Large circular lattice work
I've got a rotate question. Will SU rotate to the .00 percentage of a degree? Say like 11.77 degree rotate. I remember doing the spoke wheel and manually placing parts. When I got to the end, the last pieces where out of place. After checking the angle, it read 11.8, I went back and changed a few to 11.7 to make everything fit. Would a rotate / paste array work better (I hope that's the right term) or would a rotate / paste by divide (12/ entered after rotate) work? Or is there a better way to solve this problem?
Cliff
Su Works with degree
I believe that your result is just a lack of reading number of precision
(so it's a round up or round down)
you can increase the number of precision : Menu Windows / Model InfoYou can enter /7 or 7/
You can enter any entries after the rotation array until you take a another tool! -
Pilou, that was the ticket. Now it works great. I have better luck with the / before the number. Don't know why, just do. Hopefully I'll make you proud.
Dave, had a GREAT chat yesterday,
you answered most of my question for my short term goals. I didn't work on the bowie any more that night, to frustrated. But I did get the rotate / copy array down (thanks to the precision adjustment). I think most of my problems with the slat build up was with weld. 1st I get better results dividing it into 2 and welding then /3. Then for some reason I have to click the long curved right helix, then the top and bottom, followed by the left helix to get it to extrude right. Plus walking me through the choices for the boxes helped. No more guessing and trial and error, mostly error. I thought that you had sub folders in your layers? Not just single layers, but I thought I saw 1 layer with 2 sub layers, if that makes any sense to you. If I'm correct, "How do I do the same?".OK some long and short term goals. 1st I'd like to upload files that don't drive you all nutz trying to work with them. Then most of you guys should be able to work up plans from the files if you want to build one (you;ll still need the pdf). I'm working getting getting layers down to a point that help show how things are put together. On the short side, layers is in the works, drawing threads for both machine and wood screws. When I'm done with this project, I'll have it drawn down to the last nut and bolt. I'm not planning on doing it with other projects, but this is a big learning curve for me. I know how the yurts is built, how it works, so I want to see if I can pull off the details.
Time to beg for some more help. Here's 1 of the latest helix attempts. Problem is the tops of the inside slats are to far to the center. I've tried making an inside and outside slat, but dam near the same results. I followed Dave's walk through. Even tried scaling to mirror instead of flipping on the green. Any suggestions? It should be V6.
Cliff,
In thinking about it, although I used the same slat for both directions, by rights, it should be two different ones. Using the same method as I showed you, there should be two separate helices created with one have a radius that is larger than the other by the thickness of the slats. You can either draw the second helix and flip it along the green direction or get a reversed turn by typing -1 for the number of turns.
I enjoyed chatting with you yesterday.
D
IDK what you've covered with Dave.
If you are using the same slat for the inner. Choose an outer slat, copy it and Paste in Place. Then immediately flip along blue axis. You should then have a slat that is properly positioned in the circle, going the other direction (albeit you need to rotate about the yurt center per your inner slat layout). Before that you need to move it inward, as best you can, keeping a HORIZONTAL plane movement:
[Debatable at this point whether you wish to make the inner slat a different component from the outer. Think what you might be doing with it. You can do this later by selecting all the inner slats and making "unique" at once.]
Draw a line from bottom corner to bottom corner (or tops) of this new slat and the outside slat that you made it from. find the midpoint of that line and draw a horizontal line snapping to the center of the yurt (you might need further help setting that up?). Give that line the length of the thickness of the lath. Select the inner lath and use that short line as a guide for moving the lath inward.
Then you rotate the lath (by yurt center) to a proper circular offset per your plan, and radially duplicate it.
Do this on a copy of your file !
In case it totally doesn't work for you and you want to try something else!
( or... Select all outer lath copy, paste in place, group. flip along blue. Uniform red-green scale about center (~.995), rotate. Done. But then you've technically scaled the lath--but how technical IS a yurt?)
Just like you, Pilou, Cliff has Style
Why do you keep the End points, Extensions, and Profile style ?
It's very pertubating till the project is not finished !
You can disable them menu Window / Styles/ (edge setting - the little wireframe cube on the left)
You want make something like this ?
Pilou,
I find endpoints can be handy for seeing vertices while working sometimes. Profiles show a line that isn't lying in a plane. For the same purposes of working aid, I sometimes use color "by axis". Yeah it's ugly, but useful. Conversely I turn these off, rarely use them, in SU output. But plain edges is nicer on the eyes sometimes while modeling.
