp.class puts end_tp.name puts 'END'
                  THEN
                  end_ep.transform!(t1)
                  FAIL ? IF end_tp is NOT a group or component_instance ???
                  Report back what the 'puts' show in the Ruby Console...
                  • P
                    pmagans
                    This is the output - Doesn't get to the puts statements
                    true
                    end_tp details...
                    Error; #<NameError; undefined local variable or method `end_tp' for #<CONVEYOR;;Conveyor;0xb8a563c>>
                    C;/PROGRA~2/Google/GOOGLE~1/Plugins/Conveyor/CONVEYOR2.rb;43
                    C;/PROGRA~2/Google/GOOGLE~1/Plugins/Conveyor/CONVEYOR2.rb;27;in `initialize'
                    (eval);435;in `new'
                    (eval);435
                      Try this change: in the EndPulley code after
                      ###ADD
                      return @group
                      as the last code before the ' end' of the initialize...
                      REMOVE the equivalent line from the create_geometry method...
                      Run with the ' puts' to see what's what now...
                      • P
                        pmagans
                        Same message No change - its dying on the puts statements?
                        • Dan RathbunD
                          Dan Rathbun
                          WAIT !!
                          Earlier on I attempted to explain that his custom classes were WRAPPER CLASSES. (And questioned why anyone would want to actually do this. Subsequent edits by a user such as boolean operations can cause the references held by the wrapper class instances to become invalid and point at Sketchup::DeletedEntity objects.)
                          I showed an example which did NOT have a EndPully class, because it would ALSO be a wrapper class, whose new() constructor returns the wrapper instance NOT a Sketchup::Group instance.
                          SO.. therefore... he needs to call the EndPully instance's group() wrapper method (created via the attr_reader(:group) call,) which will return the actual group reference:
                          st_ep.group.transform! t1
                            Can you also add the equivalent 'puts' just after the
                            puts 'st_tp details...' puts st_tp puts st_tp.class puts st_tp.name puts 'END'
                            so we can see what the first part does...
                            • Dan RathbunD
                              Dan Rathbun
                              Sorry ... I got busy and did not get back to this thread,
                              I was going to continue the discussion on why wrapper classes are extremely problematic for Sketchup::Drawingelement subclasses. (One issue is on Mac multiple models could be open, but the API does not yet have a good way to track them, and we know of some bugs on the PC, that causes issues.)
                              Anyway... the alternative you REALLY should be using is to create a Sketchup::ComponentDefinition for your pully and conveyor, and then place instances of these (rather than Groups.)
                              The definition's instances collection will keep track of them for you.
                              The model's DefintionList collection will keep track of your definition(s) for each model that they are inserted into.
                              When a model is opened, your plugin can search through it's DefintionList to find those definitions that are "known" to the plugin. And then grab an array of their instances, and iterate it to get references.
                              • P
                                pmagans
                                Dan you are correct. Adding the .group gave me access to the "group" objects that were created.
                                As for my thought process I am not sure that it is valid so let me describe my thoughts.
                                I don't want to code "like" things so I assumed that using classes would allow me to inherit class attributes things without having to copy a bunch of code it multiple places. For example classes would be:
                                1. FUNCTIONAL AREAS
                                  [list:11tc2ay1]1. CONVEYOR
                                • CONVEYOR_COMPONENTS
                                • END_PULLEY
                                • DRIVE
                                • INTERMEDIATE_BED
                                • PAN_GUARD
                                • BEARINGS
                                • ETC.
                                • BUILDING_MODSETC.[/*β“‚11tc2ay1][/listβ­•11tc2ay1]Later I could write Customer specific code for each of the classes and inherit all of the functionality that I wrote in the "General" Classes
                                One customer's end_pulley may contain different bearings, pulleys, profiles etc. Also there are many types of end pulleys. That being said they do have some similarities especially attribute definitions, layer structure, basic functionality.
                                Am I on the right track or am I way off the rails?
                                • Dan RathbunD
                                  Dan Rathbun
                                  @TIG πŸŽ‰
                                  Simply put:
                                  A class constructor returns an instance of IT's class.
                                  CONVEYOR::EndPully.new() returns an instance of CONVEYOR::EndPully not an instance Sketchup::Group
                                  This is one of the MAJOR drawbacks of a wrapper class, you have to write wrapper methods for all the methods of the wrapped object that you wish to access "as if" the wrapper "were" the object itself.
                                  There are some ruby tricks to get a list of only the API methods, and define wrapper methods via an eval loop. But .. it's still can get complicated in other nitty-gritty ways.
                                  I just do not recommend it.
                                  • Dan RathbunD
                                    Dan Rathbun
                                    Dynamic Component definitions can give you a lot of flexibility. A style of pully, were the diameter and width are settable via the Component Options dialog.
                                    Your code classes and modules... are geometry creators, but not the actual model objects themselves.
                                    You can also inherit (share) code functionality via mixin module libraries.
                                    Given a mixin module named BasicPully ...
                                    module FancyPully
                                      include BasicPully
                                      # now overrride inherited methods if desired
                                      # now add additional methods if desired
                                    .. and later ...
                                    module NiftyPully
                                      include FancyPully
                                      β˜€ πŸ˜’ doh!
                                      • P
                                        pmagans
                                        I will check into the mixin module approach also the dynamic components. Are dynamic components "create-able" through Ruby code or only through the Sketchup interface?
                                        The only info/tutorial I could find was:
                                        http://sketchucation.com/forums/viewtopic.php?f=180&t=17888&p=145120&hilit=dynamic+component+tutorial#p145120
                                        • Dan RathbunD
                                          Dan Rathbun
                                          Both.
                                          But of course the coding means is not documented because the Free license users are not supposed to do it. (... or at least use a wizard interface.)
                                          A lot has been written about them.
                                          • P
                                            pmagans
                                            That's a bummer. I like the concept of dynamic tools for locking up variables and documenting the components, but I hate the user interface! It would just take me too long through traditional means to create a workable library. And of course if I wanted to change something I would have to do it in multiple places. I will do a more active search for creating/modifying dynamic components through Ruby. So far what I have found has not been that helpful besides holding/setting attributes. Any tips on where to start?