Peter
Nice. That door won't keep out the critters, through.
Dam I forgot to ask about lathe. Is that the rotate tool used with copy / paste or is it something else. A quick explanation, thread link, video, anything. It's one of those terms I've heard, just haven't researched it yet.
@ Pilou. those setting are the default for the program. I think it's the architecture feet, inches. I don't always turn them off, like when I copy something into a new file and have an idea to try. I forget about Style and just try to work out the problem. So what default format do you use?
Yes that's similar to what I'll be building, but with taller walls, smaller smoke ring, and a shallower roof. But that's the basic idea. Since I have built 1 before(plus there have been 100+ built by these plans), I know the plans work, but I'm having a problem doing it in SU. It could be my math (not like I haven't double, triple checked it and soon to do it again). Hopefully the next file won't make you want to scream at me again.
@ pbacot, welcome to scream at the noob. "Yes, I am joking around". You've got some good ideas I'll be trying. Dave and I talked about a WHOLE ZHIT load of stuff,
We both have a love for woodworking and I got to see some of his work. Basically he showed me how he draws, a quick run though on the hilex extrude. Why components are better to use and when working with smaller objects like I have been, to make a copy, scale it up, and finish the detail (great trick). Mostly what's been covered in the thread I was having problems with.@Dave, "Style?" not every guy can look that dam good in a kilt.
The custom Doubles and shirts help, But it's the English can opener I wear on my right forearm that makes the statement!
OK joking a side, this next file is basic, it's the smoke ring, rafters, and the slat (uncurved), I tried to get the layers to work from the ground up so you can see each step in the build up. I added notes in the components info to help clarify things. As always, any suggestions, comment, rants, raves or different angles to think about, "are greatly appreciated". 1 last thing, if I copy the objects in this file into a new file. Will the layer come with them, or are they in the file protocol and not the object protocol?
Layers come across with the things you paste into a new file.
Lathe is creating or modifying geometry with the follow me tool on a circle (or some other plugins). So you take a flat face in the shape of 1/2 of a vase and make it into a 3d vase. It's not like copy and paste.
Seems cool!
Well that's a beginning, Pilou has almost given me a thumbs up, I'll live with that for now.
So what template do you use, Pilou?Thanks Peter, I know that trick, Dave even said it works better scaled up. I just didn't know it was called lathe. The joys of learning a new vocabulary.
It's just the very funny RandomPainter by Chris Fullmer!
I'm making head way. I've got the slat to line up correctly. Now I just need to get the spacing down. Basically I went back to the 1st helix and started to double check EVERYTHING. I did find 1 small mistake I made in height, but that didn't affect anything. I also found 2 added inputs through boxes or cells on the spread sheet, but after recalculating the numbers, it seemed to small to worry about. But I started over just to play it safe. I could not tell the difference between the 1st helix and the new 1. The very tops didn't meet perfectly, but you had to really zoom in to see it. So I went through all the steps again, with 1 small twist. The outside slat is the old helix and the inside is the new. My 1st guess is I made some stupid rookie error and didn't catch it. I used some of Peter's suggestions to double check things where lined up as I went. But after practicing the steps all those times, there was less chance for an error. But I still need to check my typing when I enter file names.
Cliff,
Those look like they line up about as perfectly as SU can. Good job.
Peter
Clean!
But seems one slat is missing ?Here I have used the famous Grow By Tig
Who permits Array Move, Rotate, Scale in the same time!
Thanks guys, I've had a LOT of practice trying to get it right. And a big thanks to Dave for showing me the helix and extrude by rails.
Pilou, there is a slat missing, actually 2 sets of slats missing. the spacing with the bolt holes is wrong so everything isn't lining up. I went all the way back to the beginning and found 1 more mistake that just compounded all the way through. I working on correcting that now. I also need to work on getting the holes in the slats, but that been a pain I still need to work on.
Here's the next file to check out. See if you like how I did the layers. There's small stuff missing and I want to put thread on the bolts, but that will be later.
Seems good for people who love Layers
You have 2 general groups without names!
As in SU Layers are only layer of visibility and not layer of Geometry
Create always your objects in Layer 0, then dispatch them in layer wished
for avoid many problems!Something curious
As I am in an old country with decimal system
When I transform your measures in meters
I have that! Does this normal for a door?Ps Maybe you must choose colors of layers more near reality ? (not an obligation)
Here the objects by your Color's Layer
